STEVE'S - D.I.Y. Home Theatre - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 87Likes
post #91 of 116 Old 09-10-2019, 06:09 AM - Thread Starter
Luddy111dog's Avatar
Quoted: 29 Post(s)
Liked: 96
I then painted the CORNICE in white & the final results are TOPS......FAIR-DINKUM they're the ANTS-PANTS.
Next on the list this week is to paint the double-door grey & the little room which leads to the garage, grey as well. Also, paint the curtain-header on the inside black.
Tiles & mirrors in the bar are on order. So is the full block-out window blind for the side window & a 4 1/2 metre curtain on the back wall to hide the 3 stacker sliding door. Wait till you see this curtain...It's awesome. It's not like your typical curtain. It's state of the art & it has burnt a hole in my pocket at the same time....but once viewed, I'd just had to have it. Both these items are black & 3 to 4 weeks away.
ID:	2613440   Click image for larger version
ID:	2613442   Click image for larger version
ID:	2613444   Click image for larger version
ID:	2613446   Click image for larger version
ID:	2613450   Click image for larger version
chadsmith013 and pkinneb like this.
Luddy111dog is online now
post #92 of 116 Old 09-10-2019, 07:00 AM
Quoted: 161 Post(s)
Liked: 233
Very nice work. Being a pro painter I admire your caulking skills. Most skimp on that part ' but a good caulk job makes a big difference. Good job.
Luddy111dog likes this.
gibson61 is offline
post #93 of 116 Old 09-10-2019, 08:07 AM
Quoted: 167 Post(s)
Liked: 451
Awesome job on that some of the nicest finish work I have seen!!
My Theater Build - Full Circle Cinema
pkinneb is offline
post #94 of 116 Old 09-10-2019, 07:00 PM
Lynkage's Avatar
Quoted: 135 Post(s)
Liked: 90
Hello Steve!!
Very nice work you have done here! Maybe someday when my wife and I visit, we can see it in person! (She's an Aussie!)
May I ask what kind of paint are you spraying? Tip size? I have a few gravity fed HVLP's but if you are spraying latex the tip really needs to be large. I am not an expert by any means so I am just asking. Finishes can be extremely challenging and you have done a wonderful job!
Have an ale on me if you are ever state side!
I'm also sorry to read about Buzz R.I P.
Cheers,
Shane
Lynkage is offline
post #95 of 116 Old 09-10-2019, 09:03 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
Thx Gibbo. Your exactly right. To many Painters THESE DAYS, take short-cuts & would rather fill these gaps by "Loading" them up with excess paint. The thing is (as you would know) to the "Untrained-eye" the finished paint job looks absolutely marvellous....but give it a year or 2 once the paint fully dries, those gaps will crack, exposing the true workmanship of that painter. By using a good quality gap sealer, along with pride will guarantee & job that will last until the next new paint trend arrives....That's if you don't have kids lol.
Cheers PK. You're doing a terrific job too m8.
9 months into my build & the light is starting the glow at the end of the tunnel but still, a couple of months before I can think about relaxing....unfortunately.
pkinneb likes this.
post #96 of 116 Old 09-10-2019, 11:35 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
Originally Posted by Lynkage View Post
Hello Steve!!
You never know bro....You'll have to give it a good year though as once I've finished this project I've got an outdoor undercover area that backs onto this room which is next on the hit-list (you can sometimes see the start of it thru the back glass doors)....No point coming over for a "BO-PEEP" if we can't throw a swimp on the BBQ.
Cheers,
Shane
Thx Shane...he was a great Fur-Baby. I miss his personality & little licks.
Regarding paint, I used "Water-Based" as the over-spray dries instantly once it hits the air.
I just watered the paint down around about 4 parts paint, 1 part water. I didn't measure it due to my background experience. I just simply gave it a good stir & watched the consistency of the paint falling off the paint stick until it looked right in my eyes.
The "TIP size" (I'll have to wait until I get home) off memory I think it's 1.2....I'll get back to you as it could be 1.5
Quick tip if you haven't used a spray-gun before -
1. Always stir your paint thoroughly.
2. Always "Strain" your paint. Go to your local automotive shop & buy a box of 100 paper strainers. Yeah sure....you won't use more than a dozen at a time but they come in handy for other jobs & they're cheaper in bulk than buying multiple packs of 6.
