New HT oom with wet bar - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1 of 31 Old 10-22-2018, 05:19 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Sophisticated Den - New HT room with wet bar
AVS Post
Hi everyone,
Newbie here. Long time theatre admirer, and finally getting a chance to build one. Overall room size 22’-3”W x 8’-6”H x 15’-2”D. This is going to be a new media room and entertainment room for my wife and I and friends/family. We do not have any children.
A few existing conditions that I cannot get rid of:
- Existing tile floor over infloor heating. (yes, I know, far from ideal, but too expensive to rip out).
- Wet bar plumbing rough-ins are to be reuse, (see drawing).
Overall intent:
- This is our only TV in our house and we will be getting a new 75” QLED TV.
- New raised platform with a reclining loveseat and will be built as noted per drawing below.
- To creat a mid-budget theatre
- Budget $15,000cdn
- As I am in the design industry my dollar goes farther:-)
- Not looking for the best but looking for value and something we won’t regret in a month.
Existing Equipment:
- TV, 55" 4K: Samsung UN55KU7000F (For the time being)
- Receiver: Yamaha RX-V581
- Sub: Sony SA-WMSP87
- Blu-Ray: Samsung BD-J6300 (for the time being)
- Front Speakers: Pioneer SP-FS52
Proposed New Equipment:
- New 75” QLED TV, specs to be confirmed
- New 4k Blu-Ray, specs to be confirmed
- New Subwoofer: SVS PB-1000 (1 for now, will get a second one to replace the Sony sub in the future)
- Heigh Speakers: SVS Prime Elevation
- Centre Channel Speaker: Philharmonic Audio MTM center channel
- Rear surround: Pioneer SP-BS22-LR
QUESTIONS/ASSISTANCE NEEDED:
1. We are going to do Atmos 5.1.2 using existing fronts and receiver. With our love seat at the back wall, and based on our specific layout, would you use rear mounted surrounds or side mounted? Also when you have 2 tiered seating do you base height of the rears on the back higher tier or an average?
2. Feeling like SVS Prime Elevation mounted to ceiling would be our best bet for Atmos speakers. Should they be placed half way between the front and rear seats?
3. What are some brands of cheap 2” acoustic foam I can put behind our drapes? We need about 200 sq.ft. To do the rear and left wall behind the drapes.
4. Our ceiling is existing drywall. Would you add acoustic panels to the ceiling?
5. While we will try and cover the majority of the floor in the seating area with carpet and rugs, there will still be some exposed stone floor and the stone floor in the wet bar area is staying (wife won’t let that be covered, lol). Anything else I can do to mitigate reflection?
Thank you in advance!
ID:	2472036   Click image for larger version
ID:	2472038   Click image for larger version
phanttom is offline
post #2 of 31 Old 10-23-2018, 04:35 AM
Tedd's Avatar
Quoted: 2293 Post(s)
Liked: 985
First off, I would consider rotating the room, so there would be a symmetrical front, with reflective side walls.
I would suggest that 2" of foam and drapes are going to suck out the high frequencies in your room.
The floor will be reflective, but a large area rug could help, yet still show off some of the floor.
If there's ever to be a projector in the room, you could employ DIY AT screen materials later, and simply use inexpensive
speaker grill fabric to cover in the AT space, and two 2x4" to support the hdtv in the meantime.
Tedd is offline
post #3 of 31 Old 10-23-2018, 05:08 AM
Quoted: 191 Post(s)
Liked: 287
Have to agree with Tedd. Flip the room and it gives you a better wall for TV. Also a room with a 75tv is not a HT. At least 110in is my limit. Also you do not need a riser and 2nd row for a 75in flat screen' unless those seats come with binoculars. Could be a great room though.
gibson61 is offline
post #4 of 31 Old 10-23-2018, 05:28 AM
Quoted: 6672 Post(s)
Liked: 6555
welcome Phanttom, by now you realize this is a tough crowd. You are trying to fit a lot in a small space, with seating for 8 adults don't overlook the need to beef up your air conditioning and fresh air supply for this room.
post #5 of 31 Old 10-23-2018, 05:48 AM
Tedd's Avatar
Liked: 985
I wish that "tough crowd" had saved me from some "been there, done that" mistakes, and
shaved a remodel or two, off my home theater learning curve.
In that light, it's never a bad idea to bounce alternative ideas to someone. In my experience,
they often simply are stepping stones to an even better idea.
