STEVE'S - D.I.Y. Home Theatre - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 110Likes
post #61 of 143 Old 08-09-2019, 06:53 AM - Thread Starter
Luddy111dog's Avatar
Quoted: 41 Post(s)
Liked: 130
I then glued a "Right-Angled-piece" of wood above that routered piece which will go around "3/4's of the room" & hide a RGB strip.
ID:	2600904   Click image for larger version
ID:	2600906   Click image for larger version
ID:	2600908   Click image for larger version
ID:	2600910   Click image for larger version
pkinneb likes this.
Luddy111dog is offline
post #62 of 143 Old 08-09-2019, 07:05 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
I then sealed all GAPS in the room that took around a days work. IMO, without doing this, no matter how good the wood is, it will always look 2nd rate.
ID:	2600914   Click image for larger version
ID:	2600916   Click image for larger version
ID:	2600918   Click image for larger version
ID:	2600920   Click image for larger version
ID:	2600924   Click image for larger version
jokerrn and pkinneb like this.
post #63 of 143 Old 08-09-2019, 07:14 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Then all day today, I spent on TAPING-UP getting ready for a day of SPRAY-PAINTING undercoat tomorrow.
ID:	2600928   Click image for larger version
ID:	2600930   Click image for larger version
ID:	2600932   Click image for larger version
ID:	2600934   Click image for larger version
pkinneb likes this.
post #64 of 143 Old 08-09-2019, 08:26 AM
Quoted: 234 Post(s)
Liked: 731
Looks awesome!! What did you seal the gaps with?
My Theater Build - Full Circle Cinema
pkinneb is online now
post #65 of 143 Old 08-09-2019, 04:54 PM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Only the best. In aussieland, it's called "Sikaflex® 11FC".
It's not cheap but it's very versatile & will never shrink. It has a permanent elasticity & sticks like sh1t to a blanket.
It's easy to work with. I was using it for years in the automotive trade. Wouldn't use anything else.
What I do though, so not to waste this stuff is cut the nozzle as small as possible. I then whined a GOOD 2-inch paper tape around the end of the nozzle which overlaps the end of the nuzzle by 1/4 of an inch, making sure it's well secured so it doesn't come off, leaving a small pointy end. I then cut a "45-degree angle", right at the end of the tape. By doing this, you can then direct the Sikaflex right into those small, sharp corners with no waste of product. Then simply run your finger along the edge, directing all the sikaflex into the cracks. Then run a clean rag along the edge, trying not to disturb what you've just perfectly done but to simply clean up anything you may have missed.
The "Tape procedure"...you may have to repeat this 5 or 6 times over the period of the day, but it's well worth doing once you've perfected it.
pkinneb likes this.
post #66 of 143 Old 08-10-2019, 05:36 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Undercoated
Well after 4 or 5 hours on the "GUN", the undercoat is done.
My best Spray-gun decided to pack it in, so its either time for some new seals or some minor teaks. Hope its the latter.
Pulled out my 2nd best gun & it went like a dream...........after an hour of frustration with the faulty one.
Used about 12 litres of undercoat....but thank god it's done.
I'll let the undercoat sit for a couple of days before I give it a scuff with 180 grit, then I'll be back on the gun next week.
There's a few "Gaps" that I've missed here & there, so I'll get another tube of Sikaflex & weave some magic.
Now it's time to think about colours.....& where.
I'm possibly using "White" on the "Framed" areas....but definitely dark GREY & BLACK on the walls. IDEAS are welcomed.
The bar I'm thinking BLACK, along with the front screen wall...so maybe grey on the side walls with the odd black insert.
ID:	2601368   Click image for larger version
ID:	2601370   Click image for larger version
ID:	2601372   Click image for larger version
ID:	2601374   Click image for larger version
ID:	2601378   Click image for larger version
ID:	2601380   Click image for larger version
ID:	2601382   Click image for larger version
ID:	2601384   Click image for larger version
jokerrn, pkinneb and gibson61 like this.
post #67 of 143 Old 08-10-2019, 06:48 AM
Quoted: 173 Post(s)
Liked: 250
First visit here. Very nice job and design. Your work is excellent. Will check back often. Thanks
Luddy111dog likes this.
gibson61 is offline
post #68 of 143 Old 08-10-2019, 08:35 AM
Nevada3's Avatar
Wow, that bar looks great. Look forward to seeing the final product.
Nevada3 is offline
post #69 of 143 Old 08-10-2019, 09:42 AM
MinHeadroom's Avatar
Quoted: 120 Post(s)
Liked: 169
Next level craftsmanship- this is an aspirational thread for me. Your pointers and tips (like sealing gaps) are quite helpful.
