Terminating 1.5" conduit in the room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-24-2018, 06:16 AM - Thread Starter
elitemikes's Avatar
Quoted: 44 Post(s)
I'll have 3 conduit runs coming into the room. The projector will be coming right through the ceiling. Is it okay to just seal this one up tightly at the hole or will i want to build some kind of a box around it.
The other 2 will be ended at the walls, but coming from the ceiling, I'm assuming with these ones, I have no choice but to build a box. I never found anything good sold for 1.5" to terminate into a nice thick plastic junction box.
elitemikes is offline
post #2 of 2 Old 11-24-2018, 10:00 AM
Quoted: 5966 Post(s)
Liked: 5538
If you like nice thick junction boxes, buy them and drill holes for the conduit. You can mate the conduit to the box with a terminal adapter.
https://www.platt.com/platt-electric...&SubCatID=2103
