The Hideaway Theater - Page 77 - AVS Forum | Home Theater Discussions And Reviews
 2756Likes
post #2281 of 2856 Old 05-13-2019, 10:25 AM
brazensol's Avatar
Quoted: 700 Post(s)
Liked: 516
Originally Posted by David Charles View Post
pardon my asking, but where are these 29.99 drivers that I am reading of? I see them for about 50 to 60 bucks each.
Dave
And the sale price seems to only last for one day so you have to act fast when they do go on sale!
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP's; (3) HTM-12's; (14) RSL C34e surrounds; (2) 18" Dayton Audio RSS460HO-4 Subwoofers; (1) Dayton Audio UM18-22 18" Ultimax Subwoofer; (4) Dayton Audio RSS390HO-4 15" Reference HO Subwoofers
brazensol is offline
post #2282 of 2856 Old 05-13-2019, 11:09 AM
Gorilla Killa's Avatar
Quoted: 1321 Post(s)
Liked: 1813
Since I have 2 holes, and I already had to raise the riser I contacted pierce to see what a low budget, high mass and xmax option would be. Switching baskets shaves a 1.25" so that helps also its cheaper. Won't need more than 500 watts. He'll basically be matching what I have, shallower and hopefully a bit cheaper.
SBuger and Nalleh like this.
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is offline
post #2283 of 2856 Old 05-13-2019, 11:19 AM
SBuger's Avatar
Quoted: 1156 Post(s)
Liked: 3561
Originally Posted by Sekosche View Post
Come on man! Lol, having the platform also being portable makes it hard to argue with that. I’m just not sure if the 15” Dayton Classic would be a big enough upgrade to justify dropping another $255 on three, and I already have the 6 JBLs on hand, but it would be much simpler to keep the same riser rather than spend another full day building a new one.
By going all out, I meant more with some pricier 15-18” drivers, like the Dayton Reference line with a much higher moving mass. If the unused 18” Dayton 460HO I have on hand would fit, I could just buy one more of those and be set for ($300 though), and a pair would be 1,000g mms, a bit more more Xmax, but a similar Fs to the JBL, seems the reference RS line specs would fit a BOSS build better than the high output line, but I have a spare HO already. I really want to stick with using all three drivers areas of my riser too, so a trio of higher output subs would get pricy fast.
I love a lot of TR, but I’m not sure at what point it’ll honestly be too much and is just total overkill. I really think I’m fast approaching that area. Watching The Wave at reference now, and I don’t feel I’m missing anything.
After typing this up, think I’ll sleep on my options a while and go from there.
@Sekosche - reading over your last 3-4 posts and maybe a few of your others on the subject in different threads, as exciting as adding more drivers and or bigger ones sounds (I'm sure they would add to the low end), as happy as you are with what you've got now with the 3 JBLs and MAs, FWIW, I think if I were you I'd just leave well enough alone and just enjoy the heck out of it right now. Then if you get board and want more later or when you move, then add more or bigger.
It really does sound like your system is giving you about everything you could want right now, which is awesome!! LOL how's that for relieving some of the pure pressure that's been going on lately and not just enabling here for MOAR hahaha
My "Blacked Out" Home Theater Room
1400cuft sealed room on suspended floor | SY Triple Black Velvet for Blackout | Denon AVR-X6300H - 7.6.4 Atmos | KEF Q Series Speakers | GIK Treatments | Oppo UDP 203 | Eyes 7' to 120" AT Seymour Drop Screen | Epson 5030 PJ | 6x 18" Sealed DIY Subs (4x SI DS4-18s & 2x UM22-18s) | 6x Crowson MAs | BOSS 'Sub Riser' 6x JBL-12s | MiniDSP 10x10HD
SBuger is offline
post #2284 of 2856 Old 05-13-2019, 12:12 PM
AdamAttewell's Avatar
Quoted: 557 Post(s)
Liked: 119
Thanks for all the great info guys just pricing up what its going to cost me to build two platforms for my front & back rows my shopping list so far.
I presume a 4000 watt amp will be more than enough, I dont know if I can go lower with this or not to save some money.