MinHeadroom is online now
post #70 of 143 Old 08-10-2019, 10:01 AM
mumbles60's Avatar
Quoted: 68 Post(s)
Liked: 33
^^^ I would agree with this 100%! You should be very proud of your work!
mumbles60 is offline
post #71 of 143 Old 08-12-2019, 05:48 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Thanks to those who posted those words of encouragement. Much appreciated ;-)
It's back to work tomorrow after taking a week off so It'll be back to weekend theatre work again......but I'll get there.
Like I said in another post, the bar & front wall will be painted black so I've been working on some "Colour Designs" (Color Designs, if you're on the other side of the global) for the 2 sidewalls. The wife wants some input which is white on the Cornice & skirting boards so I can live with that if it keeps the peace lol.
Here are some ideas & I'm leaning towards NUMBER 1.
Thoughts anyone?
Name:	Wall Colour.png
ID:	2602048   Click image for larger version
post #72 of 143 Old 08-12-2019, 09:14 AM
Quoted: 234 Post(s)
Liked: 731
I agree I like #1 the best as well.
post #73 of 143 Old 08-12-2019, 10:19 AM
brazensol's Avatar
Quoted: 806 Post(s)
Liked: 644
#3 or #4 .
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP; (2) iNuke NX3000D; (3) HTM-12; (14) RSL C34e surrounds; (2) 18" DA RSS460HO-4 Subwoofers; (1) DA UM18-22 18" Ultimax Subwoofer; (4) DA RSS390HO-4 15" Reference HO Subwoofers; BOSS Platform - (12) 12" Subwoofers
brazensol is offline
post #74 of 143 Old 08-16-2019, 07:09 PM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Well after much deliberation. I've changed my mind again & have decided on the following
Name:	Theatre Wall Colour Mix..jpg
brazensol and pkinneb like this.
post #75 of 143 Old 08-17-2019, 10:45 AM
brazensol's Avatar
Quoted: 806 Post(s)
Liked: 644
That's even better! Have you tried it with the colors reversed? Seems black on the bottom might anchor it better and not seem top heavy
Denali Cinema
post #76 of 143 Old 08-19-2019, 04:17 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Hi BRAZ......Yes, I've tried multiple combinations (as shown below) & I keep coming back to the one framed in red.
I think the "Top Black Walls", that surround & highlight the Top French Wall Panels, look best...especially when the front wall & Bar are going totally black.
I could be wrong but I've looked at these pictures for the last 5 or so weeks & I keep coming back to by original pick in red.
Name:	Theatreroom Colour.jpg
brazensol likes this.
post #77 of 143 Old 08-19-2019, 04:38 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
On Sunday I sprayed the walls (where required) in grey. Well I must say.....I haven't lost-it. It's the first time I've picked up a spray gun for top-coat in 20 years. No "RUNS" & the paint laid down like a mirror.
ID:	2604678   Click image for larger version
ID:	2604680   Click image for larger version
ID:	2604682   Click image for larger version
post #78 of 143 Old 08-19-2019, 04:46 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Today (Monday) I sprayed the bar in black. I did get a couple of slight "SLAGS" in the primer from the week before which I missed when sanding (that's why you should always put down a "Guide-coat" when sanding)...so I'll have to give it a quick nip this weekend. I'll then install the shelves on the wall which I also painted black today (sorry forgot to take picture) & then give the bar one more coat of black.
ID:	2604686   Click image for larger version
ID:	2604688   Click image for larger version
pkinneb likes this.
post #79 of 143 Old 08-19-2019, 08:52 AM
brazensol's Avatar
Quoted: 806 Post(s)
Liked: 644
Looks good! Are you spraying with an airless or an HVLP? I've got both types but have yet to use them but will be shooting with the airless (with latex) when I repaint my foyer.
Denali Cinema
post #80 of 143 Old 08-19-2019, 09:01 AM
Quoted: 234 Post(s)
Liked: 731
Looks great!
post #81 of 143 Old 08-19-2019, 09:16 PM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
I used HVLP. Why? Because of all the angles & curves in my handy-work. By doing this I can control the paint flow better & get into all those hard to get at areas, with a better, more even coverage.
Airless-Guns are great on walls with no features, but in my case, HVLP was the much-preferred option......especially knowing my experience with them in my earlier years in the automotive industry.
Yes it took slightly longer & I had to fill up the pot probably a dozen times, but you still have to wait "In-between-coats" for them to "Flash-Off (dry), so there's not much difference......& the end results speak for themselves.
What you do to get a great finish WITHOUT-PAINT-RUNS is go around all the hard to get at areas first. In other words, leave all the easy bits to last because the're the surfaces you'll see all the time.
So put ONE, I stress ONE coat of paint on all those angled, framed areas. Go right around the room and by the time you come back to the start, the paint would have "Flashed-Off"....making it ready to paint the whole walls. Follow your "Wet-Edge"....DON"T double-up & everything will be SWEET.
