35Lx19W 7.4.9 Atmos Theater Build in Maryland - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #1 of 50 Old 03-02-2019, 08:46 AM - Thread Starter
crimsonblue's Avatar
Quoted: 138 Post(s)
Liked: 89
Arrow 35Lx19W 7.4.9 Atmos Theater Build in Maryland
Hi all, I'm now onto my third home theater, and this time it's in a new house that has an unfinished portion of the basement that I will use as a dedicated theater.
I am about 6 months away from move-in, and I imagine that it will take me 3-4 months after I move in to get everything done [famous last words...] Attached is a basic rendering of the design. The room layout is fixed, but what I do in it is still open to suggestions.
Speakers:
  • L/C/R: Elusive 1099s
  • Surrounds and Backs: Volt-8
  • Current Subs: Currently two 4.0cf boxes with 18-22 Ultimax drivers
  • Future Subs: I am talking to the legendary folks at GSG Audio about doing four Full Marty subs.
Equipment:
  • I will have three racks in the back to house all of the gear, and I designed a 4' "closet" behind the rear wall for audio gear and random stuff that needs to be kept (original boxes, etc.)
  • The current screen is an AT 135" - and it could work in the new space too. 150" would be better, but that's a lot of cost for an incremental upgrade
  • The second row of seats will be on a riser -- jury is still out about elevating the first row; I've never done butt kickers, but it could be interesting
  • Epson Faux-K projector is a gem and I'll be bringing that over
  • 6 Crown XLS 1002 amps + 2 Behringer NX6000D amps + 4 Dayton Audio APA102 amps for Atmos
Room & Treatments
  • Concrete pad in basement
  • 2 Dedicated 20amp circuits (chime in if you have a valid argument for 3 circuits)
  • Double 5/8" drywall + Green Glue + Hat Channel
  • Roxul or Pink Fluffy -- my eyeballs have dried out reading the comparisons and science, and I'm tempted to go fluffy at this point
  • Acoustic panels -- no idea how to make these, so if you have best-practice threads - let me know
That's where I am right now. The equipment will almost all transfer over to the new house, so my thoughts are more centered on the build itself to make sure it's something I will enjoy for 10+ years
Name:	Screen Shot 2019-03-01 at 3.10.37 PM.png
________________________________________________
Home theater build 1 | Black & Grey Theater 2 | Yet Unnamed Theater 3
Marantz AV7702mkII | Epson 5040 | 7.2.4 Elusive 1099 LCR + Volt 8 Atmos & Surrounds + Dual UM18 Subs
crimsonblue is offline
post #2 of 50 Old 03-02-2019, 08:49 AM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
Previous lessons learned from builds 1 and 2:
Stage/Screen:
Allow more than 24” behind the AT screen if possible. 18” sub boxes are often 22” or 24” inches deep and it cuts it too close for comfort. I wired my speakon inputs on the side of the sub cabinets just in case, but 4-6 inches of extra depth would have been nice. Sand is heavy, but it is a worthwhile endeavor to get a solid base below your bass. 2x8s for the main cavity lumber seemed like a good height. If you are doing two steps, use cheap 2x4s for the bottom one. Why two layers of 3/4” plywood/OSB on top of the sandbox framing? Because @BIGmouthinDC says so. Trust his experience and don't be stubborn. Plus, 1.5” of OSB/plywood makes for easy round-overs with a router. Leave a 1” gap around the entire sandbox perimeter so that it does not touch the wall. Sound dampening/isolation is the whole point of the sand. Don’t degrade that by rattling your walls and the china cabinet upstairs.
Riser:
The height depends on your needs and the best angle to see over the first row of chairs while being able to view the bottom of the screen. I went with 2x10 with 1.5” of decking on top.
Add power outlets in places where you might need them in the future. Maybe you will want near field subwoofers behind the second row of chairs. Maybe you will want to have power for an iPad charger near each chair. You can hide outlets with black faceplates, but it’s very hard to add them after the fact. Really hard. Pink fluffy insulation is cheap. Line the empty cavities with it so that your riser doesn’t become a resonant drum, even if you are on thick carpet. If you want an LED or incandescent rope light lining the underlip of the riser, plan ahead for that. I couldn’t extend my lip after the fact and needed to black rope light channel strips to hide the bulbs. The channels disappear in low light and create a diffuse effect, but it would have been cleaner to have a proper lip to begin with.