Forgot to add my quickie diagram...
Tedd is offline
post #6 of 31 Old 10-23-2018, 09:14 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Thank you everyone. For now based on budget we will just be doing the TV. I know for some that may not be big enough:-). Ironically the room was roughed-in for the screen/TV to be like Tedd showed. But when my wife and her first husband did rough-ins they didn’t do a seating plan. I first laid out the room as did Tedd for the same reasons, but for functionality my wife didn’t like walking into the side of a sofa/riser.
We like the roser idea as the back row will be power reclining we want to be high enough to miss the heads of people in front.
As such I think the layout might have to be like that but will see if my wife will reconsider orientation.
@BIGmouthinDC , thanks for the comment on AC. Right now our basement is super cold all year round as we have in floor heating and cooling so we hope that will be sufficient. Living in Northern Alberta has its pluses. Lol.
@Tedd , thx for the feedback on the acoustics. We will try just the area rug as planned and drapes for the feel but will delete foam. We can always add the foam in the future. Would you still add a couple of acoustic ceiling panels or keep the drywall?
Also how do I determine best location for the SVS height speakers that will be mounted on the ceiling between first and 2nd row? Half way in between?
Build Thread:https://www.avsforum.com/forum/19-de...m-wet-bar.html
Theatre Room: Samsung UN55KU7000F | Pioneer SP-FS52 x 2 | Polk MC80 x 2
Epson 5040UB | 120" Elunevision 4K Reference Tab 2.35:1 | Philharmonic Audio Affordable Accuracy Center Channel
phanttom is offline
post #7 of 31 Old 10-23-2018, 02:43 PM
Tedd's Avatar
Liked: 985
There's more feedback on having a symmetrical front with reflective side walls. Sound pans rely on this,
and all three front speakers with that layout will sound slightly different. We rely on reflective sound to
place spatial clues, and the Mrs with her superior hearing, is actually far more likely to notice this.
You also are not considering 450+ watts per seated body/hr + projector heat + electronics heat. I've been in a
few home theaters over the years where the air has been overwhelmed.
If you do a big screen, nobody is going to notice the seating, when entering. Their eyes are going to be drawn
to the screen right away.
I would treat the first reflection points, but with your proposed layout, there's no side wall there, to treat.
Tedd is offline
post #8 of 31 Old 10-23-2018, 03:17 PM
Liked: 6555
I see a popcorn machine in the layout, I have one and I kick myself every-time I use it in a room much larger than yours that I didn't install a ceiling kitchen exhaust fan directly over it. I open a window. I see you have one. You will also need that in the winter to cool the room when you fill all your seats.
post #9 of 31 Old 10-23-2018, 05:39 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Great point...COmmercially we always do, but wasn't even thinking about my own house...lol. Might rethink that one, or use one that does air pop. Kitchen is only 1 floor above
phanttom is offline
post #10 of 31 Old 10-23-2018, 05:44 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
We looked at layout again tonight and while we totally get the symmetrical requirements for the perfect system, maybe my thread should be elsewhere on the site as we also want to entertain a bit. WE would use it daily as our TV/Theatre room, but when friends come over, move downstairs and have our liquor kept there. As such, if we rotate it 90 degrees, the whole back area truly gets eaten up (partially due to the existing column in the way which we are not in the position to relocate as it's one of the few columns in the basement (pretty open basement otherwise). So we will have to sacrifice symmetry for part of our programming needs of the space.
HVAC we will review further with one of my Mech. Engineers I work with and a tin basher we know. I'm told they did some rough-ins but need to find it first.
I appreciate the feedback!
phanttom is offline
post #11 of 31 Old 10-28-2018, 04:20 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
So, we have finalized our layout after reviewing the layout again. While we know that turning the room 90 degrees would be ideal for sound, the room just wouldn't function the way we want unless we deleted the riser which we don't want with having reclining seats/loveseat at the back.
So now, i'm struggling/confused by TV placement, angle & height. I hope someone can dumb it down for me. Below is a copy of our elevation/section of the space.
Final Layout:
Name:	Theatre Design Drawings Option 1e - 2018-10-28.jpg
Side Elevation/Section
Name:	Theatre Design Drawings SIDE ELEVATION - 2018-10-28.jpg
phanttom is offline
post #12 of 31 Old 11-04-2018, 04:06 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Well the build started yesterday. Between yesterday and today got the raised platform built and the wall to the bar area.
