For those that have walls built on clips & hat channel - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BIGmouthinDC
post #1 of 16 Old 10-05-2018, 10:42 PM - Thread Starter
Quoted: 67 Post(s)
Liked: 4
For you guys who have walls built with clips, hat channel and/or at least 2 sheets of drywall, how exactly do you secure anything to the walls?
I neglected to realize that in building the above wall system, there is a void cavity which will not securely allow fastening of most anything. Sure, you can use common drywall anchors, but I've never liked using them even for smaller items such as picture frames, let alone possible 20 pound speakers. Maybe there's a more substantial, quality anchor that I am not aware of...
I'd be interested to learn how you secured wall-mounted speakers or anything else of substantial weight to this kind of wall system without hitting a stud and short circuiting everything.
matpal is offline
post #2 of 16 Old 10-06-2018, 01:50 AM
Quoted: 6161 Post(s)
Liked: 5830
Molding, you use liquid nails and finish nails into the drywall
You can anchor the outside bottom edge of a soffit to furring that is glued and screwed to drywall edge.
Columns are anchored to furring that is glued and screwed to the drywall,
Acoustic treatment furring or fabric track can be glued and construction stapled to the walls, you can screw but a construction staple gun is faster.
What else you got?
tarponater likes this.
post #3 of 16 Old 10-06-2018, 01:55 AM
James92TSi's Avatar
Quoted: 136 Post(s)
Liked: 453
I didn't personally build on clips/channel/DD/GG, but I see a lot of guys use OSB as the first layer, instead of drywall, in areas where they anticipate hanging items. Not so helpful if you've already closed your walls.
A tip I saw from @BIGmouthinDC in the Beast Unleashed build involves marking a stick (held vertically) for all of the clip/channel heights around the room. You then use that stick to mark your studs for clip locations, and during drywall installation you can use the stick as a reference so you screw into the channel consistently since it's hidden by the drywall you're hanging.
The same could be applied for hitting the channel with longer screws after the fact for hanging items. But I am not so sure about hanging 20lb speakers from the channel; just not that familiar with its capacity since I haven't used it.
James
Long-time AVS reader, finally building a small dedicated room.
McTheatre II Build Thread
James92TSi is offline
post #4 of 16 Old 10-06-2018, 05:44 AM
Liked: 5830
A lot of time speakers go in columns so you just have a shelf. OSB as a first layer is a good idea if you need to hang naked speakers in your theater, If doesn't have to be the entire room just the speaker locations, and you could do just a 2 ft wide strip floor to ceiling if you planned it out properly. I just hate working with OSB versus drywall, Takes longer to cut. And, then there are the splinters.
Depending on your room finishing plans there may be an opportunity to build in recessed backer boxes to hold the speaker or a 3/4 thick plywood mounting plate glued and screwed to the surface of the drywall. You would hide it behind the wall treatments.
ID:	2464594   Click image for larger version
ID:	2464596   Click image for larger version
post #5 of 16 Old 10-06-2018, 06:52 AM - Thread Starter
Quoted: 67 Post(s)
Liked: 4
What else you got?
Thanks but I'm not quite sure I follow. I'm basically worried about speaker mounting. As the mounts have a fairly small surface area that actually touch the wall, all you saying put that small attachment point on a larger plate and then essentially gluing that to the wall?
matpal is offline
post #6 of 16 Old 10-06-2018, 06:56 AM - Thread Starter
Quoted: 67 Post(s)
Liked: 4
Wow, that looks amazing!
matpal is offline
post #7 of 16 Old 10-06-2018, 06:59 AM - Thread Starter
Quoted: 67 Post(s)
Liked: 4
I thought about the OSB but obviously it will be harder to work with and I am not sure if i would be sacrificing some of the acoustical properties over 2 sheets of drywall.
matpal is offline
post #8 of 16 Old 10-06-2018, 09:03 AM
Liked: 5830
yes, glue and screw. If you are doing fabric covered walls with 1-2 inch of various acoustical treatment. It is easy to hide various mounting plates that you attach to the surface of the drywall. It could even extend to the floor to help hold the weight of something really heavy. Found a picture from my project file of naked speakers on all dressed walls. You don't see the mounting plates. From this project: https://www.avsforum.com/forum/19-de...#post_20683383
post #9 of 16 Old 10-06-2018, 09:35 AM
brazensol's Avatar
Quoted: 804 Post(s)
Liked: 643
I have been using these style drywall anchors lately and really like them. I get mine at Lowe's.
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP; (2) iNuke NX3000D; (3) HTM-12; (14) RSL C34e surrounds; (2) 18" DA RSS460HO-4 Subwoofers; (1) DA UM18-22 18" Ultimax Subwoofer; (4) DA RSS390HO-4 15" Reference HO Subwoofers; BOSS Platform - (12) 12" Subwoofers
brazensol is offline
post #10 of 16 Old 10-06-2018, 10:29 AM - Thread Starter
Quoted: 67 Post(s)
Liked: 4
That is amazing, thank you. So your room is only 15ft wide? And your furniture selection from the linked thread would be about 12ft? That looks like a lot more than 1.5ft on either side of the chairs.
I make this comment because this was also a concern of mine and the room restraints due to illogical placement of basement support pillars.
matpal is offline
post #11 of 16 Old 10-06-2018, 10:40 AM
Liked: 5830
I don't remember the dimensions, not my room, a clients.
The palliser HiFi in the 4 across middle loveseat is 9ft 8in wide. not 12ft
post #12 of 16 Old 10-14-2018, 06:31 PM
deauxt's Avatar
Quoted: 38 Post(s)
Liked: 30
Jeff, from which theater were these photos taken? Did they do a build thread?
deauxt is offline
post #13 of 16 Old 10-14-2018, 06:39 PM
Liked: 5830
the speakers recessed in the wall are from the Rawlinsway, the staggered wall panels are from, Staggered wall. both linked in my signature,
post #14 of 16 Old 10-14-2018, 07:06 PM
deauxt's Avatar
Quoted: 38 Post(s)
Liked: 30
Thank you, sir!
deauxt is offline
post #15 of 16 Old 10-18-2018, 09:19 AM
tarponater's Avatar
Quoted: 164 Post(s)
Liked: 663
You can secure most molding directly to drywall with a crown molding nailer and liquid nails. Just drive two nails at 45 degrees in an "X" pattern every 12" or so. They will hold the molding against the wall till the glue dries.
JVC RS-540, Sony UBP-X800, Onkyo TX-RZ730 (7.2.4), Onkyo M-5010, Elite Screens 100" 16:9 (Spandex AT DIY)
DIYSG 1099 LCR, Polk TSX-150C (DIY) Atmos, Yamaha NS333 Surround & Surround Back
Triple HS-24 mkiii 11cuft sealed, Behringer NU-12000, Crown XLS-2502, MINIDSP 2X4
tarponater is online now
post #16 of 16 Old 10-18-2018, 10:14 AM
Liked: 5830
depending on the molding I often just use 23 ga finish nails (slightly headed pins) which disappear after painting. No filling, sanding required. That is all you need to hold it in place for the glue to dry.
