Reelwood 2019 Demo Clips Collection 4K Atmos dtsX and more - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 54Likes
post #91 of 155 Old 05-31-2019, 02:58 PM
Liked: 0
Originally Posted by Jk7.2 View Post
Wow. I’m just getting into trying to download demo clips and save them to my 128G flash drive. I’m gonna try a few of these. Thanks!
I can't download it, I am using BiglyBT (Vuze) Torrent App, how did you download it?
Antoni Arias Diaz is offline
post #92 of 155 Old 05-31-2019, 03:49 PM
Howard Shure's Avatar
Quoted: 37 Post(s)
Liked: 41
Thank you OP for doing this. This is going to make it much easier to demo my new subs!
Is the download really slow for everyone else and any tips on how to speed it up? I am a complete newbie when it comes to torrents. I'm using uTorrent. Currently I should have the whole thing in a week and 6 days.
__________________________________________________ __________________________________________________ __________________________________________________ ______________
Running 5.2.4, Yamaha RX-A 2070, Parasound A31, Polk LSiM 707 (Fronts), Polk LSiM 706 (Center), Polk OWM3 (Surround), Polk TL3 (Atmos), Dual HSU ULS-15 MK2 Subs, Epson 5030UB, Silver Ticket 110"
Howard Shure is offline
post #93 of 155 Old 06-05-2019, 06:39 AM
Quoted: 117 Post(s)
Liked: 106
Originally Posted by russdornisch View Post
Never mind on this... I didn't even realize that at the time my Shield hadn't recognized the HD. As soon as it did the clips showed up! Plugged it into my receiver and Oled to do some sound and video testing to see if I got Dolby out of it and sure enough the whole thing worked like a dream. Now one month till we move and I can use these clips to test out the new theater!!!!!
In SPMC, you may have to first create a source, particularly if you're using a NAS, through SYSTEM>FILE MANAGER. Once you specify a NAS share or similar, then it will show up in FILES when you want to open a movie file. Glad you got it sorted.
dennwood is offline
post #94 of 155 Old 06-07-2019, 02:44 PM
avrignaud's Avatar
Quoted: 80 Post(s)
Liked: 27
Originally Posted by pjvader View Post
If anyone knows of a way i can upload the files to somewhere and let everyone have access but also let me add new files (got a ton of new clips waiting, captain marvel atmos, black hawk down atmos etc) but i cant add them to a torrent without creating a new torrent from scratch there are cloud services i could use but i cant find any free ones that allow the 300gb etc
Have you looked at Mediafire, filehosting.org, or others listed here? https://hosting.review/file-storage/free-file-hosting/
I'd personally be excited to see an updated torrent with your new files. Current one has only two seeders sadly.
Also, FWIW, I'm a big fan of the "pile of files" approach, versus disc/image. Makes it so much easier to browse a directory and demo.
pjvader and mystickid like this.
avrignaud is offline
post #95 of 155 Old 06-07-2019, 06:33 PM
LastButNotLeast's Avatar
Quoted: 3047 Post(s)
Liked: 2864
All you had to do was ask: I'll seed all weekend and beyond.
Looks like there are a few others, too.
Michael
LastButNotLeast is offline
post #96 of 155 Old 06-24-2019, 03:24 AM
Liked: 0
Many Many Many thanks!!! This is an amazing collection, i now have everything needed to demo and test my home theater system. Amazing job thanks again
nikospriov is offline
post #97 of 155 Old 06-24-2019, 03:35 AM
Liked: 0
Also another remark, I listened to Guns n Roses paradise city in truehd and then in the same volume on Spotify and the difference is chaotic, I thought it was broken
post #98 of 155 Old 06-29-2019, 01:39 PM
Liked: 2
Thanks, although not all files correspond to the description e.g.