Labor:
An extra pair of hands can cut the work time down by 75%. I hired two guys off of Craigslist (the odd-jobs and gigs section) who were between construction jobs and paid them $15/hour. Best move ever. While it was my project and I was “in charge” - I made it clear that I wanted their suggestions and input, which definitely helped the project along. I had the vision, but they had the years of expertise and had a few tricks up their sleeves to make things go faster/better.
Lighting:
Accent lighting added a really great look to my room. I went with cheap 3” 50w halogen downlights ($14.99 each) and I’ll add in LED bulbs when they burn out. Buying them separately is oddly still much cheaper than starting off with LED housings. Some people go with 4” downlights - I liked the accent effect of the 3” bulbs; my tray ceiling was 10” so it seemed to be better balanced. It’s 1000x easier to add the accent lights when you’re building a tray ceiling. If you are doing it after the fact, just get the power up into the tray and then pull your Romex through. Don’t make the spacing between light holes too far or it is much hard to fish the wire through.
Paint:
If your spouse allows it, painting the ceiling black has an enormous effect on the perceived contrast — night and day difference. I was tossing out my carpet so I didn’t care about the drips, but keep that in mind and carefully prep your space when you are painting on the ceiling. The blackest of the black paint still has some reflection so heed the advice that so many here give on making a wider screen frame made out of black crushed velvet. It is like a black hole for light and really makes a tremendous difference. Get MDF or cheap plywood and a stapler and you’re done in a few minutes. I used SyFabrics and loved the result. JoAnne Fabrics is probably fine too, but the price fluctuates too much and I just wanted it done.
Speakers:
Seriously, check out the DIY offerings from DIYsoundgroup and GSG Audio. Premium components and the only catch is that some assembly is required! Flat packs from them, and from Parts-Express are the best investment you will ever make. Pre-drill your holes for mounting woofers. Put your hand between the woofer and the screwdriver or you will be buying a new woofer when it slips (mine did, and I was being careful). If using sealed enclosures, get speakon receptacles that are air-tight. Parts-Express.com has speakon connectors with different colors (blue, white, green, yellow, red) and it might help your sanity to color code your cables at the speaker end (ex. red for Fronts, yellow for subs) and then with the same color at your amp end if you are using.
WAF:
Double the amount of time that you tell your spouse that you will be working. Things always take longer than expected. And, if possible, take a night off and just do something nice for her/him and say thank you for being patient. I initially failed and this and got some deserved backlash, but was able to make it right eventually.
post #3 of 50 Old 03-02-2019, 01:45 PM
Quoted: 5723 Post(s)
Liked: 5284
First row viewing distance of 15 ft is pretty far for my taste. 12-13 would be my preference.
bb80301 and brazensol like this.
post #4 of 50 Old 03-03-2019, 06:19 AM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
Fair point -- 13' still works for my taste so I'll probably move things up a few feet to gain space on the back end. Thanks BIG! Once this new house gets framed up, I'll have to get you over!
post #5 of 50 Old 03-03-2019, 12:41 PM
NotShorty's Avatar
Quoted: 32 Post(s)
Liked: 30
Subscribed. Your "previous lessons learned" post was enough to convince me that this will be a thread worth following.
How do you plan to get power to the riser if it's on slab and it doesn't extend out to the side walls (it's an "island" if you will)?
There may be a commonly accepted way of dealing with this that I'm unaware of, so apologies in advance if that's the case.
Sent from my Pixel 2 using Tapatalk
NotShorty is online now
post #6 of 50 Old 03-03-2019, 02:23 PM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
Yeah, getting power to the riser is a bit of an issue. I could do a little riser in the back by the bar to allow for electrical, or go peninsula style to the side. I guess people in the second row would have to step up no matter what.
Anyone else out there have any elegant solutions for getting power to a second row riser?
post #7 of 50 Old 03-04-2019, 12:46 AM
Liked: 5284
Trenching a concrete slab floor for electrical is a one weekend job or less. Loud, dusty project but if you rent the right tool nothing a DIYer can’t tackle. Better yet if the slab isn’t poured yet have them put in a conduit from a side wall to the riser.
post #8 of 50 Old 03-04-2019, 01:15 AM
frenchfries's Avatar
Quoted: 74 Post(s)
Liked: 39
I'm not sure what the regulations are where you are but can you chase into the slab? If so do that then run your power and terminate with a floor box under the riser, then you can do whatever you want.
