Flush mount ceiling tile systems? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-21-2018, 05:53 AM - Thread Starter
Psychoholic's Avatar
So after 15 years of wanting I'm finally starting on my home theater in my basement (build thread will come later, I have been taking some pictures). I'm not doing anything insane for trapping sound but I'm not sure what I want to do with the ceiling.
Most of the wires go through the floor joists overhead (theater is in the basement, 8' ceilings) and I like having access to them so I am heavily leaning on a flush mount ceiling tile setup. I was looking at Ceilingmax with either Certainteed or Armstrong tiles but I was curious if others had other/better ideas?
Chris (Psychoholic)
Psychoholic is offline
post #2 of 4 Old 08-21-2018, 07:34 AM
Waterboy77's Avatar
Quoted: 604 Post(s)
Liked: 315
Not sure if its a better idea but I used SNAP CLIP for my basement ceiling and have received a lot of compliments on how it looks from friends and family.
Its super easy to install and low profile....there are pictures in my build thread
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is offline
post #3 of 4 Old 08-21-2018, 12:00 PM - Thread Starter
Wow, that does look good!
Is that Roxul above it for sound deadening?
post #4 of 4 Old 08-21-2018, 03:55 PM
Waterboy77's Avatar
Quoted: 604 Post(s)
Liked: 315
Yes it is and I also did a couple layers of drywall and green glue above the theater area
Family Cave Theater