3. Clean your paint-cap in-between coats. It takes 5 seconds using an old toothbrush in a bucket of water.
4. Make sure the "Breather-Hole" situated at the top of your pot remains unblocked at all time. Use a thin piece of wire &/or toothbrush too clean.
5. Don't have your air-pressure turned up too high (Controller usually found on base on gun). You want the paint to go on softly, not thrown on.
6. Make sure you adjust your PAINT-NEEDLE (usually the 2nd controller on the gun). You don't want the paint going on dry as it will end up looking like 180 grit sand-paper. You don't want the paint going on to wet as the paint will run like the local water fountain. As a guide I usually whined the needle out 3 full-turns & adjust in or out as I go.
7. Make sure your "FAN" (usually the top controller) is set right. This is most important. For beginners try practising with a pot full of water first. Adjust the fan all the way in & you will notice it will spray like a garden-hose if your look for distance. Start adjusting the fan OUT & you will notice it will spray like a garden-hose with a mist. So what I do to get the fan right is adjust the fan right-out & then adjust it back-in until you see the fan start closing slightly. You'll notice at this time the fan will have an even spray throughout. As I said before, beginners use a pot full of water first so you don't waste product.
8. Keep a steady arm. As a general rule if you're Right-Handed like me....Hold the gun in your right hand & the spray-hose in your left. This will provide a steady arm throughout.
9. Make sure you've got plenty of refreshments in the fridge.
Lynkage and pkinneb like this.
post #97 of 116 Old 09-16-2019, 05:00 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
Ok so I got everything done this weekend as stated.
Painted the double-doors.
Painted the little room that will store all my audio equipment.
And painted the inside of the headers black.
I also installed more RGB-LEDS around the room....but I'll leave those pictures for another day as I'm stuffed & need a coldie.
ID:	2616060   Click image for larger version
ID:	2616062   Click image for larger version
ID:	2616064   Click image for larger version
impreza276, A.T.M. and pkinneb like this.
post #98 of 116 Old 09-16-2019, 08:48 AM
Quoted: 167 Post(s)
Liked: 451
This is really coming together nicely! Top notch work on the details
pkinneb is offline
post #99 of 116 Old 09-23-2019, 06:04 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
Got the flooring down during the week.
No, I didn't go for the usual carpet. As the room is going to be a "Movie / Sporting / Concert " room, I opted for something that's more user-friend regarding "Traffic". It's a very durable laminated wood finished floor boarding that's about 8mm thick. I left a similar GAP around all the edging of the room, where the boarding simply slips under that gap creating more clean lines.
I will be laying large rugs during quite times.
ID:	2619062   Click image for larger version
ID:	2619064   Click image for larger version
ID:	2619066   Click image for larger version
post #100 of 116 Old 09-23-2019, 06:08 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
Placed the mirrors in after cutting out templates & getting a friend to cut them to size at his shop.
ID:	2619070   Click image for larger version
ID:	2619072   Click image for larger version
ID:	2619074   Click image for larger version
post #101 of 116 Old 09-23-2019, 06:15 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
Painted on the "Tile Primer" so to get the maximum grip once I start laying the tiles.
Cut my first ever tile today after forking out good cash on a decent tile cutter. Piece of p1$$.
Layed a couple of tiles before calling it a day.
ID:	2619078   Click image for larger version
ID:	2619080   Click image for larger version
ID:	2619082   Click image for larger version
ID:	2619084   Click image for larger version
post #102 of 116 Old 10-08-2019, 06:15 AM
audioguy's Avatar
Quoted: 5125 Post(s)
Liked: 3982
All I can say is "WOW". Your carpentry skills are off the charts. That you can both design and build such a great looking space is just remarkable. I know you must be very pleased with this space.
Congrats. Job well done. Looking forward to the photos when it is complete.
audioguy is offline
post #103 of 116 Old 10-18-2019, 08:41 PM
MinHeadroom's Avatar
Quoted: 79 Post(s)
Liked: 123
It’s just getting silly how good a) your skills are and b) how good you are at documenting them.
Mad jealous. Keep it up..
MinHeadroom is offline
post #104 of 116 Old 10-20-2019, 05:49 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
Thx PK, Audioguy & MHD. I haven't been ignoring you lot. I've just had a couple of "ARM-CHAIR-WEEK-ENDS" where I temporarily USED the 90% finished Movie-Room.
