Ashton Cove Theater Build - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 1057Likes
post #691 of 749 Old 04-15-2019, 08:24 PM
Rjloper9's Avatar
Quoted: 28 Post(s)
Liked: 27
This theater is the DIY gold standard. Simply amazing and inspiring.
Oklahomie likes this.
Rjloper9 is online now
post #692 of 749 Old 04-16-2019, 04:42 AM - Thread Starter
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
Thank you, RJ! Hopefully I’ve given you some ideas to stew on as you plan your project out. You are in the planning phase, right?
Aaron H.
Aaron H.
Oklahomie is offline
post #693 of 749 Old 04-16-2019, 06:13 AM
Rjloper9's Avatar
Quoted: 28 Post(s)
Liked: 27
I’ve definitely thrown a lot of the ideas and techniques I’ve seen used in your thread into the vault.
You are correct, I’m in the planning phase for a space that doesn’t even exist yet. My wife and I are planning to move and hoping to build again. She’s already aware of my need for a dedicated theater space and has a front row seat to this rabbit hole I’ve swan dived into
Ryan
post #694 of 749 Old 04-16-2019, 06:48 AM
SteveCallas's Avatar
Quoted: 834 Post(s)
Liked: 765
When you get all the subwoofers running the way you like, please let me know if you get any rattling from those panels against the wall when the low frequency bass notes cause the walls to vibrate. Do you have any cushion between the panel frames and the walls besides the fabric wrapped over them?
SteveCallas is offline
post #695 of 749 Old 04-16-2019, 08:33 AM - Thread Starter
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
I have tested that, and the panels do not rattle at all, and I only have fabric separating them and the wall. They are very snuggly friction fit, so that might help mitigate that issue.
The sconces, A/C vents, and A/V closet door rattle when things get really loud, so I’ve got to figure out a plan to address those items.
Aaron H.
Aaron H.
post #696 of 749 Old 04-16-2019, 08:35 AM
LLDaLastDon's Avatar
Quoted: 21 Post(s)
Liked: 26
4/15/19 - audio and video
I had some other errands to take care of, so I didn’t make it to the store to pick up more wood for the panels, so instead I did a little calibration.
I configured a 16:9 and 2:35:1 lens memory for the projector, ran the Denon audio calibration, and tested with the opening scene of Guardians of The Galaxy 2. It looked beautiful and sounded great! The Denon calibration made a big difference from the stock settings that I had.
Wednesday might be the first official movie. Avengers Infinity War.
Aaron H.
Aw man. I'm so jealous. It looks amazing. You should do a full video walk though when you are done.
Sent from my Pixel 3 XL using Tapatalk
Larry L.
My Theater Build - The Lion's Lair
LLDaLastDon is offline
post #697 of 749 Old 04-16-2019, 08:59 AM
Quoted: 834 Post(s)
Liked: 765
I had the same issue with sconces - got some black D ring rubber seals, slit them down the arch of the D, and ran them around the back of the sconce that made contact to the wall.
I had some issues with the upper ball spring on the double door entry vibrating, so i used a combination of felt along the top and outer sides along with rubber double D seals where the doors meet and at the bottom.
Luckily no issues with any vent covers...those are usually screwed in pretty tight. Are you sure its the vent cover or could it be the actual duct hose vibrating on something?
post #698 of 749 Old 04-16-2019, 09:29 AM - Thread Starter
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
You know, it could be the can lights; I’m not 100% sure. I need to run a bass sweep test and just walk around to see. Because you are right, the AC vents are fastened pretty darn tight.
Aaron H.
Aaron H.
post #699 of 749 Old 04-16-2019, 02:57 PM
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
Arrrrrrrrggggggggggggggggghhhhhhhhhhhh!!! I'm away for a long weekend, and I miss so much! After following your thread this long I should have *known*!!
Love the steps idea. Dig the friction fit, grats on the PJ and seating!
And "Yes, you may now hang the PJ".
FYI, my answer WOULD have been "only if all of your punch list items are done". Come to find out, you didn't need me to tell you that, BRAVO Sir!
DougUSMC is offline
post #700 of 749 Old 04-16-2019, 08:19 PM
MinHeadroom's Avatar
Quoted: 56 Post(s)
Liked: 68
You are so methodical in your implementation AND your documentation- dude you should have a show on DIY. Pitch this!