Chasing is annoying but it's not too terrible.
Sent from my ASUS_Z017DA using Tapatalk
frenchfries is offline
post #9 of 50 Old 03-06-2019, 03:28 PM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
My builder is not moving at the pace I would like, so I think it's a great idea to see if I can get some conduit (1 pipe for power, 1 pipe for signal cables) run into the concrete. Great idea!
frenchfries likes this.
post #10 of 50 Old 03-06-2019, 03:33 PM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
If anyone in the VA/MD/DC area has ever wanted to get a Marty Sub flat pack, I am putting together a small group buy. The guys at GSG Audio are awesome and have answered a ton of questions about sob coverage, butt kickers, etc.
Right now, I'm partnering up with some other local AVSforum guys to get:
  • 4 Full Martys
  • 2 Mini Martys
  • 2 UM18-22 18" drivers
  • 2 RSS460-HO 18" drivers
  • 2 Behringer NX6000D amps
If you want in on some Marty Sub flat packs and want to save a bundle on shipping (or if you have a business loading dock where we can unload to save on the huge residential markup) -- let me know!
post #11 of 50 Old 03-06-2019, 07:06 PM
Rjloper9's Avatar
Quoted: 26 Post(s)
Liked: 26
If you're not completely sold on the buttkickers, check out what @trhought did in The Hideway Theater with his invention, THE BOSS! Details in post #29
https://www.avsforum.com/forum/19-de...y-theater.html
trhought likes this.
Rjloper9 is offline
post #12 of 50 Old 03-06-2019, 08:07 PM
Liked: 5284
post #13 of 50 Old 03-07-2019, 03:19 AM
SteveCallas's Avatar
Quoted: 807 Post(s)
Liked: 733
Go for four dedicated equipment electrical circuits
One for the recievers/pre pro/amps for speakers
One for the subwoofer amps
One for the projector
One for all the other gear (disc player, video game systems, roku/satellite box/cable box)
The last one can be shared with other outlets in the room for vacuuming, charging phones, etc
Lights should be on a seperate circuit as well, possibly shared with other rooms
Rjloper9 likes this.
SteveCallas is offline
post #14 of 50 Old 03-07-2019, 05:22 PM
trhought's Avatar
Quoted: 675 Post(s)
Liked: 1183
LOL....that "percepto" device in the link reminds me of the 4D movie experience at Disneyworld's "A Bug's Life". The part of the movie where the ticklers physically poke out of the seats at the perfect time and everybody screams....lol....classic. Let alone some other surprises that I won't spoil.
trhought is offline
post #15 of 50 Old 03-07-2019, 07:20 PM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
Playing devil's advocate -- doesn't 4 circuits seem like overkill? Why would the projector be on its own circuit? It doesn't use that much juice. I was thinking:
1. Amps and Lights (when one of those is on, the others are off)
2. Subs
3. Equipment
I have a ton of equipment, 6 Crown XLS1002 amps, lights, etc. on one circuit right now, and an iNuke 6000D on another circuit. I actually had all that on one 20amp circuit and everything was fine. Peak wattage comes with few devices on, few lights on (they are LEDs anyway) and just a momentary boost of the amps/subs.
texpilot likes this.
post #16 of 50 Old 03-08-2019, 07:29 AM
trhought's Avatar
Quoted: 675 Post(s)
Liked: 1183
Peninsula style to the side is what I did, makes running any cables so much easier since that riser goes all the way over to the wall on one side. Glad I did it this way 20 years ago because I've added 3 additional cables back there so far in addition to the power (added Cat6 for back row bar, low voltage cable for LED lighting and USB charge ports for bar and an HDMI cable for a secondary screen in the back row bar. Never know what the future will bring, but it seems it always means adding another cable of some sort...lol.