2 weeks ago we had our SUPERBOWL Grand Final (Rugby League) where my Mighty Mighty Green-Machine, the Canberra RAIDERS got the ruff end off the stick in the final stages & got pipped on the post. Arrrh well....There's always next year....BUGGER.
And last week Australia staged the BEST CAR RACE in the world, BATHURST 1000 where once again my beloved HOLDEN got pipped as well, by a Ford Mustang.
Back on the tools this weekend where I'll be doing my "Front Speaker Surrounds". Pictures to come, but first I'll post some pictures from last weekend when the room was CLEAN & my mates were over.
Cheer's Steve.
post #105 of 116 Old 10-20-2019, 06:07 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
I'll post "Double Pictures" of each scene .....but with different colours to show you that when it comes to colour settings, the skys the limit with these RGBs.
If your an AUSSIE, you'll know what the last picture means, COCKROACH CRESCENT lol.
Also, I've purposely not shown you any pictures of the 130-inch projector screen because I need to finish off ALL surrounding areas first. Sorry to keep you in suspense ;-)
ID:	2629632   Click image for larger version
ID:	2629634   Click image for larger version
ID:	2629636   Click image for larger version
ID:	2629638   Click image for larger version
ID:	2629642   Click image for larger version
ID:	2629644   Click image for larger version
ID:	2629646   Click image for larger version
ID:	2629648   Click image for larger version
ID:	2629652   Click image for larger version
ID:	2629654   Click image for larger version
ID:	2629656   Click image for larger version
ID:	2629658   Click image for larger version
ID:	2629662   Click image for larger version
ID:	2629664   Click image for larger version
ID:	2629666   Click image for larger version
louisdamani and pkinneb like this.
post #106 of 116 Old 10-20-2019, 06:47 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
I forgot to put up pictures of the BLACK TILES.
It's pretty hard to show these tiles off without being here but here's some pic's that show reflections of the RGBs.
They're 600mm x 600mm squared tiles so I only needed 12 of them....TOPS.
ID:	2629672   Click image for larger version
ID:	2629674   Click image for larger version
ID:	2629676   Click image for larger version
ID:	2629678   Click image for larger version
4fit? and pkinneb like this.
post #107 of 116 Old 10-28-2019, 03:19 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
These 2 pictures are of the FULL-BLOCK-OUT blind, that was installed 2 weeks ago.
One shown opened & one shown closed.
They obviously work 100%. Brilliant.
ID:	2633020   Click image for larger version
pkinneb likes this.
post #108 of 116 Old 10-28-2019, 04:12 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
And these pictures are of the curtain on the Rear-Triple-Stacker-Window, on the rear-wall.
These curtains work similarly to the old out of date "Vertical-Blinds", that rotate left & right to let the light in... but don't have the old "Joiner-Cords" on the bottom to keep them parallel or in-sink.
These curtains actually look like they're One-Big-Curtain.....but don't be fooled as you can walk through them anywhere you like without pulling the curtain out of the way.
When rotated "Left" they close blocking out 85% of all light....but when Rotated "Right" they open up letting in the light and revealing a nice lacy pattern which is totally separated from the next sleave.
These curtains will perfectly complement this room as behind those moving glass doors will be an outdoor BBQ area which will be undercover and in-line with 130-inch projector screen.
Give me 2 more years & this spot will be the ANTS PANTS.
ID:	2633024   Click image for larger version
ID:	2633026   Click image for larger version
ID:	2633028   Click image for larger version
ID:	2633030   Click image for larger version
ID:	2633034   Click image for larger version
ID:	2633036   Click image for larger version
pkinneb and MinHeadroom like this.
post #109 of 116 Old 10-28-2019, 04:43 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
These pictures are of the FRONT speaker covers that will go below the 130-inch screen.
They're only "Cut-Outs" ATM from MDF panelling...which I'll paint in the coming weeks.
There's 3 speaker covers in total, shown. Left, right & centre.
They're all made up from 3-pieces.
The 1st piece is the base.
The 2nd will be hidden in the centre and be covered in "Black-Speaker-Material".
The 3rd piece is the front-face and that will lock all 3 pieces neatly together.
Once completed & mounted will show clean-lines.
If you haven't noticed I love "Attention-to-Detail".
All pieces have been routed inside & out, where needed.
PS....The little puppy is "Grace". She's our new baby girl after beloved "BUZZ" past earlier in the year.