I have a MiniDSP 2x4 that I will be using for applying EQ, I already have some speaker cable but what gauge should I be using?
Need to find a local lumber yard for the plywood, this seems to be what everyone is using.
I already have isolators on my recliners but I presume I will need more to isolate the BOSS platform from the floor?
AdamAttewell is online now
post #2285 of 2856 Old 05-13-2019, 12:29 PM
SteveCallas's Avatar
Quoted: 737 Post(s)
Liked: 662
@AcousticSoul - along the lines of what trthought was alluding to, the xmech on the Dayton must be quite a bit more than 9mm and it may have a soft bottom design, because i can get it moving like crazy with no clank sounds. Im thinking it can handle more than 20 watts, im sure its seeing a fair bit more in spirited passages in my system.
SteveCallas is offline
post #2286 of 2856 Old 05-13-2019, 05:10 PM
Liked: 1813
@Nalleh Here's a few pics. I left spacing everywhere underneath in between bays to keep from closing the spaces up. I think being too close to the ground and confining the drivers contributes to spl. Making sure I don't get another wild hair before I tidy it up and put the velvet or speaker cloth on it.
ID:	2566334   Click image for larger version
ID:	2566336   Click image for larger version
carp, SBuger, trhought and 2 others like this.
post #2287 of 2856 Old 05-13-2019, 05:56 PM
Quoted: 737 Post(s)
Liked: 662
@Gorilla Killa - you may be right about a small gap contributing to sound - Mark Seaton was thinking a small gap can lead to more trampoline effect though because the front wave pressure has more resistance and pushes up against the platform.
Gorilla Killa and Nalleh like this.
post #2288 of 2856 Old 05-13-2019, 07:01 PM
Archaea's Avatar
Quoted: 3761 Post(s)
Liked: 3531
Finally hooked up my nx3000d tonight. That single amp is subjectively louder than all four of my last iteration inuke DSP 6000's together. It's gotta go in the other room.
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is offline
post #2289 of 2856 Old 05-13-2019, 07:22 PM
raynist's Avatar
Quoted: 2031 Post(s)
Liked: 2106
Did you fan mod the older 6000’s?
raynist is online now
post #2290 of 2856 Old 05-13-2019, 07:24 PM
Archaea's Avatar
Liked: 3531
Nope. They were the final iteration (3100 watts x 2 rating) before they moved to the new NX series. Each iteration of inuke I owned got quieter I think. The first iteration was REALLY loud, the hair dryer analogy was the joke - but it wasn't too far exaggerated when they were under load.
Second gen wasn't as bad, and third gen was downright respectful, and I've NEVER heard the fan spin up on this final generation - not even when solid clip lights for long periods of time (limiter lights in my case since I limit the channels to 1750 watts each channel (to prevent power cycling on my sealed UM18-22, (4 ohm load per channel)).
I owned one of three different generations. Not sure why they went backllouder again on the new NX series. Pretty surprisingly really. Here' I'll record something and throw it up on imagur for a comparison.
Edit. Here you are.
https://imgur.com/gallery/BnnfyPN
Archaea is offline
post #2291 of 2856 Old 05-13-2019, 07:28 PM
raynist's Avatar
Liked: 2106
Nope. They were the final iteration before they moved to the new NX series. Each iteration got quieter I think. I believe I owned one of three different generations. Not sure why they went louder again on the NX series. Pretty surprisingly really. Here' I'll record something and throw it up on imagur for a comparison.
I can modded both of my NX3000D’s. I don’t have an equipment room so they were way too loud.
I have a last gen inuke 6000 DSP in my garage that is fan modded - it is loud - but in the garage I can’t really hear it over the music playing - and my garage is quite large so unless you are right next to it you can’t hear it.
post #2292 of 2856 Old 05-13-2019, 07:28 PM
Quoted: 25 Post(s)
Oh the horror! I am not happy to hear that.
I have a new 3000 and 6000 to install and would have assumed they kept the fan noise down after the last iterations of the iNukes. I modded my old 3000. Anyone modded the new models?
Casey
CaseyH71 is offline
post #2293 of 2856 Old 05-13-2019, 07:36 PM
raynist's Avatar
Liked: 2106
Casey
It is the same process as before.
