The Hideaway Theater - Page 80 - AVS Forum | Home Theater Discussions And Reviews
 2715Likes
post #2371 of 2822 Old 05-17-2019, 12:47 PM
Sekosche's Avatar
Quoted: 1361 Post(s)
Liked: 3333
BOSS 2.0
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is online now
post #2372 of 2822 Old 05-17-2019, 01:06 PM
tvuong's Avatar
Quoted: 2529 Post(s)
Liked: 2138
^^ Looking good. Almost there
tvuong is online now
post #2373 of 2822 Old 05-17-2019, 01:12 PM
Gorilla Killa's Avatar
Quoted: 1320 Post(s)
Liked: 1812
No delay is needed.
Gorilla Killa is online now
post #2374 of 2822 Old 05-17-2019, 01:30 PM
Alan P's Avatar
Quoted: 6137 Post(s)
Liked: 5351
Originally Posted by Kevnmin View Post
How do you guys set time delay for the BOSS? Is a setting the same that would be used for very close NF which would have large delay. Or is it better to set for same as furthest placed sub? I'm sure the answer is a preference thing but it just has me wondering...
If the BOSS behaves like my Crowsons, and I believe it does, you want "0" delay...negative delay would be even better.
Alan P is offline
post #2375 of 2822 Old 05-17-2019, 01:32 PM
BryceDH's Avatar
Quoted: 171 Post(s)
Liked: 154
Running eq (ypao for me) is going to set a delay time for the subs (normal subs, not boss) from what I understand... are you saying you want the BOSS to have 0 delay in relation to the subs, or that it would be good to go into the minidsp 2x4HD and somehow have the BOSS getting its signal prior to the subs in the room?
Sent from my SM-N960U using Tapatalk
Equipment: Yamaha 3050, Oppo 103d, PSA mt 110s (L,C,R), Polk tsi200 (SR/L), 2 VBSS, FullMarty, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is online now
post #2376 of 2822 Old 05-17-2019, 01:48 PM
Alan P's Avatar
Liked: 5351
@aron7awol can explain this negative delay stuff much better than I can. I still have a hard time wrapping my head around it sometimes.
HERE is a good discussion of negative delay where I was finally able to understand what he was trying to tell me!
Kevnmin likes this.
Alan P is offline
post #2377 of 2822 Old 05-17-2019, 01:56 PM
Liked: 1812
You need to think of this in terms of aligning in sync with your mains and not the other subs. Since you have the HD you have the ability to add negative delay. Your signal chain will play a part, more connections will increase the need for a negative delay. Generally you shouldn't need one but it's doesn't hurt to experiment.
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
post #2378 of 2822 Old 05-17-2019, 02:08 PM
Liked: 1812
Originally Posted by Sekosche View Post
BOSS 2.0
Spoiler!
What changed your mind, I thought you were all set?
post #2379 of 2822 Old 05-17-2019, 02:31 PM
BryceDH's Avatar
Quoted: 171 Post(s)
Liked: 154
Ok. In my mind since I have nearfield subs less than a foot behind me I am most concerned with the boss hitting the same time they do. I'm just running the boss off the same input I'm running my nearfield from in the 2x4hd matrix. Ypao set the proper delay for the nearfield with relation to all the speakers. I might play a little and see what happens.
post #2380 of 2822 Old 05-17-2019, 03:43 PM
Quoted: 194 Post(s)
Liked: 89
I'm glad you guys chimed in. My thinking was the less delay or zero delay would make sense as to be timed with the visual que's happening right at the moment of visual que on the screen/tv. I will read the article to help me understand.
Sony 75X940E, Denon X6200w, Sony X700, Roku Ultra, MiniDSP 2x4HD
Parasound (2x)HCA-855a, HCA-750a, Sony ES4300
Mission 705a L&R, dual 70c3 C, 703 SL&SR, 705 BL&BR, (4x)Yamaha NSIC800 Atmos
LFE- Front: M&K MX-200 & MX-150THX; Rear: M&K V-75 & Klipsch RW-12
ULF- 4xJBL Mini-riser BOSS + (2x)Aura AST-2B-4 shakers
Kevnmin is online now
post #2381 of 2822 Old 05-17-2019, 03:59 PM
Alan P's Avatar
Liked: 5351
Basically, you need to add to the sub distance in your AVR (Denon will limit you to only 20' more than your closest speaker) which decreases delay. Then add back the delay to the subs in the MiniDSP.