ID:	2633048   Click image for larger version
ID:	2633050   Click image for larger version
ID:	2633052   Click image for larger version
ID:	2633054   Click image for larger version
ID:	2633058   Click image for larger version
pkinneb likes this.
post #110 of 116 Old 10-28-2019, 05:00 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
These pictures are of the SIDE speaker covers. Obviously there's 2 covers.
Basically it's the same as explained in the above post.
Once they've finished I still need to finish off the Stubbies (sorry SUBBIES) surrounds covers, the RV-Rack & a few odd jobs.....But I'm getting there slowly but surely.
ID:	2633062   Click image for larger version
ID:	2633064   Click image for larger version
ID:	2633066   Click image for larger version
ID:	2633068   Click image for larger version
post #111 of 116 Old 10-28-2019, 05:04 AM
lizrussspike's Avatar
Quoted: 1296 Post(s)
Liked: 1954
Wow @ Luddy111dog, great space and fantastic work.
lizrussspike is offline
post #112 of 116 Old 11-10-2019, 12:35 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
Cheers lizrussspike.
On a sad note, I've injured my right-bicep picking up a large sheet of MDF today while in the process of building my AV AMP storage unit.
I got as far as cutting out the "Front & Rear" faces of the AV-Rack, before going down to the local hardware shop where I tore that muscle internally...so it's gonna need some time off to help repair.
Looks like the HT room is going to get a workout for a couple of weeks lol.
I must admit......this is NOT the first time I've read about this scenario happening (injury) during a HT-build, and it most probably won't be the last lol.
The 1st pic below is simply 2 blank MDF boards which I've cut to size.
The 2nd pic is with holes cut-out where the AV, Blueray & CD players, multiples Amps and even an old twin-tape-deck for old time sake will be displayed. I've also got to place FANS as well to extract the heat.
Both pieces look identical as after cutting one out I simply clamped them together and routered the other one out. Their not 100% though as I had to leave room for a power-point which I presume you can all notice.
Oh well....I've got a bit of time now to think about it.
ID:	2638878   Click image for larger version
MinHeadroom likes this.
post #113 of 116 Old 11-10-2019, 05:48 AM
Liked: 1954
Sorry to hear that @Luddy111dog , that's a bummer. I tore a muscle in my forearm and elbow, and it sucks. Def take time to let it heal.
Good Luck
post #114 of 116 Old 11-20-2019, 03:23 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
It goes from bad to worse.
The bicep is as good as gold (light duties) but the YAMAHA RX-A3010 died on the weekend.
I've gone back to my "Main-man" who I buy all my AV's, Amps, Speakers from & although I haven't committed yet, he's offered me a really good deal on a new YAMAHA RX-A3080.
25% off what his website is asking for it....so I'm pretty keen.
Thoughts on any another AV's before I commit or reasons why I should or shouldn't buy.
My set-up consists of 3 Yamaha amps that I've "Pre-amp" to the system and a stack of PSB Synchrony Speakers (1 tower & 3 bookshelves & 1 centre). 1 PSB 500 Subwoofer & 2 sets of Nile ceiling speakers.
All speakers are not installed yet (ceiling & side Spk still in box) as HT-room is in the final stages...& believe it or not I was considering updating my AV with ATMOS & then this happens which makes things easier lol.
Thoughts are welcome by all, including what I should bi-amp (front towers & ??) and whether I should use 5.1.4 - 7.1.4.
Regards, Steve.
post #115 of 116 Old 11-21-2019, 10:30 AM
tigerhonaker's Avatar
Quoted: 731 Post(s)
Liked: 727
Thumbs up
Steve,
The bicep is as good as gold (light duties) ...
Take care of that ^^^
Nice Theater buddy ...
Waiting to see the (Final-Completed-Pictures).
Terry
tigerhonaker is offline
post #116 of 116 Old 12-02-2019, 03:45 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 96
Ok regarding the AV-RACK.
I've routered out some SLEEVES to slide the shelves in on the
wall panels.
There's 7 shelves (so far).
The shelves I've routered out some holes to help with cooling.
There's a picture with the FRONT-FACE painted black.
There's a picture with some AV & AMPs in position.
ID:	2648334   Click image for larger version
ID:	2648336   Click image for larger version
ID:	2648338   Click image for larger version
ID:	2648340   Click image for larger version