Platform is built with 2x10’s. They were supposed to be 2x12’s but Home Depot delivered the wrong items. Made do and put a 2x4 on side below to make up the difference.
Laid 15lb roofing felt between existing tile floor and platform. 2x6’s with joist hangers at 16” centres and a central cripple for each joist.
Cavity filled with 3 layers of R12 batt insulation.
3/4” t&g ply on top glued with PL400 and screwed at 8-12” centers depending on location.
Wall was built with 2x6’s and 1/2” MDF on both sides. Reduced need to tape and mud GWB. Wall was anchored to the side of the platform with twenty 3/8” x 3” lag bolts before the other side of MDF was installed.
Nosing extends past riser by 1.5” to conceal new RGB strip lights with metal channel.
Next weekend might be the wet bar and repaint. Maybe even carpet tile if it arrives from Tandus.
ID:	2478014   Click image for larger version
ID:	2478016   Click image for larger version
ID:	2478018   Click image for larger version
ID:	2478022   Click image for larger version
ID:	2478026   Click image for larger version
ID:	2478028   Click image for larger version
ID:	2478030   Click image for larger version
ID:	2478032   Click image for larger version
ID:	2478038   Click image for larger version
phanttom is offline
post #13 of 31 Old 11-12-2018, 09:40 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Weekend 2 done. Got the entire basement painted. Used Dulux Ultra Flat, Colour: Improbable #DLX1011 .5
Tandus carpet tile started with rubber backing.
I need some screen/projector advice too, please see thread here: https://www.avsforum.com/forum/68-di...92-screen.html
CMonster and Oklahomie like this.
phanttom is offline
post #14 of 31 Old 11-17-2018, 01:26 PM
Quoted: 13 Post(s)
Liked: 0
Cool to see another Edmontonian on here! Following the thread.
Love the look and colour on the walls. Are you keeping the mirror on the wall? Seems like that will be tough for sound reflections and light reflections if you decide on a projector.
iamtaylorsmith is offline
post #15 of 31 Old 11-17-2018, 07:54 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Hey. Nice to meet you. That mirror is getting covered with some acoustical material and drapes. We kept it in case we wver convert it back to a gym ( doubtful, as the other gym is still on the other side).
phanttom is offline
post #16 of 31 Old 11-19-2018, 08:25 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
- Carpet 95% done. Ran out so Tandus is sending me more. Should be here for end of week. Just 4 more squares.
- Room painted. Colour: Improbable by Dulux using Ultra Flat paint.
- Bar cabinet install started. Templating for Hanstone starts Wednesday.
- Order for new Elunevision screen goes in this week along with new Theatre seats.
- Ikea tomorrow night for blackout drapes and rest of cabinets including CD storage and more.
- Waiting for invoice from Philharmonic Audio for my new modified Pioneer Centre.
- Probably get the Monitor Audio Brinze Fx and C165 ceiling speakers for Atmos this week if my local AD has a Black Friday week sale on.
- Waiting for Lutron Caseta in Black to come in from my Lutron rep and new Diffusion Lighting led strip lights for the risers.
- Final electrical to be first part of December.
- projector to be ordered for arrival before holidays.
ID:	2485140   Click image for larger version
ID:	2485142   Click image for larger version
ID:	2485144   Click image for larger version
phanttom is offline
post #17 of 31 Old 11-20-2018, 03:48 PM
Quoted: 36 Post(s)
Making good progress
winty82 is offline
post #18 of 31 Old 11-24-2018, 11:49 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Spent the last week finalizing Ikea cabinet setup. Used Sektion for the wet bar lowers and Besta for the uppers. It was interesting mounting the Besta uppers as we did many pilot holes after hitting a water line beside a stud last week Fix was easy with a Shark Bite, but still sucked. Been a bit paranoid since about hitting another water line as the wet bar wall backs onto the basement washroom with shower. So tonight we did pilot holes and decided for all but 1 location where we knew for sure there was a stud, to use snap toggle bolts. Used a 1/2" spade bit to drill the holes but would only let the tip to through the drywall, then used a small screwdriver to probe. Glad we did that because at one area, there was some weird metal objet behind (see photo with 3 holes). So we dropped it 1" and were fine.