These amps are made for professional audio where fan noise is a non issue. It is just a small percentage of crazies like us that use them in home environments
post #2294 of 2856 Old 05-13-2019, 07:46 PM
Archaea's Avatar
Liked: 3531
Yeah but it’s nonsense they took a step backwards because they were clearly getting the message from their consumers that we wanted quieter fans
Here’s my video evidence at how much louder the NX3000D is. Not only louder but cheaper sounding higher pitched fan too.
CaseyH71 likes this.
Archaea is offline
post #2295 of 2856 Old 05-13-2019, 08:38 PM
tvuong's Avatar
Quoted: 2536 Post(s)
Liked: 2169
^^ Yeap, it is loud, luckily fan mod took me about 10 minutes. It is now dead silence
ID:	2566458   Click image for larger version
ID:	2566464   Click image for larger version
ID:	2566468   Click image for larger version
ID:	2566706   Click image for larger version
tvuong is online now
post #2296 of 2856 Old 05-13-2019, 09:16 PM
Nalleh's Avatar
Quoted: 2392 Post(s)
Liked: 3070
Awsome, thanks
That is truly a big boy BOSS.
SBuger likes this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 8xJBL 12" BOSS - 4xJBL 12" w/SLAPS M12" VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is online now
post #2297 of 2856 Old 05-13-2019, 11:32 PM
Russell Burrows's Avatar
Quoted: 63 Post(s)
Red face
True.In my case a pair of cheap chinese brand Subwoofers are keeping me Happy on a single 3 . 4 mdf mini riser and your post made me stop and say maybe i will try more or better quality subwoofer next week or next month but for now i am just enjoying my humble diy tr in movie and music
SBuger and trhought like this.
Yamaha avr, diy l c r surround Behringer nx3000 dsp Fi car audio ib318 v2 310 cubic foot concrete ib lg pf 1500 projector.steren projector mount.
Pending create diy riser Bass shakers , buy fourty 6 inch drivers for some new mains get new 4k projector
I can hear my wallet screaming already
Russell Burrows is offline
post #2298 of 2856 Old 05-14-2019, 10:09 AM
brazensol's Avatar
Quoted: 700 Post(s)
Liked: 516
Interesting on the 3000D fan noise. I haven't plugged mine in yet but I can't say as I noticed any appreciable difference on my new 6000D vs the 6000DSP's. Glad I have an equipment room but might consider fan mods at some point down the road when things slow down. If that ever happens. I'm remodeling my house (everything on the first floor will get touched one way or another) as well as finishing the huge basement. It never ends...
Denali Cinema
post #2299 of 2856 Old 05-14-2019, 11:18 AM
FriscoDTM's Avatar
Quoted: 417 Post(s)
Liked: 388
A little more but what about the DIYSG buyout 15”?
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One X, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #2300 of 2856 Old 05-14-2019, 03:13 PM
Liked: 1813
So Pierce went off the rails price wise so that's a bust. FU Audio has these for $220 shipped, I may pick one up. 20mm xmax and 480g mms, decent motor strength. Similar to the SI HT18.
https://www.fuaudio.com/product-page/fu750v2-0-s-18
Nalleh likes this.
post #2301 of 2856 Old 05-14-2019, 03:29 PM
Liked: 1813
I think someone hacked @SBuger account, trying to talk you off the ledge with all the TR he's surrounded by. Can you build a riser for 1 seat and put the 18 in it? That will give you a reference point for the 18, if more TR is wanted for little outlay of cash.
SBuger, Nalleh and Sekosche like this.
post #2302 of 2856 Old 05-14-2019, 06:17 PM
SBuger's Avatar
Liked: 3561
LOL ...yeah someone must have taken over my account yesterday, as that was not a usual SBuger answer/post was it hahaha.
Nah, seriously ...I thought I'd try to be sensible here for once with someone else's time, especially after what happened with @Nalleh recently by kind of taking a step or two back from that insane TR setup he previously had just to try something new after I kind of went crazy with it all and adding the BOSS into the mix. Although it's sent him into full blown TR experimental mode now and I'm sure what he'll come up with combo wise will just completely blow the doors off any of our TR setups. I hope so, and can't wait to see it!! I'm sure it will push and inspire me as well as others, like you and others have done already. It does keep it exciting I gotta say!!