(Keep it up)
MinHeadroom is offline
post #701 of 749 Old 04-17-2019, 04:43 AM - Thread Starter
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
(Keep it up)
Speaking of documentation - one of my after action items for this project is to have a table of contents on page 1 for people to easily link to the different stages of the build. I would love to have a show! Haha!! That would be cool...
Aaron H.
Aaron H.
post #702 of 749 Old 04-17-2019, 05:03 AM - Thread Starter
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
4/16/19 updates and more cleaning
I cleaned up the AV closet and bar area (with the help of the wife). Speaking of the bar, my little secret for the bar is that the granite is not silicone stuck to the cabinet, so that if I ever have to take the back panel off, I just move the granite out. The granite is so heavy though, that the risk of any slippage happening with it is near 0%.
I installed a ring smart doorbell so that we can still hear when people are ringing our doorbell from within the theater. I’m going to move the ring into one of the columns plugged into one of the lower utility outlets, which should be perfect.
I also spent some time getting all of the components in the AV rack hardwired into my LAN and firmware updated. I still need to update the projector, and confirmed with Mike Garrett that the early on firmware update issues with the RS1000’s are no longer an issue.
Today I’m going to scotch guard the fabric on the wall, to help protect it from stains and such, and i might see if I can find some magnetic strips to work on the main switch box in the room. I’ve got a good idea for how I want to bring those hue switches more flush with the surface.
I know I mentioned this previously, but the Denon Audyssey app brought the room to life. With how efficient the DIYSG speakers are, the Denon X6500H was the perfect choice for my room. I don’t have any regrets, or feelings of being “under-powered”. In fact, I can’t stand to turn the system up past 75 on a scale of 100.
Throwing in a few more still shots from me poking through guardians of the galaxy 2.
tjambro, James92TSi, 4fit? and 3 others like this.
Aaron H.
post #703 of 749 Old 04-17-2019, 05:05 AM
Quoted: 56 Post(s)
Liked: 68
The best part of this WIP is you are just making it happen, albeit the right way. There aren’t 10 posts between updates hemming hawing (as I do) about what to do next. It’s soooo engaging
post #704 of 749 Old 04-17-2019, 06:02 AM
OJ Bartley's Avatar
Quoted: 492 Post(s)
Liked: 583
Aaron, this theatre is simply beautiful. You've done an absolutely amazing job, and it is hands down one of my favourites on the forum. I will certainly be taking inspiration from your room as I move forward on mine. A+, 10/10, gold star.
Sent from my SM-A520W using Tapatalk
OJ Bartley is offline
post #705 of 749 Old 04-17-2019, 06:15 AM - Thread Starter
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
Thank you, OJ! It truly makes me happy to know that I’m helping others with their journey. So much of what I’ve done is from knowledge that I’ve gained reading other people’s journey with their builds, so to pass those lessons learned and ideas forward, was paramount for me.
Aaron H.
OJ Bartley likes this.
Aaron H.
post #706 of 749 Old 04-17-2019, 06:24 AM
lockdown571's Avatar
Quoted: 425 Post(s)
Liked: 315
Thanks for sharing. Finished product looks amazing. You probably said this somewhere, but what did the seating distance for the 1st row from the screen end up being? Looks like you went with a 165" diag 2.35:1 screen. How do you like the screen size? I was thinking something similar in the future for a room of that size.
lockdown571 is offline
post #707 of 749 Old 04-17-2019, 08:56 AM
BP1Fanatic's Avatar
Quoted: 226 Post(s)
Liked: 193
Nice video quality!
BP1Fanatic is offline
post #708 of 749 Old 04-17-2019, 09:24 AM - Thread Starter
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
I will use my laser measuring device tonight and get the exact distance for you. I want to say first row eyes are around 11’ and second row 17 1/2’.
The screen size is perfect. First row delivers a very immersive experience, while the second row is a little more casual. I think any bigger would be too much, unless the first row viewing distance were to be further back.
Aaron H.
lockdown571 likes this.
Aaron H.
post #709 of 749 Old 04-17-2019, 01:58 PM
Quoted: 107 Post(s)
Liked: 309
Sorry if you mentioned it elsewhere but where did you get the outlets with the usb ports above your bar? BTW like others have said stealing a lot of design ques from your build its an amazing space!
pkinneb is offline
post #710 of 749 Old 04-17-2019, 07:55 PM - Thread Starter
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
4/17/19 scotch guard, entrance switch, & paint
I wanted for the AC thermostat and Phillips Hue switches to be more flush with the wall, so I built inserts that I fabric wrapped and friction fit in-place. For the Phillips hue insert, I recessed magnets behind the fabric so that the switch/remote controls would have a “magical” stick to the fabric backer.