Also mounted Besta to our side walls with doors for DVD/Blu-Ray storage...Looks great. Quartz counters were templated yesterday by FloForm. Going with Hanstone, Sterling Grey.
Ordered Polk MC80 for the in-ceiling Atmos speakers today for a great deal.
Next up:
- Install metal stair nosings & LED tread lights
- Install blackout drapes on back wall where window is & side wall where mirrors are. Using Ikea Majgull blackout drapes in grey.
- Have electrician run power for projector & screen, add (2) Cat6 lines, change out all plugs for black, install black Lutron Caseta switches
- Finish plumbing once counters are in.
- Install projector (JVC DLA-X590RB) & screen (Elunevision, 120" 4K Reference Tab Tension 2.35:1)
- Install Theater One Seating, Helios black seats at back row. Doing 2 chairs now, will expand to 4 next year.
- Order and install (2) Wine fridges in wet bar.
- Miscellaneous Decor
- DONE! (for now)
phanttom is offline
post #19 of 31 Old 11-25-2018, 12:07 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Thanks! Been spending 80% of my weekends and some week nights with my wife. Would like to be 70% done by Christmas.
phanttom is offline
post #20 of 31 Old 11-25-2018, 09:30 AM
Quoted: 13 Post(s)
Liked: 0
Next up:
- DONE! (for now)
Attachment 2487042
Attachment 2487044
Attachment 2487046
Attachment 2487048
It's looking great down there. Love the lego collection.
Have you used Caseta switches before? I'm looking to upgrade to smart lighting, and the Caseta line seems like the best way to go.
post #21 of 31 Old 11-25-2018, 07:44 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Thanks! Yeah a bit of lego is always needed.
As for Casseta, I have some experience with it as a commercial interior designer. I just had a seminar with a Lutron rep, a Lutron 5-star dealer, an electrician and an electrical engineer. Lutron is my go to for dimmers in general. I feel the Lutron is an amazing value system with their app for retrofit applications. They can do larger commercial systems too with other systems. Casseta is their entry system, but is great. Unlike many other systems, if the hub goes down, the switch still works as a regular switch. Through a Lutron dealer you can also get black switches. Most box stores only do white.
The lamp module is great, BUT you cannot use the lamp module for equipment. For that I use WEMO to turn on our Rocket Espresso machine to warm up the boiler.
phanttom is offline
post #22 of 31 Old 11-28-2018, 12:22 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Spent the evening last night installing nosing on the riser (pictures to come).
Wanted to say thanks to @Tedd for his assistance. I got a 32" 720p TV from Superstore for $100cdn. Have converted it into a digital movie poster! I have created my own template in photoshop for 1080x1920 pixels. LOVING IT!
Now to design the shroud and have it fabricated.
Attachment 2488402
Tedd likes this.
phanttom is offline
post #23 of 31 Old 11-28-2018, 10:13 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Got a great deal on Hue Striplights today: 80" + 40" extension for $100cdn from Best Buy. So i got 2 sets + a bridge for $280'ish with tax (cdn). Ran 1 @ 80" + 2 @ 40" for the stairs, then used the other 80" on it's own under the bar cabinets.
Installed the new 32" 768p Westinghouse TV in portrait mode on the wall. Used the Peerlees PRMF2X2 mount for $18cdn from Visions!!!!! It is now our movie poster display. Will get a custom shroud made. The USB interface is simple, BUT the slideshow it doesn't turn on automatically when the TV comes on. Might look at a cheap Raspberry or something to connect to the TV, that might be better. NOTE: While the VESA 200x200 works either landscape or portrait for the mount, when you actually rotate it 90 degrees into portrait, the bracket on the TV doesn't slide down into the wall bracket. As such I could only use 3 of 4 VESA screws on the TV, but it weights nothing so i'm not too concerned.).
Link to mount: https://www.visions.ca/Catalogue/Cat...83&sku=PRMF2X2
Updated photos from today.
phanttom is offline
post #24 of 31 Old 12-14-2018, 11:47 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
So after 6 weeks, 100% of construction is done. Lutron black caseta dimmers and hue strip lights installed. Ikea blackout drapes installed. Bar 100% done with new Hanstone Sterling Grey quartz tops. Cabinets are a combination of Sektion lower & Besta uppers.
