The Hideaway Theater - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 3292Likes
post #271 of 3684 Old 03-15-2019, 11:05 AM
carp's Avatar
Quoted: 3545 Post(s)
Liked: 3290
Originally Posted by ddigler View Post
@trhought - i am so intrigued by the BOSS; I want it! Thanks for developing and sharing your ideas for what, to me, is one of the most intriguing designs I have seen to bring TR to a HT!
Problem is I don't know if I have room under my reclining seats for the drivers. See below. I really want to build this thing. Suggestions, thoughts? I will pull any measurements from my seats if that helps?
This looks almost exactly like the underside of my HT chairs. No way will the driver fit, so I'm going to do what Tim is talking about with putting the drivers behind the chairs.
Originally Posted by trhought View Post
PSA: These JBL's are on sale right now at Best Buy for $29.99.....the GX1200's. Get 'em while you can!
Nice! I just bought 6, so I'm up to 7 total including the one I already have. So, 4 for the individual HT chairs in the front row and 3 for the back row riser with the couch on it.
I'm ready to roll with 1 of the drivers this weekend. I have everything I need except for the bumper feet you recommend which will get here on Wednesday. In the meantime I'll try it with my Crowson isolators. Should be fun!
SBuger and trhought like this.
carp is offline
post #272 of 3684 Old 03-15-2019, 11:09 AM
carp's Avatar
Liked: 3290
Now I just have to think of a creative way to hide the drivers that will be behind the chairs.
For my main seat I'm thinking of putting in a platform that will cover the driver and at the same time allow for me to stack my NF sub on top. That way I can get the low end feel from the BOSS and the chest punch of the NF sub.
SBuger likes this.
carp is offline
post #273 of 3684 Old 03-15-2019, 11:50 AM
Chris Young's Avatar
Quoted: 65 Post(s)
Liked: 193
I just wanted to share At this time the GX1200 is on sale at bestbuy.com
trhought likes this.
"The Boy has no patience" Yoda
"He will learn patience. Was I any different when you taught me?" Obi-Wan
My attempt living room build The Story Time Theater
3 DIY HTM-12 LCR 10 M&K S-100B, 2 Servodrive Contrabass. 2 SVS PB12/2 Plus(ForSale). 2 V.B.S.S., 2 Adire Tempest Side Columns Near field Fun all in one room.
Chris Young is offline
post #274 of 3684 Old 03-15-2019, 12:59 PM - Thread Starter
trhought's Avatar
Quoted: 725 Post(s)
Liked: 1242
Great thinking carp! Sounds like a great plan. Hoping everything fits OK!
Have you thought about raising the riser a few inches.....that would probably allow the JBL's to clear underneath your recliners. Maybe, you don't have the room....I recall your ceiling heights were low to begin with....I think. My memory isn't as good as it used to be...lol.
trhought is offline
post #275 of 3684 Old 03-15-2019, 03:21 PM
carp's Avatar
Liked: 3290
My riser is already to the point where pepole around 6' 3" or taller could possibly hit their head as they exit the riser because of the beam which hangs down around 10 inches from the ceiling, and that beam is right next to where you step down off of one of the sides of the riser. I did put some of those child safety pads on it so it won't really hurt too much. I'm 6'1" so I would be fine with raising the riser a bit for the new isolation feet that you use, but I don't what to have to raise it more than that.
carp is offline
post #276 of 3684 Old 03-15-2019, 03:29 PM
brazensol's Avatar
Quoted: 752 Post(s)
Liked: 574
That figures. Just had mine delivered yesterday! Now I got to drive back to Anchorage and get a price adjust. But thanks for the heads-up on the sale!
I'm also in the same boat as some others with the chairs being motorized. Would you happen to know how far above the plywood (when using a single 3/4" piece) the speaker sits when mounted?