For best results use a "TACK-RAG". A Tack-Rag is a sticky-cloth that you wipe down on all the walls, JUST before your ready to paint. Doing this procedure will eliminate all dust particles that you can't see but notice later STANDING-UP in finished paint jobs.
Cheers, Steve
post #82 of 143 Old 08-19-2019, 09:43 PM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Forgot the pic
post #83 of 143 Old 08-28-2019, 05:58 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
On the weekend I went around (for the 3rd time) and taped up everything that was not going to be painted black.
Got the spray-gun out the next day & laid down the black.
I still need to finish off the double-doors & the white edging on the walls.
Another 2 weekends off painting to go.
I'll put some more pictures up when I get a chance.
ID:	2608190   Click image for larger version
ID:	2608192   Click image for larger version
ID:	2608194   Click image for larger version
post #84 of 143 Old 08-28-2019, 04:42 PM
Quoted: 234 Post(s)
Liked: 731
That is turning out amazing! You do great work
post #85 of 143 Old 08-30-2019, 03:58 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Cheers PK.
I'm probably going to paint "LESS white", on some of the trimmed areas as I've explained before in previous posts.
Once you've applied something, it always looks different in real-life...so I'm always happy to review & change my plans, as I go.
Glad I'm not building a house from scratch as it would probably cost me double by the time its finished.
pkinneb likes this.
post #86 of 143 Old 09-02-2019, 04:19 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Here's those pic's I promised before.
ID:	2610122   Click image for larger version
ID:	2610124   Click image for larger version
ID:	2610126   Click image for larger version
post #87 of 143 Old 09-02-2019, 05:45 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Today I painted the top edge of the walls shown in the first photo, GREY.
Put a Smart-TV in the bar.
Moved all the RGB-LED Controllers behind the TV into the recessed "Wall-Cavity".
Now they're all hidden and I have easy access if needed thanks to the "TV mounting bracket" that extend outwards by half a metre.
I also got some mirrors measured up for the bar & brought some tiles from my mate's shop. I showed him my Bar plans, told him what colours I'd be using & mirrors....& then asked him off the top of my head, "What tiles would you use"??? In sixty seconds the perception that I had stamped in my head for the bar were erased immediately. I'll show you these amazing tiles he sold me once they're mounted on the walls. I liked them so much that I rang him back when I got home & ordered another couple of boxes to place on the floor.
& lastly, I got quote for a curtain & 1 pull-down-blind (full sun blockout) for the side window.
ID:	2610130   Click image for larger version
ID:	2610132   Click image for larger version
ID:	2610134   Click image for larger version
ID:	2610136   Click image for larger version
post #88 of 143 Old 09-03-2019, 09:38 AM
rontalley's Avatar
Quoted: 825 Post(s)
Liked: 422
The build has me rethinking my carpentry skills! I thought I was pretty darn good but the detail here is just WOW!!!
My Media Room
AVR 1-Yamaha RX-A3050 (7.2.4), AVR 2 Pioneer VSX-815-K(Used for 4ch Amp TF+TR)
Mains-Polk Audio RTi8, Center-Polk Audio CSi5, Surrounds-Polk Audio RTi4, Ceilings-Micca M-8C, Sub 1- UM18-22 (4cu.ft DIY) - iNuke 6000DSP, Sub 2-Klipsch RW12D
Projector-BenQ 3550 4K, Screen-110" Silver Ticket STR-169110, TV-Vizio P-65 4K
rontalley is offline
post #89 of 143 Old 09-10-2019, 05:18 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
Cheers, Ronny. The key is (especially when it's your place & your time) if you get bored towards the end of the days work, walk away from it.....sit down, have a beer & think about tomorrows assault on the room.
You'll then focus on what SHOULD be done & you'll get it right with no regrets.
pkinneb likes this.
post #90 of 143 Old 09-10-2019, 06:00 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 130
OK....Over the weekend I experimented with painting the FRAMES.
I first painted one frame WHITE.......Stood back & said a big NO.
I then painted the Top Frames in a colour I tinted myself using the black I used on the walls, combined with a table-spoon of white (you could say) to lighten it. I didn't mind it but I still wasn't happy.
I painted the Bottom Frames in a colour I once again tinted myself using the grey I used on the walls & a table-spoon of white. I stood back & said to myself....YOU'VE NAILED IT. So I then painted the Top Frames from black to that same grey. BINGO. I then painted the Bottom-Sill-Panels grey to suit.
ID:	2613392   Click image for larger version
ID:	2613394   Click image for larger version
ID:	2613396   Click image for larger version
ID:	2613398   Click image for larger version
Lynkage and pkinneb like this.