If you're looking for awesome, low cost ULF and TR, check out the BOSS in my build thread (signature link below).....no need for buttkickers or tactile transducers if you have a BOSS or 2 in your theater. One member has even recently constructed a curved BOSS which would be perfect for your front row while the full riser BOSS would be perfect for your back row.
trhought is offline
post #17 of 50 Old 03-08-2019, 07:43 AM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
What is the novel element? We've seen plenty of subs in risers before. What am I missing?
post #18 of 50 Old 03-08-2019, 08:11 AM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 168
Ha Ha Ha Ha...….HAAA HAAA HAAAA....stop it you're killing me!
I would run at least the 4 circuits. My room is open concept so I ran a circuit along each side wall of the room, plus the two for equipment and 1 for lighting.
Speaking of lighting circuits....I would STRONGLY suggest that you run power to the switch box and then to the fixtures. Yes, it takes a little longer and uses a little more wire, but it gives much better control and declutters wiring at the fixture. ESPECIALLY if you are going to use remote switches, and particularly Insteon, which requires a neutral at each switch. And, if you ever need to do any work after the fact, you know that if the switch off, the fixture is dead.
And when wiring outlets, pigtail the outlet so that one bad outlet doesn't take out the rest of the outlets on the circuit.
And what is this "if your spouse allows it" stuff? I'm watching you, Bub.
Rjloper9, brazensol and BllDo like this.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #19 of 50 Old 03-08-2019, 08:17 AM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
Not to be a complete dummy, but how else would someone wire lights? I thought the line always came into the light switch, and went from there to the lights.
post #20 of 50 Old 03-08-2019, 08:41 AM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 168
Builders will do it the cheaper way....run the power to the ceiling in a kind of main line to each fixture, usually down the center of the ceiling to use as little wire as possible. Then they run a line from the hot at the fixture box down to the switch. If you're lucky, they connect the black from the box the switch, then color the white at the switch with a black marker and run it back up to the fixture. It adds extra wires and connectors in the fixture box, and can be confusing if the wires aren't all marked properly.
crimsonblue likes this.
Tom Logan
post #21 of 50 Old 03-08-2019, 10:36 AM
trhought's Avatar
Quoted: 675 Post(s)
Liked: 1183
Great Question!
BOSS features:
1 Open Baffle Design...no SPL to worry about integrating with your far-field subs. Set it and forget it.
2 Drivers mounted in horizontal arrangement....more efficient transfer of TR to the body than vertical arrangements
3 More excursion than buttkickers and maybe even more than tactile transducers....comparison testing coming soon.
4 More sensitive than buttkickers or tactile transducers.....only 80 watts needed per driver
5 Main volume levels can be kept low while still delivery respectable TR and the experience doesn't get lost with low MV
6 As MV approaches reference, the BOSS keeps responding in a natural way keeping in line the the far-field SPL increase
7 Low cost....it's only $90 for the 3 drivers plus a 4x8 sheet of 3/4" plywood for $35
Number 1 and 2 are the probably the biggest differences between the BOSS and more traditional subs in risers....being an open baffle design, means it's more efficient and doesn't take much power to reach max excursion. Open baffle also means the sound waves cancel and there's no SPL...perfect for integration with existing far-field subs without having to re-calibrate. The horizontal configuration means most of that excursion transfers directly to your body in an up-down motion which is how we feel ULF in the real world.
Just another option in the ULF/TR world of our hobby and costs considerably less than the other ULF/TR/VNF options.
It only cost me $240 to delivery respectable TR to every seat in our theater and every row. Plus, the BOSS's are totally hidden...no one knows they're there until the ground starts to move below them.
There's some videos of the BOSS's in action in my build thread link in my signature below.....after watching the videos, remember all that ULF and TR is in every seat and every row of our theater including our 3rd row bar...all for less than $250 and 80 watts per driver......incredible!
trhought is offline
post #22 of 50 Old 03-08-2019, 10:58 AM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
[Shrug]
I understand how it works, but I don't see how this is anything new, other than saying BOSS a few hundred times in your thread. I'm not saying it's not a good concept, but TR on a riser, via subs, isn't really new.