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP; (2) iNuke NX3000D; (3) HTM-12; (14) RSL C34e surrounds; (2) 18" DA RSS460HO-4 Subwoofers; (1) DA UM18-22 18" Ultimax Subwoofer; (4) DA RSS390HO-4 15" Reference HO Subwoofers; BOSS Platform - (12) 12" Subwoofers
brazensol is offline
post #277 of 3684 Old 03-15-2019, 03:33 PM - Thread Starter
trhought's Avatar
Quoted: 725 Post(s)
Liked: 1242
^^^^ Oh yeah, not a good situation....another safety hazard to avoid for sure!
I saw you're getting the prescribed isos which I think you will like a lot. Curious your thoughts between the Crowson isos and the BOSS isos. The Crowson isos looked stiffer but it's so hard to tell from the pictures. In general, the softer the isos, the more TR you will get with the BOSS. Won't be long and you'll be enjoying crazy ULF and TR in every seat of your theater!
trhought is offline
post #278 of 3684 Old 03-15-2019, 03:43 PM - Thread Starter
trhought's Avatar
Quoted: 725 Post(s)
Liked: 1242
Hey brazensol....Hopefully it'll be worth the gas and your time to make the trip for the price-match!
I just measured my mini-riser BOSS with 3/4" thick plywood....the top of the JBL magnet is 5.25" above the top of the BOSS platform.
SBuger and brazensol like this.
trhought is offline
post #279 of 3684 Old 03-15-2019, 05:18 PM
brazensol's Avatar
Quoted: 752 Post(s)
Liked: 574
Since I paid $65.00/ea for 6 of them it'll be worth it! Besides we have to go to Anchorage tomorrow or Sunday for groceries from the base commissary (my wife is still active duty and I'm retired). Groceries are much cheaper at the base than on the local Alaskan economy. As it happens I was in Anchorage this morning (Dr. appointment) and picked up a 65" Vizio P65 F1 at Best Buy. I was going to get the LG B8 (which was waiting for me to pick up at the base exchange) but decided it just wasn't worth twice the price. So all in all I'm saving about ~$1210.00!
Denali Cinema
post #280 of 3684 Old 03-15-2019, 05:19 PM
brazensol's Avatar
Quoted: 752 Post(s)
Liked: 574
Thanks for measuring! That might be hard to work around.
Denali Cinema
post #281 of 3684 Old 03-15-2019, 05:34 PM
Gorilla Killa's Avatar
Quoted: 1460 Post(s)
Liked: 2070
That tv is a great value @brazensol , don't look back. There's going to be quite a few stoked enthusiasts in here shortly.
ID:	2565816   Click image for larger version
ID:	2565830   Click image for larger version
ID:	2565832   Click image for larger version
trhought and brazensol like this.
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is online now
post #282 of 3684 Old 03-15-2019, 06:22 PM
SteveCallas's Avatar
Quoted: 839 Post(s)
Liked: 769
@trhought - you say the more rigid the riser the better eh? Fair enough, 3 layers of 3/4 inch void free plywood for a 48 x 32 x 2.25 inch riser is going to extremely rigid.
SteveCallas is offline
post #283 of 3684 Old 03-15-2019, 07:11 PM - Thread Starter
trhought's Avatar
Quoted: 725 Post(s)
Liked: 1242
Definitely worth the drive then! Enjoy your trip and looking forward to learning more about your BOSS build and experience! The first Alaskan BOSS....lol.
brazensol likes this.
trhought is offline
post #284 of 3684 Old 03-15-2019, 07:14 PM - Thread Starter
trhought's Avatar
Quoted: 725 Post(s)
Liked: 1242
LOL...That should do it! Will make fitting those 15's a bit easier too I'd imagine!
trhought is offline
post #285 of 3684 Old 03-16-2019, 09:52 AM
Ford Prefect's Avatar
I think I'm going to say screw it and not have the mini riser(s) stick out in front of the chairs. I recline almost all of the time anyway, and it will be easier to just hide the risers under the chairs. I just don't think I could make it look good with the curved front row, and then there is the whole tripping hazard to think about.
When I have people over for a movie they always recline too.
I would like to have no riser sticking out in front of the seats, to avoid the tripping hazard.
However, I don't have recliners. The viewers would still feel TR through their seats, but not through their feet. Is that an issue, or not?
