Mini 7.2.4 Home Cinema (smallest ever?) - Updated to v1.1
The Mini Cinema has received a few updates to bring it to v1.1
First, some pictures:
Higher quality ones available here on Flickr
I should note that the room in real life is a lot darker than this, but if I shot it how it actually looks, you wouldn't be able to see anything
So, the changes...
1) I changed the rear surrounds from XTZ S2s to S5s, so now all the surrounds are the same. The "tripole" effect of the S5s gives a larger soundstage behind me, making the speaker location less obvious
2) The TV has been brought forward slightly so it's flush with the front of the speakers. This has allowed the bias light to diffuse a bit more, has mostly hidden the trunking to the L/R speakers, and has slightly increased the perceived image size
(I think it's about 1.4m (4'7") from eyes to screen now).
I should also note that although the bias lights still turn on/off automatically, I now leave them on during playback, but can turn them off with one button if I want that pure darkness
3) Probably the biggest (yet completely hidden) change is the addition of a "BOSS Platform". This might replace the Buttkicker LFEs, or compliment them, I'm undecided on that yet. But the hype is certainly real! When testing its limits, I managed to get to the point where my vision had become blurred and I was struggling to get the mouse back to where it needed to be to turn it back down!
Here's a photo of the underside:
It looks intimidating but it's very simple to build and setup
4) I've swapped out the MiniDSP 2x4 Balanced for a MiniDSP 2x4HD, for various frivolous reasons
5) I've moved the HTPC into a different case (Fractal Define Mini C) which is now located next to the rack instead
6) I changed the Buttkicker BKA1000-N amp to a Behringer NX3000D as I needed an extra channel for the BOSS Platform
7) And most importantly, I changed the insides of the cushions from the crap ones they came with
The only thing left to add is acoustic treatments... someday...
Original post here:
So, the changes...
Original post here:
So I'm thinking I may have built the smallest ever "full Atmos" setup, at just 3.3*2.5m (10.8*8.2ft) 😁
- the room is approx 600ft³
Here's a 3D mockup. My goal was to have a dedicated room with a layout as close as possible to Dolby guidelines, and I pretty much nailed it (to the mm 😋
And here's the final result:
Uncompressed images available here
TV: LG OLED 65" B7 (1.5m [4.9ft] from eyes to screen!)
HTPC: i5-6600K, 8GB DDR4, GTX1070, 2x 256GB SSD, GA-Z170X-Gaming7, Silverstone GD09, Noctua fans
Speakers
LCR: XTZ Cinema M6
Side Surrounds: XTZ Cinema S5
Rear Surrounds + Atmos: XTZ Cinema S2
Subs: 2x DIY 15" 'Fi Audio SP415' sealed down-firing cubes
Other: 2x Buttkicker LFE
Amps
AVR: NAD T758v3 (with Dirac Live)
Power Amp: Arcam P-1000 (powering LCR + Atmos)
Sub amps: 2x Citronic PLX3600 (dual 2ohm)
Other: Buttkicker BKA1000-N
Bass management is handled by a MiniDSP 2x4, with a chunky house curve applied to the Buttkickers - which are located in the sofa, one inside each armrest, which was serendipitous that they fit there 😁
- I suppose it's 7.4.4 if you include them in the sub count
I got sick of putting discs in/loading times/menus etc so I ripped all of my DVDs/Blu-Rays to my NAS, which I play back locally on the HTPC using Kodi DSPlayer (which supports madVR + LAV filters)
The Bias Lighting is the MediaLight Quad
Funnily enough, whilst Bias Lighting was great with my old Plasma setup, I actually perfer it off when viewing my OLED, as there's nothing quite like having the room plunge into absolute darkness. And I don't appear to suffer from eye strain without it.
So what I've done instead is to have them automatically turn on/off when media is playing, paused, etc using a WiFi LED controller + some scripting
Wallpaper is from here
The paint was a custom mix, for which I got the info from here - the aim was to get a neutral grey as not to alter colour perception
This is only Phase 1 of my project - I plan on adding room treatment in Phase 2
Speakers
LCR: XTZ Cinema M6
Amps