Say your sub distance is currently set to 15' in your AVR and your closest speaker is 5', you would be able to push the sub distance up to 25' (an additional 10'). Doing so, you just subtracted 11ms of delay (1'=1.1ms). You then add that 11ms of delay to all subs connected to the MiniDSP (re-aligning the subs with the speakers), leaving the BOSS at "0". You just gained an extra 11ms of delay between the subs/speakers and the BOSS. You may or may not need that much, but testing has proven that even that much is not enough.
Kevnmin likes this.
Alan P is offline
post #2382 of 2822 Old 05-17-2019, 04:10 PM
Archaea's Avatar
Quoted: 3750 Post(s)
Liked: 3519
You need to play with it by feel.
I found that adding some delay to the NX3000D in the Behringer DSP GUI made my direct mount hybrid and BOSS platform made feel more closely matched/realistic/accurate to my nearfield sub, where the 18” driver isn’t as close in distance.
Keep in mind that adding “distance” in an AVR (Denon and Marantz and Onkyo) is actually increasing the speed the signal is processed... it’s opposite of what you might originally have thought. IE - If your speaker is 25’ away the receiver needs to process/output the sound more quickly to arrive in sync with a speaker that is 6’ away.
VS. on the Behringer amp DSP, adding delay is actually adding delay. Making the impact / impulse response slower in getting to you.
It plays out like this
Let’s say Audyssey puts my front sub bank at 12’
It puts my rear sub bank at 4.1 foot.
That all feels very much perfect
When I split off my sub 2 nearfield bank to the direct mount BOSS hybrid idea it didn’t feel quite right. Timing (impulse response) felt a bit off.
I turned off my nearfield 18” sub and manually fidgeted with the sub2 distance playing only the Boss direct mount hybrid until I felt like it felt good and accurate to the front sub 1 Bank of subwoofers. That distance setting for sub 2 was about 2.5’
Turn on the nearfield 18” again and boss hybrid both and now the nearfield 18” felt off because with the lesser distance in the AVR they are now firing too late. (In AVR more distance = < delay, less distance = > delay)
This is perceivable with kick drums of beat based music.
So I put my sub2 bank back at the original 4.1 feet which is ideal for the nearfield (but makes BOSS hybrid fire too fast, and in my NX3000D I added a slight ~ 2 foot delay. (Making it > delay for the BOSS Hybrid)
Since my butt is 6” from the direct mount and 2’ from the nearfield it l feels perfect now.
I used generic measurements through all this but you get the idea.
Kevnmin likes this.
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is online now
post #2383 of 2822 Old 05-17-2019, 04:10 PM
Quoted: 194 Post(s)
Liked: 89
Ingenious!!
post #2384 of 2822 Old 05-17-2019, 04:57 PM
Sekosche's Avatar
Liked: 3333
I was totally set, but...
Maybe it was the extra 4th driver I had from the original order that prompted me to order two more a couple weeks later. That and I really needed to add a little more ground clearance as just the isos are not enough. I also built this one so the couch is flush with the front; have already tripped over or into it a few times and don’t want my kids/wife hurting themselves on it. I also blame the ease of building/modifying the BOSS.
And more BOSS is always better, no?! Will be interesting to see how I can dial all six in below 20Hz now that I’m not afraid of too much excursion.
post #2385 of 2822 Old 05-17-2019, 05:46 PM
SteveCallas's Avatar
Quoted: 734 Post(s)
Liked: 662
Originally Posted by tvuong
Isn’t it the only way to feed the boss? Perhaps you meant feeding the boss full range LFE with no LPF?
No. A typical subwoofer is fed with both the LFE signal + redirected bass from the 5, 7, 9, 11, 13, or 15 speaker surround speakers. I am only feeding the BOSS with the LFE channel. LFE can go up to 120hz, I have it lowpassed at 80hz.
SteveCallas is offline
post #2386 of 2822 Old 05-17-2019, 05:56 PM
Sekosche's Avatar
Liked: 3333
Why do you prefer just the LFE signal for the BOSS? Just curious
post #2387 of 2822 Old 05-18-2019, 05:51 AM
lizrussspike's Avatar
Quoted: 1091 Post(s)
Liked: 1610
Out with old and in with new.
eeyoreDK likes this.
lizrussspike is offline
post #2388 of 2822 Old 05-18-2019, 06:02 AM
Quoted: 734 Post(s)
Liked: 662
@Sekosche - if i send all the redirected bass to the boss, i agree with some others that it can be a bit too much, a bit too distracting, and almost mandates the use of a lowpass filter somwhere in the 20-40hz range. Otherwise you are shaking throughout a movie with bass constantly. With just the LFE signal, i can still allow bass up to 80hz (which i like because the higher bass frequencies have a different effect, and i want to experience a range of tactile effects) without it being overwhelming or active ALL the time. The LFE channel is typically active in the most bass heavy scenes, and typically gets the lowest frequency information in it. The redirected bass is typically higher in frequency and is typically more abundant.