Left to do
- Install Atmos Speakers (Polk MC80)
- Install power for projector & screen + install Ruipro HDMi cable & Cat 6 lines
- Order & install MA Bronze FX Rears
- Order & install Screen, Elunevision 2.35:1 motorized tab tension
- Order & install projector: still deciding between JVC DLA-X590RB & Epson 4050 (need to see my final budget)
- Order & Install theatre seats, Theatre One Seating, Helios
- Build decorative frame around digital movie poster
- Wall posters/pictures on front wall on each side of TV
- Order two new wine fridges for under bar.
iamtaylorsmith likes this.
phanttom is offline
post #25 of 31 Old 04-10-2019, 09:07 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Been a while since I posted. Just got 2 new Theater One Helios seats. So far amazing. Super comfy, lots of adjustability and more. Only downside is the cup holders. The bottom has the illuminated ring but it’s not flat. Makes putting cups/glasses in there awkward. Ok going to have a custom piece of frosted acrylic cut to fit in there.
Also got a new 120” 2.35:1 EluneVision motorized tab-tensioned screen. Hope to get that installed in 1-2 weeks.
ID:	2551532   Click image for larger version
ID:	2551534   Click image for larger version
ID:	2551536   Click image for larger version
ID:	2551538   Click image for larger version
phanttom is offline
post #26 of 31 Old 04-28-2019, 10:21 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
New HT Room with wet bar
Got my new EluneVision Reference 4K tab tensioned screen up yesterday!!!! 120”, 2.35:1. So for loving it. Using my old Epson EX 7235 projector for now until I order a 4050.
ID:	2559432   Click image for larger version
ID:	2559434   Click image for larger version
ID:	2559436   Click image for larger version
phanttom is offline
post #27 of 31 Old 07-06-2019, 10:24 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
A July 6, 2019 update:
- Refurb Epson 5040ub installed using a Peerless Prg-Unv mount. I Flude and screwed a 3/4” piece of mdf perpendicular to my ceiling joists then used two 1/4” snap toggle bolts to mount the projector.
- old Epson Ex7235 to be removed tomorrow
Next to do:
- have custom brass screens cnc’d to install on front wall.
- select & order a new sub
ID:	2588404   Click image for larger version
ID:	2588406   Click image for larger version
ID:	2588408   Click image for larger version
phanttom is offline
post #28 of 31 Old 12-29-2019, 09:04 PM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Been a few months, little things have been updated.
NEWLY DONE
- Old projector removed
- Potlight trims & ceiling Atmos speakers painted black
- New built-in Danby wine fridge installed
- Welcome trailer created as a YT video (will eventually get a Plex Server setup)
- Area rug below sofa installed
- Side tables for sofa installed
INCOMING/ORDERED
- Beverage fridge with freezer for bar (wine fridge will remain)
- Samples of wallcovering for feature wall behind motorized projector
- AS Hanging system to hang some B&W travel photography my wife and I have taken on our world travels. These are framed in Gold frames to give the 1920’s theme
OUTSTSTANDING
- Order 2 more Valencia seats
- patch & repair minor holes in ceiling where old projector was
- Order 4K UHD Blu-ray player
- Order 4K HDMI RuiPro Cable
- Order 4K Apple TV
- Order new 12” Sub
- Design & Order shroud around Digital Poster TV
Hope to be 100% done by April (except maybe the 2 other seats).
Name:	T&H Cinemas Startup Image_edited-1.jpg
ID:	2660976   Click image for larger version
ID:	2660978   Click image for larger version
ID:	2660980   Click image for larger version
ID:	2660982   Click image for larger version
phanttom is offline
post #29 of 31 Old 12-30-2019, 02:19 AM
Luddy111dog's Avatar
Quoted: 46 Post(s)
Liked: 143
Hi phanttom.
For what size room you've got and "Wife Rules" that had to be obeyed to keep the peace.....I think you've done a mickey mouse job.
Pat on the back from Queensland Australia. & Happy New Year ;-)
Luddy111dog is offline
post #30 of 31 Old 12-30-2019, 08:15 AM - Thread Starter
Quoted: 76 Post(s)
Liked: 25
Originally Posted by Luddy111dog View Post
Hi phanttom.
Sometimes things can be lost in translation but on one hand you said "mickey mouse job", and on the other hand "pat on the back". Just wanted to clarify which it was...in the end, we are happy with it and while ther eis always perfect, the balance is the important part.
Cheers.
phanttom is offline
