Ashton Cove Theater Build - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 1056Likes
post #631 of 748 Old 04-11-2019, 08:46 AM
DougUSMC's Avatar
Quoted: 694 Post(s)
Liked: 579
Originally Posted by Oklahomie View Post
I am curious though, is there any value in laying a rubber mat underneath them? Super easy to do. I have extras.
Ok on the baffle wall, I would be up for the challenge, but what would the benefits of that be, and are there some easy guides as to how I would go about constructing it?
IDK, some say that they like the rubber matting to reduce vibration, but I've never done that. I went the "fill the stage with sand" route, and it's worked very well for me. I don't hear any vibration whatsoever coming from the stage.
IIRC from talking to @BrolicBeast they are primarily used to focus sound axis, pressure, and DBs to a specific direction. This leads to a net gain in SPL and raw DBs at a given location. He's much smarter at them, and can clarify/correct me tho.
DougUSMC is offline
post #632 of 748 Old 04-11-2019, 04:59 PM
OJ Bartley's Avatar
Quoted: 460 Post(s)
Liked: 552
Aaron H.
Yeah, baffle walls can help to reinforce the sound, especially in the midbass range (I think), but it learned to my dismay that they're really supposed to be quite dense and rigid... Like double DW & GG sandwich dense and rigid.
I know some of the guys with big QSC speakers said the baffle wall really made them come alive, but it isn't as simple a job as I had originally thought.
Sent from my SM-A520W using Tapatalk
OJ Bartley is offline
post #633 of 748 Old 04-11-2019, 06:01 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
Regarding a baffle wall for the titans I do not think it is necessary but I could be wrong. I heard but I am hope I Matt @mtg90 could confirm that the crossovers for the titans are design so a baffle wall is not needed. As I said I could be completely off track here.
As for the QSCs there are designed to be in a baffle wall
Mahuzz13 is online now
post #634 of 748 Old 04-11-2019, 09:13 PM - Thread Starter
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
4/11/19 - hang time!
This afternoon was an adventure! I got the z-clips installed on the back side of the screen & screen wall, then realized after placing it on the wall that there was a noticeable bend in the middle. So down went the screen, and all zip ties pulling the screen from the bottom. Took out the bracing, and installed longer, more rigid pieces, which helped keep the height in the center of the screen.
I think I still notice a very minor bend, but am going to wait and see how the a projected image looks before I make any other big changes to the screen.
There are minor dimples on the bottom edge of the screen, but it’s only noticeable when the spot lights on the top of the screen project down. When direct light is thrown on the screen, it looks like a perfect screen. Overall, I’m happy with how it turned out, I just hope that the minor bend won’t be too noticeable, otherwise I will take the screen down and do the same thing in the quarter sections of the screen.
Aaron H.
Aaron H.
Oklahomie is offline
post #635 of 748 Old 04-12-2019, 04:28 AM
tjambro's Avatar
Quoted: 29 Post(s)
Liked: 74
Aaron, my professional Seymour screen in my last theater had a few dimples only noticeable with down lights also.
tjambro is offline
post #636 of 748 Old 04-12-2019, 04:36 AM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
Hey Aaron, I would contact then manufacturer and see what they say and it could be an easy fix.
post #637 of 748 Old 04-12-2019, 06:43 AM
Quoted: 103 Post(s)
Liked: 137
Man that looks great. I love it. Perfect size.
It may be the camera but I think I notice the bend also. Either way it looks fantastic.
Oklahomie likes this.
Roll Tide.
p3bham is offline
post #638 of 748 Old 04-12-2019, 06:44 AM
eng-399's Avatar
Quoted: 2418 Post(s)
Liked: 4963
eng-399 is offline
post #639 of 748 Old 04-12-2019, 07:23 AM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 170
Aaron H.
AWESOME site!
BP1Fanatic is online now
post #640 of 748 Old 04-12-2019, 07:48 AM - Thread Starter
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
Ok I’ve done some laser leveling and there is a minor difference between the middle and the edges. But not huge. I’m calculating a 1/16” to 3/32” difference between the middle and edges with my laser level. It’s this spread at the top and bottom, so a total difference of 1/8”.
The question here, is will this be noticeable when the projector throws an image onto it? I guess the one way to test is for me to pull the projector out and see.
MIDDLE
RIGHT
LEFT
Aaron H.
impreza276 likes this.
Aaron H.
post #641 of 748 Old 04-12-2019, 08:34 AM
impreza276's Avatar
Quoted: 481 Post(s)
Liked: 718
No.
Noooooooo!!!
warwwolf7 and brazensol like this.
impreza276 is offline
post #642 of 748 Old 04-12-2019, 08:34 AM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 170
Loving the OCDness!
post #643 of 748 Old 04-12-2019, 08:37 AM - Thread Starter
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
I talked some sense into myself. I’m just going to push forward and will circle back to the screen if and when it’s an issue.
Working on velvet frames now.
Aaron H.
texpilot and Mahuzz13 like this.
Aaron H.
post #644 of 748 Old 04-12-2019, 10:59 AM
DougUSMC's Avatar
Quoted: 694 Post(s)
Liked: 579
That's a valid concern, the risk of seeing a 1/32" difference from 10'.