/Ford
Ford Prefect is offline
post #286 of 3684 Old 03-16-2019, 10:16 AM - Thread Starter
trhought's Avatar
Quoted: 725 Post(s)
Liked: 1242
^^^^ @Ford Prefect Good Question.....the realism is maximized if you have your feet along with your entire body being moved by the platform.
Having said that, the ULF and TR from the BOSS will still deliver a very natural and impactful experience even without the foot platform. I use my foot platforms (front and back rows) primarily for enhancing the music experience. With movies, the visual cues are enough to make the experience natural and real. Plus, I find myself drawing my legs up onto the chair or couch anyway during movies so no big deal.
For whatever reason, I prefer to listen to music with my feet on the floor, or one leg crossed over the other with one foot still on the ground. That's just my music listening pose...lol. When there's no visual cues on the screen and I'm getting swept away by music only, the platform helps a lot I've found.
Hope these perspectives help!
trhought is offline
post #287 of 3684 Old 03-16-2019, 12:01 PM
carp's Avatar
Liked: 3290
I just fired it up for the first time, listening to some music and it's very impressive.
I started with some metal and it has all the feel I would ever want, way more headroom than needed actually.
Next I put on some Bassotronics. Hmmm... what happened to the 8 hz centered quick hitting tone and the drawn out 17 hz centered tone? So I tried some test tones and sure enough there is VERY strong feel down to around 30 hz and then it starts to drop off rapidly. I can barely feel 20hz and can't feel 10hz at all.
It has to be that the isolators are too stiff for the low stuff.
Also I do notice that I feel it slightly more in the legs (reclined) than I do in the rest of my body. I'm hoping Tim's recommended isolators address that too.
I am so impressed though! The bass feel above 30hz is fantastic. Love it. Can't wait to get the other isolators!
Thanks Tim for sharing this ingenious idea!
carp is offline
post #288 of 3684 Old 03-16-2019, 01:00 PM - Thread Starter
trhought's Avatar
Quoted: 725 Post(s)
Liked: 1242
Hey carp....Great to hear you got it built and running! Absolutely.....the prescribed isolators will help big time with the single digit frequencies and overall response will roll off quite naturally at the higher frequencies where it should. Won't be long and you'll be enjoying that single digit ULF and TR that will feel so natural. Keep us posted when you get the new isolators.....hopefully they get there earlier than expected...fingers crossed!
SBuger likes this.
trhought is offline
post #289 of 3684 Old 03-16-2019, 01:28 PM - Thread Starter
trhought's Avatar
Quoted: 725 Post(s)
Liked: 1242
@carp Just thought of something else you could try until the softer isolators get there. If you have enough of the stiffer isolators, stack them on top of one another if you want to play around. That will cut their spring rate in half and lower the BOSS response from ~30Hz that you're getting now down to ~15-20Hz. The really soft ones I prescribe will easily get you into the single digits.
Gorilla Killa likes this.
trhought is offline
post #290 of 3684 Old 03-16-2019, 03:15 PM
carp's Avatar
Liked: 3290
@trhought Great idea, done and done.
Worked like you would expect, now I'm pretty strong down close to 15hz. When playing Bass I Love You the 17hz tone is very strong. If I crank the volume way up I can just barely feel 10hz.
Oh, I forgot to mention earlier that I am using a house curve eq on the minidsp so it is a bit of a cheat. Without that the low stuff is still pretty weak compared to above 30. However, since I was running that same EQ curve before with 1 isolator it is an apples to apples comparison to stacking 2 of the Crowson isolators.
I can definitely feel the difference just sitting on the chair and moving my weight around a little bit, the chair has a lot more "float" to it.