Before, progress, and after pictures
To protect the fabric walls from greasy popcorn hands, spills, and accidents, I scotch guarded the entire room. Multiple coats where hands would frequently touch fabric (picture is immediately after spraying. Everything dries clear)
I then took my matte black krylon spray paint and created a puddle of paint on a piece wood, then used a q-tip to touch-up scratches in the vents.
I think the last item I have left is to work on is the door panels.
@lockdown571 here are the distances from eyeballs to screen. 1st row is 11’ 9” and second row is 18’ 2” (reclined).
@pkinneb - I bought them off amazon. Here is a screenshot of my purchase for your reference. Love them.
Aaron H.
Aaron H.
post #711 of 749 Old 04-18-2019, 05:17 AM
DougUSMC's Avatar
Quoted: 719 Post(s)
Liked: 616
Great stuff, I really like the idea of the Ring doorbell!
DougUSMC is offline
post #712 of 749 Old 04-18-2019, 06:02 AM
Liked: 5
Aaron, this build is unreal. Well done, sir! Looking forward to the walk-through video when it's all complete (nudge nudge )...
DougUSMC and Oklahomie like this.
swipes is offline
post #713 of 749 Old 04-18-2019, 09:50 AM
COACH2369's Avatar
Quoted: 1207 Post(s)
Liked: 1006
I have been stalking this thread for awhile now.... FANTASTIC job!
And yes, a video is a must.
COACH2369 is offline
post #714 of 749 Old 04-18-2019, 08:12 PM
Liked: 7
Wow, looks great
Jetski6 is offline
post #715 of 749 Old 04-20-2019, 08:11 AM
Quoted: 107 Post(s)
Liked: 309
I had never seen one of these so I ordered one off Amazon man these are sweet! Thanks for the tip
texpilot and Oklahomie like this.
pkinneb is offline
post #716 of 749 Old 04-20-2019, 08:30 AM
texpilot's Avatar
Quoted: 228 Post(s)
Liked: 126
The Bosch are indeed great but be sure to get the backlit model like Aaron has. I have the cheaper non-backlit model and it stinks when you need to read it in low light!
Oklahomie and pkinneb like this.
texpilot is offline
post #717 of 749 Old 04-20-2019, 02:51 PM - Thread Starter
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
Yesterday we had our first official movie. Instead of infinity war, we watched aqua man. Holy cow what an experience!... I ended up having to turn down the bass because some members of my family couldn’t take it; it was quite loud. My family was blown away by the entire experience. I think I’ve turned them away from the traditional movie theater experience (wasn’t Intentional ).
After the movie, we watched the OKC Thunder playoff l game, which was equally as cool! The game to life in the theater room. It was like you truly there. You could hear the roar of the fans, the squeak of the players shoes, the background music playing, the yelling of the players - very engaging experience.
We also have the popcorn machine a good run!
Tonight will be the second showing - infinity war. I think all 8 seats are sold out! More family. I think tonight we will pull out the margarita machine and give it some good use as well.
Next item on my list is figuring out automation for lighting and AV controls. AND I still need to build the panels for the entrance door.
Aaron H.
Aaron H.
post #718 of 749 Old 04-20-2019, 02:56 PM
BP1Fanatic's Avatar
Quoted: 226 Post(s)
Liked: 193
Excellent!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
post #719 of 749 Old 04-21-2019, 02:41 PM
Cold_Country's Avatar
Liked: 63
Send a message via Skype™ to Cold_Country
Great Job Aaron!! Now you get to ENJOY!! I wish I was in the same boat ... but I see at least a couple more months of building in my future!
One question now that you have the projector up and running: I always liked the white crown and base colors you used, but I was concerned about the reflection from it ... so I was going to go with black crown, base and chair rail.
However, from your pics, I don't see a lot of reflection. How do you find it? Is it distracting ... or is it no bother at all?
Cold_Country is offline
post #720 of 749 Old 04-21-2019, 06:09 PM - Thread Starter
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 763
I don’t find it distracting at all. As I go back and look at pictures I’ve taken, in really bright scenes, you can see them in the picture, and they stand out a little bit, but during the movie, it’s never even been a thought.
Aaron H.
Aaron H.