IT'S A TRAP!!!
Sir, please step away from the projector box, and focus once again on the side panels!!
DougUSMC is offline
post #645 of 748 Old 04-12-2019, 11:20 AM
thrillcat's Avatar
Quoted: 526 Post(s)
Liked: 492
You'll see it as soon as you project a football or basketball game that has a nice, straight-edge graphic along the bottom of the screen. Trust me.
I love my iPhone, but it will never replace my turntable. I've never seen Titanic OR XXXXXXXXX. Alexa is a stripper name.
The Cinema 1858 Remodel Thread
thrillcat is offline
post #646 of 748 Old 04-12-2019, 12:51 PM
sor
sor's Avatar
Quoted: 108 Post(s)
Liked: 79
Most people would be lucky to get their projection aligned to 1/16” at all four corners. That’s what the velvet frames are for.
sor is offline
post #647 of 748 Old 04-12-2019, 02:11 PM - Thread Starter
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
My hope is this exactly. I hope that the small variances will be covered by the velvet frames.
This is one of the exact use-cases I thought about in my mind. If there is a noticeable defect when Projector time rolls around, I will re-visit and make adjustments.
Aaron H.
Aaron H.
post #648 of 748 Old 04-12-2019, 02:14 PM - Thread Starter
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
Frames are half complete! It’s always fun measuring and building panels around imperfect designs and imperfect construction. I had to make the panels imperfect to fit perfectly within their slots!
I don’t know why I waited so long to buy a Kreg jig. These things are awesome.
Aaron H.
Aaron H.
post #649 of 748 Old 04-12-2019, 08:58 PM - Thread Starter
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
4/12/19 - completed stage wall
Woohoo, another mile marker passed. There are tiny imperfections all over the wall, but for a weekend warrior, I think I did alright, and I’m happy with the end result. The velvet I used is slightly different from the velvet that came with the screen; it’s not as pure dark as the screen velvet, but I’m venturing to guess it won’t be noticeable when the projector is running.
All of the panels are friction with just one or two Small Velcro spots to ensure a solid hold. The Velcro was much easier to staple than the GOM high beams fabric on the walls, which made the frame wrapping a piece of cake. I hope that the friction fit will hold through bass wobbling scenes from the six UM-18’s - time will tell.
There is no time for rest! I am cleaning the room as we speak and am prepping for step paint.
Aaron H.
Aaron H.
post #650 of 748 Old 04-12-2019, 09:00 PM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 170
Nice!
post #651 of 748 Old 04-12-2019, 09:01 PM - Thread Starter
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
@DougUSMC - can I hang my projector now?
Aaron H.
Aaron H.
post #652 of 748 Old 04-12-2019, 09:02 PM
eng-399's Avatar
Liked: 4963
eng-399 is offline
post #653 of 748 Old 04-13-2019, 09:27 AM
brazensol's Avatar
Quoted: 704 Post(s)
Liked: 525
Aaron H.
Only if you're happy the way everything looks at the precise moment you hang your projector...
Mahuzz13 likes this.
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP's; (3) HTM-12's; (14) RSL C34e surrounds; (2) 18" Dayton Audio RSS460HO-4 Subwoofers; (1) Dayton Audio UM18-22 18" Ultimax Subwoofer; (4) Dayton Audio RSS390HO-4 15" Reference HO Subwoofers
brazensol is offline
post #654 of 748 Old 04-13-2019, 10:20 AM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
I say go for it
post #655 of 748 Old 04-13-2019, 11:08 AM
texpilot's Avatar
Quoted: 227 Post(s)
Liked: 125
How do you get SO MUCH done SO FAST? Are you on vacation right now????? Your progress is simply amazing.
texpilot is offline
post #656 of 748 Old 04-13-2019, 11:14 AM - Thread Starter
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
I do work a staggered shift where I am off frequently on Fridays, so 3 day weekends and lots of time granted by the wife boss have helped accelerate my progress!!
Aaron H.
tjambro and texpilot like this.
Aaron H.
post #657 of 748 Old 04-13-2019, 11:23 AM
texpilot's Avatar
Quoted: 227 Post(s)
Liked: 125
Aaron H.
Okay, that helps me feel like a little bit less of a loser. But only a tiny bit. All credit to you and your amazingly productive work ethic!!!
texpilot is offline
post #658 of 748 Old 04-13-2019, 11:38 AM - Thread Starter
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
You aren’t a loser! Haha, perhaps I am the loser for not having a life and working on this room so much.
Aaron H.
Aaron H.
post #659 of 748 Old 04-13-2019, 11:43 AM
texpilot's Avatar
Quoted: 227 Post(s)
Liked: 125
Aaron H.
No way! Most people would consider the guy who still hasn’t finished his theater after three years the loser (me!) rather than a highly productive person such as yourself.
texpilot is offline
post #660 of 748 Old 04-13-2019, 02:17 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
Less than a year and Aaron you have come up with such a beautiful theatre, kudos to you my friend. It is nice to have that freedom to get your goals done in such a short period of time. Can’t wait to hear about your impressions on the first movie you watch
texpilot and Oklahomie like this.