Sekosche likes this.
post #2389 of 2822 Old 05-18-2019, 10:19 AM
Longeze's Avatar
Quoted: 17 Post(s)
@TRH ough.. Re: Your comment: "..like bicycle inner tubes specifically. An interesting idea to explore to see what else may be possible, especially if that inner tube can be used for 2 purposes, as skirting to enhance the hovercraft effect and providing the duty of the isolators."
It just dawned on me that you were likely suggesting a concentric arrangement for the inner tubes, with each speaker skirted by its own tube - DUH... I love it!!! Thinking that the using small utillity trailer tire tubes might work best to maximize the effect, by increasing pumping efficiency? Since my couch is on thick carpet, breathing might not be that much of an issue. I've mounted four JBL's under the main part of my sectional... (insert mad scientist maniacal lol here...)
Longeze is offline
post #2390 of 2822 Old 05-18-2019, 10:24 AM
Archaea's Avatar
Liked: 3519
I did some vibrasensor testing between my BOSS mini platform, and my hybrid direct mount, and a control chair.
https://www.avsforum.com/forum/15-ge...l#post58065162
Post 2068.
I also recounted some subjective testing last night with @desertdome , who happened through KC for an AV calibration job today.
I'm still undecided which I like better. But I'd like to finish up all four chairs one way or the other today.
post #2391 of 2822 Old 05-18-2019, 11:03 AM
Sekosche's Avatar
Liked: 3333
Makes sense, my nearfields give me enough up to 100Hz so I’ve been running the MA’s and BOSS much lower, I can’t imagine running an 80Hz LPF on the BOSS! May have to try it just once, but I imagine it’s distracting.
post #2392 of 2822 Old 05-18-2019, 12:09 PM
Archaea's Avatar
Liked: 3519
I made a video of the Hudson HIFI 20 durometer as feet to show a comparison. Between 1) no feet, 2) Hudson HIFI isolators attached to bottom of chair and 3) Boss platform with Hudson HIFI isolators.
https://imgur.com/gallery/CFnsSx4?s=sms
I’m having trouble keeping my chair from sliding around on the mini riser. What adhesive are you guys using?
post #2393 of 2822 Old 05-18-2019, 12:28 PM
Quoted: 184 Post(s)
Liked: 529
My seat has feet and I used small blocks of wood attached to the platform that lock the feet in place.
Electronics: Denon X4400, Vizio M65
Subs: PSA V1811 & PSA V1801
Speakers: 3 x Chane A2.4 LCR, Klipsch Qunitet Surrounds
chucks0 is offline
post #2394 of 2822 Old 05-18-2019, 12:30 PM
BryceDH's Avatar
Quoted: 171 Post(s)
Liked: 154
I did the same...
post #2395 of 2822 Old 05-18-2019, 01:21 PM
tvuong's Avatar
Liked: 2138
I got this but haven’t built my boss to try on yet.
https://www.amazon.com/Gorilla-Heavy...8-5&th=1&psc=1
post #2396 of 2822 Old 05-18-2019, 02:29 PM
Sekosche's Avatar
Liked: 3333
Slap a few silicone isos on your furniture and it won’t budge, even the smaller ones would work, and jiggle, jiggle, jiggle.
post #2397 of 2822 Old 05-18-2019, 08:17 PM
Quoted: 734 Post(s)
Liked: 662
My platform has thick carpet on it, the recliners stay put.
post #2398 of 2822 Old 05-19-2019, 09:05 AM
Nalleh's Avatar
Quoted: 2385 Post(s)
Liked: 3039
This is how it’s done
All that for one seat !
DigiWega, SBuger, trhought and 2 others like this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI-HT18v2 in 2xDO Sonos - 12x12" JBL GT-X1200 NF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873 - Harmony Ultimate.
Nalleh’s HT
Nalleh is online now
post #2399 of 2822 Old 05-19-2019, 09:17 AM
Archaea's Avatar
Liked: 3519
@Nalleh
You are going to hit your head on the ceiling.
Nalleh and brazensol like this.
post #2400 of 2822 Old 05-19-2019, 09:21 AM
Archaea's Avatar
Liked: 3519
I'm going to call Boston Dynamics and tell them I have a new customer for their sand flea...