I'm a TR junkie for sure and seem to never tire of chasing more TR, or better TR maybe I should say. But really, I should probably just leave well enough alone too, with what I have going right now and just start enjoying a lot of movies (I'm gettin way far behind on a lot of great new movies), instead of thinking about 18's and SLAPS etc. BUT, I do love to experiment with it all and trying to push the boundaries of TR. Most of the time, it's half the fun for me It sounded like Sekosche was kind of having a hard time deciding if adding more was the right move right now since he is so happy with what he has ATM. Once you get to that point, sometimes its just best to enjoy, at least for a little while LOL But if he wants to go for more, bigger and better and all that, ...cool, more power to him, I'm sure he'll get what he's after if he does go for it. And I'll enjoy reading about it and be truly be happy for him, as I think he's a all out crazy TR junkie as well, like a lot of us (or at least a handful of us) seem to be around here.
After the last couple if days with recent config experiments and whatnot of my own, I think I'm about to that point too and ready to just start enjoying a whole lot of content for a while. I am curious about the 18's though with your beast of a BOSS. I may try my 18's too, I don't know, depending on how Nalleh's (and your) experiments go. I'm kind of fighting the thought of setting up much higher than I already am though. The VNF 18's + Crowson MAs + BOSS with JBLs + a little bit of BK LFEs seemed to be bringing it pretty hardcore today, bringing a HUGE smile to my face I think it's definitely the best and most powerful the TR in my system has ever felt in this new room. BUT as we know, there is always room for improvement in this hobby it seems. Especially when one is a perfectionist with a thirst and drive for crazy TR.
SBuger is offline
post #2303 of 2856 Old 05-15-2019, 03:06 AM
Sekosche's Avatar
Quoted: 1370 Post(s)
Liked: 3356
Only $220 and made in the USA? Not bad at all for those specs! Resonant frequency is a bit higher at 31Hz, but I’m sure there’s plenty of headroom for EQing one of these in a BOSS. You buying a pair?
And I’m totally content with my setup. The extra 3 JBL’s will probably sit in storage a while, as the small gain likely isn’t worth a whole new BOSS build to me. I have a decent break coming up and plan to relax and enjoy some content! My system sounds so good to me, there’s just too much work involved for very incremental upgrades at this point; I’ll save anything too extreme for the next house where it’ll have a more permanent residence.
But I hope more people try some huge drivers in a BOSS!
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is online now
post #2304 of 2856 Old 05-15-2019, 05:51 AM
Rowan611's Avatar
Quoted: 602 Post(s)
Liked: 697
Has anybody considered one of Fi’s IB offerings. Since they’re built specifically for IB use I wonder how’d they perform in a BOSS riser?
Looks like the 12” has a similar cutout. With it’s more powerful motor I’m curious if it would be an upgrade over the JBL?
@trhought could you possibly model it?
https://ficaraudio.com/product/ib3-series-ib312-v2/
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS riser | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is offline
post #2305 of 2856 Old 05-15-2019, 06:08 AM
BryceDH's Avatar
Quoted: 173 Post(s)
Liked: 158
@Sekosche , I dug through the thread some and found the post where you mentioned adjusting your peak limiter down to 115w per driver (after using 150w peak for a little bit). Is this still what you are using? I'm driving mine with a 6000dsp and it sounds like you are using 1 of the inuke as well.
More of a question for everyone now...
Do you know if there is any danger in hitting the limiter if there aren't any bad sounds coming from the subs? I'm obviously not going to try to ride the limiter, but wonder if I should be "tickling" it at the most intense bass scenes to maximize the TR. I took some vibsensor measurements and want to get to 1 e01 if possible. This measurement was taken with the peak limiter set to 80w per driver (2 drivers). That is the EOT intro.
Sent from my SM-N960U using Tapatalk
SBuger likes this.