Doing it for small amount of money because of the low cost of the drivers -- that's a great thing, and worth passing around. The design drawings you made are very helpful for those trying to do the same type of setup -- nice work with those; I can barely draw stick people! I just don't think it's a new concept, just one that you've given a name.
post #23 of 50 Old 03-08-2019, 11:31 AM
trhought's Avatar
Quoted: 675 Post(s)
Liked: 1183
^^^^ Cool. I still think it's a great question and will include the BOSS features in my build thread for those who have the same question. I'm like you when I first started this "sub in riser" journey....yeah, there'e been several risers and mini-risers on AVS over the years, but after several exciting experiments about ULF/TR and sensitivity of the orientation of drivers and the open baffle benefits, it became a much different animal than anything else I've seen here or any other threads...back to our normally scheduled programming.
BTW, I love your design and setup, gonna be awesome how you have the seating arranged relative to the speakers and the room. Should deliver a quite nice soundfield with the seats not being too close to any one drivers and taking advantage of the natural room bass reinforcement with the seats placed longitudally and laterally like they are. Like it a lot.
Our rooms are about the same size....these large rooms help a lot with acoustics.
For the visuals, I prefer a much more immersive experience for the front row, but that's just me and some of my kids like it better up there also. (10 feet from a 14' diagonal 2.35:1 screen).
trhought is offline
post #24 of 50 Old 03-08-2019, 11:44 AM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
Heck, anything that refines regular options into best practices is the way this hobby should go - so keep doing what you're doing!
It's funny about the screen-MLP discussion; I think I watch too many fast moving movies and like to be a bit further back. I'll have to move my current front row up to 10 or 11 feet to see if I've just been too conservative on distance. I think you at BIG may be right!
post #25 of 50 Old 03-09-2019, 06:02 AM
Quoted: 807 Post(s)
Liked: 733
2. Subs
3. Equipment
Which circuit would the projector go on? Which circuit would shared outlets in the rest of the theater room go on?
Dedicated circuits are pretty inexpensive and a dedicated theater room is the last place you would want to see any kind of a hiccup from taxing the electrical.
post #26 of 50 Old 03-09-2019, 12:13 PM
Liked: 5284
Not sure of your experience in your area but here in my corner of NoVa my power is very iffy during storms and other events like a car hitting a power pole. Projectors have a cool down cycle for a reason, to protect the innards of a projector from the residual heat of a bulb after you turn the projector off. I don't have a circuit connected to a breaker for the projector, I have a power inlet and an outlet. Normal outlet for the projector but a power inlet connected to a battery UPS that feeds that inlet. You don't need an expensive one, I get the current flavor at Costco usually $99. Tape the receipt to the back. When the battery goes bad in 4-5 years you take it back for a full free exchange. I'm on my 4th. They usually have built in surge protection which you will also want for your projector.
This is a power inlet, Midlite on Amazon:
Rjloper9 and texpilot like this.
post #27 of 50 Old 03-09-2019, 12:24 PM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
Is this a good time for confessional? I've usually run my projector power cord into the ceiling via a brushed grommet, and then connected a 20ft extension cord (12gauge) back to the equipment room into a UPS backup. That seemed to be the easy fix at the time, but I'm sure it's not code compliant!
post #28 of 50 Old 03-09-2019, 12:53 PM
Liked: 5284
correct, not code compliant, Also Romex which is inwall rated is cheaper than an extension cord.
If you want to save money and not buy a power inlet just hard wire a pigtail to the Romex in the junction box for the power feed. This approach has been passed by inspectors.
texpilot and Boxozaxu like this.
post #29 of 50 Old 03-09-2019, 07:06 PM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
This?
Projector plugged into standard outlet in the ceiling --> sole Romex from that outlet goes through ceiling joists, popping out of drywall and then finished with a 3 prong adapter --> Plug in adapter to UPS or outlet.
Essentially a DIY extension cord using Romex and a 3-prong adapter to meet code?
post #30 of 50 Old 03-09-2019, 11:09 PM
Liked: 5284
It is a little known fact that on August 30, 2016 I received my only forum infraction for accusing someone of being lazy in regards to their wiring scheme. I won’t make the same mistake twice.
Romex is not approved for unprotected use such as an extension cord. Also extension cords use stranded not solid wire. However as was pointed out on an “inspectors forum” there is often plenty of exposed Romex in unfinished basements, garages and attics. If you plan on selling the house at some point I wouldn’t use the Romex as an extension cord.
https://www.nachi.org/forum/f19/rome...plug-ok-14070/