ID:	2540088   Click image for larger version
SBuger and Gorilla Killa like this.
carp is offline
post #291 of 3684 Old 03-16-2019, 03:24 PM
gpmbc's Avatar
Quoted: 386 Post(s)
Liked: 264
So Carp, with the low stuff being weak without the minidsp, do you think that’s a result of still not having soft enough isolators or maybe not rigid enough platform?
gpmbc is offline
post #292 of 3684 Old 03-16-2019, 03:29 PM - Thread Starter
trhought's Avatar
Quoted: 725 Post(s)
Liked: 1242
carp....glad it helped soften the ride a bit! You'll be surprised how soft the prescribed isolators are and what they will do for the single digit content. Looks great! Enjoy your new ride....it's only gonna get better!
trhought is offline
post #293 of 3684 Old 03-16-2019, 03:35 PM
carp's Avatar
Liked: 3290
Hey Greg, I just replied to your PM.
I don't know. I hope it's not the platform because it is 3/4 plywood and seems pretty rigid and I don't want to have to stack another on top of it....
So yeah I hope it's the isolators and I think it is. They really don't compress much.
carp is offline
post #294 of 3684 Old 03-16-2019, 03:41 PM
gpmbc's Avatar
Quoted: 386 Post(s)
Liked: 264
So speaking of platform rigidity, should I do 1” thick 13 ply Baltic Birch or dual layer 3/4”? Keeping in mind my drivers will be on the back side of my seating.
gpmbc is offline
post #295 of 3684 Old 03-16-2019, 03:50 PM - Thread Starter
trhought's Avatar
Quoted: 725 Post(s)
Liked: 1242
^^^^ @gpmbc I think either will work. If it were me, I'd go with the least cost option. If your overall mini-riser height is a concern, the 1" birch would probably be better to save the 1/2". If riser height isn't a concern, you may even be able to build a thicker riser and move the JBL's underneath the chair if that's possible. If you have the JBL's already, just tilt your chair up and place one of the JBL's where you think it will fit. Slowly lower the chair until it hits the magnet. Measure the distance from the bottom of the chair leg to the floor. That's how thick your riser will have to be.
Hope this makes sense.
trhought is offline
post #296 of 3684 Old 03-16-2019, 04:03 PM
gpmbc's Avatar
Quoted: 386 Post(s)
Liked: 264
Thanks Tim, I’ve got my drivers and isolators. When I get back in town, just gotta get wood and I’m good to go.
gpmbc is offline
post #297 of 3684 Old 03-16-2019, 06:10 PM
Liked: 2070
Hell yes it is. Hope you bought extra, double them up to!
post #298 of 3684 Old 03-16-2019, 06:48 PM
SBuger's Avatar
Quoted: 1249 Post(s)
Liked: 4037
Did you double up up for the VS measurements in the VS thread, or just stay with the single layer Iso's?
My 'Blacked Out' Home Theater | Tactile Response for BASS | BassEQ for Filtered Movies
1400cuft Sealed Room on Suspended Floor | SY Triple Black Velvet Blackout | GIK Treatments | Denon AVR-X6300H - 7.6.4 Atmos | KEF Q Series Speakers | Epson 5040UB 4K | Eyes 6.5' to 120" AT Seymour Screen | Oppo 203 | Xbox One X | Apple TV 4K | 6x 18" Sealed DIY Subs | 6x Crowson MAs | 4x BK LFEs | BOSS 'Sub Riser' w/ 6x JBL-12s | MiniDSP 10x10HD
SBuger is offline
post #299 of 3684 Old 03-16-2019, 06:55 PM
Liked: 2070
Im doubled up for all measurements. Im also on basement slab, closed room. Staying that way to be sure, could always turn it down but it will never happen. I have my doubled like snowman. Highly recommend doubling
SBuger likes this.
post #300 of 3684 Old 03-16-2019, 07:03 PM
SBuger's Avatar
Liked: 4037
^^^ Cool, do the iso's and platform stay in place that way pretty good and not slip off/slide around much? So you mean round side to round then right?
Pretty big diff in feel going from single to doubled huh?
EDIT:I guess if one is going to double up, you could go with the 1.25” hemisphere instead of the 2.5” to keep height down a little. A little cheaper too. Maybe not quite as much mass to squish though with the smaller ones.
Are you using the 2.5" hemisphere iso's?
SBuger is offline