Equipment: Yamaha 3050, Oppo 103d, DIYSG HT12s (L,C,R), PSA mt 110s (SR,SL), 2 VBSS, Submaximus, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is online now
post #2306 of 2856 Old 05-15-2019, 06:22 AM
Sekosche's Avatar
Liked: 3356
I lowered mine to 250 watts total a couple days ago across all three, just to reduce headroom until I add 3/4” ply spacers for fear of them hitting the ground. I ran them at 450w for a bit and didn’t notice any issues at all. You can hit the limiter with no worries. I have 6-12dB headroom before clipping, so the limiter kicks in way before there’s any electrical worries.
If that’s your VibSensor TR with 80w per driver, I wouldn’t expect a 15-20 fold increase in TR (logarithmic scale of 1e-3 to 1e-1), from just upping the power a bit. Still solid TR though, and it seems to mimic the waveform of the EOT intro pretty closely other than the 10Hz drop off, so your TR is pretty balanced. How does it feel to you?
nsiret likes this.
post #2307 of 2856 Old 05-15-2019, 06:22 AM
Rowan611's Avatar
Quoted: 602 Post(s)
Liked: 697
Hitting the limiter shouldn’t hurt the drivers as long as they’re not making any strange noises. You’re better off riding the limiter vs clipping the driver.
Rowan611 is offline
post #2308 of 2856 Old 05-15-2019, 06:37 AM
BryceDH's Avatar
Quoted: 173 Post(s)
Liked: 158
It feels pretty good. I've got cutouts for 4 drivers in my riser but FedEx lost 2 of them so I'm waiting on them to get sent again. My platform is 2 sheets of 3/4" and the drivers are recessed, so I should be good on ground clearance. I'll be interested to see what 2 more drivers and upping the power limit will do. Maybe the 1e01s are from guys with crownsons and stuff too. Not sure if people are getting that with just the BOSS. I'm happy either way for sure though. Definitely a huge upgrade (no comparison to before). There were comments about 1e01 being reference level TR that have me intrigued. If the 4 drivers doesn't do it I'll just sit back and enjoy (as I already have been for the most part).
What are you doing to verify you've got the headroom? Pretty sure I dont have any issues there as I'm only at 1o'clock on the inuke for the boss channel and my Marty's and VBSS are nearly maxed on the gain with no issues for the past year.
@Rowan611 , thanks for your input as well. Good to know.
Also for what it's worth, this is the vibsensor measurement if I bring the gain up to where I'm against the limiter at 80w peak per driver.
post #2309 of 2856 Old 05-15-2019, 07:03 AM
Sekosche's Avatar
Liked: 3356
You can check your signal strength in real time in the iNuke software and compare the clip versus limit.
That’s pretty darn good TR from just two drivers, you’re tickling 1e-2, which is really strong to me, so maybe with two more drivers it will bump you up quite a bit. I’m not good at extracting power levels from drivers to TR, so maybe the more experienced VibSensor users can chime in.
I’m not sure what’s considered reference level TR, but I know 1e-1 is ridiculous amounts of TR and anything more powerful is really too much to me for extended listening sessions, great fun for demos though! I’ve got a chunk of time off coming up, so I’ll try and get some VS measurements of the EOT scene with my 3 driver BOSS with and without MA’s and VNF subs. It is a great clip to use for calibration and seems to be the preferred method in the VS thread, since it’s easy to replicate and read on various systems; but I can’t stand using the intro for anything else.
Here’s a scene from War of the Worlds that’s right in the BOSS wheelhouse for TR and the 30Hz just shreds my body with vibration when reclined, timestamp in the title. Obviously, the major bass scenes in WOTW are all demo material and were really elevated to a whole new level with the BOSS.
SBuger likes this.
post #2310 of 2856 Old 05-15-2019, 07:23 AM
tvuong's Avatar
Liked: 2169
We have to be careful when comparing VS measurements with others as the weigh used on top of the phone makes a big difference in measurement results. I know Sbuger recommends and has been using 5lbs rice bag but I am not certain what Sekosche and others use. We also need to know at what bass levels were the measurements taken? Reference bass, less than reference or above reference bass? These will contribute to the VS measurement results.
SBuger and BryceDH like this.