Orianthi -Now Or Never dts-HD Master Audio, it's only DTS not HD Master
I recommend this version:
Full HD, video 80 Mbps, audio PCM 7.1, 96.0 KHz, 18.400 Kbps
https://mega.nz/#F!t4dxDAZZ!iA04Jp9pDKFmZAb39wC24g"]https://mega.nz/#F!t4dxDAZZ!iA04Jp9pDKFmZAb39wC24g
Name:	Orianthi-Now or Never.m2ts_zpstixiufss.jpg
bramowicz1 is offline
post #99 of 155 Old 06-29-2019, 01:43 PM
Liked: 2
Code:
General #1
Complete name : D:\软件\emule\Incoming\Orianthi-Now or Never.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 3.55 GiB
Duration : 4mn 42s
Overall bit rate mode : Variable
Overall bit rate : 108 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video #4113
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : [email protected]
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=7
Codec ID : 2
Duration : 4mn 42s
Bit rate : 80.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 1.287
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
Stream size : 2.65 GiB (75%)
Writing library : TMPGEnc Video Mastering Works 5 Version. 5.1.0.46
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #4352
Menu ID : 1 (0x1)
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : Blu-ray
Codec ID : 128
Duration : 4mn 42s
Bit rate mode : Constant
Bit rate : 4 608 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 96.0 KHz
Bit depth : 24 bits
Stream size : 155 MiB (4%)
Audio #4353
Menu ID : 1 (0x1)
Format : PCM
Codec ID : 128
Duration : 4mn 42s
Bit rate : 18.4 Mbps
Channel(s) : 8 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE
Bit depth : 24 bits
Stream size : 621 MiB (17%)
post #100 of 155 Old 06-29-2019, 01:46 PM
Liked: 2
Sorry, info:
Code:
General #1
Format : BDAV
Duration : 4mn 42s
Video #4113
Menu ID : 1 (0x1)
Format : MPEG Video
Codec ID : 2
Duration : 4mn 42s
Color space : YUV
Bit depth : 8 bits
Audio #4352
Menu ID : 1 (0x1)
Format : PCM
Codec ID : 128
Duration : 4mn 42s
Bit depth : 24 bits
Audio #4353
Menu ID : 1 (0x1)
Format : PCM
Codec ID : 128
Duration : 4mn 42s
Bit depth : 24 bits
post #101 of 155 Old 07-10-2019, 01:51 PM
Freddicus's Avatar
Quoted: 24 Post(s)
Liked: 25
Thanks for this. I've just finished downloading, and I'll be seeding for a while. What's a good above-average ratio these days?
Audio: Marantz SR6014 | (FL/FR) Sony SS-U421AV | (FC) Sony SS-CN5000 | (SL/SR) Sony SSF-5000 | (FHL/FHR) Polk Audio S10 | Sub (1) Polk Audio PSW505
Video: BenQ HT3550 | Elite Screens Sable Frame B2, 92-inch 16:9 (SB92WH2)
Sources: Apple TV 4K | PS4 | PC | Nintendo Switch
Cable: DELONG 10m (33ft) Fiber Optic HDMI
Freddicus is offline
post #102 of 155 Old 07-11-2019, 07:35 PM
Mr.Guvernment's Avatar
1:1 is always ideal but the more the better
Mr.Guvernment is offline
post #103 of 155 Old 07-12-2019, 07:18 AM
Freddicus's Avatar
Quoted: 24 Post(s)
Liked: 25
I put in a target of 5:1, but it might take 15 days. My upload pipe is 35 Mbps, but my peers are mostly international. Been getting 6 - 8 Mbps total. Anyway, I will be seeding for a while.
These files are great. I was surprised that Windows 10 native movie player could play these and send bitstream to my AVR. I have a ten year-old computer with a GeForce GTX 750 Ti, and it's been fine for 1080p. I can't wait to see how that dtsX object demo performs when I upgrade in a few years!
post #104 of 155 Old 07-23-2019, 06:07 AM
Freddicus's Avatar
Quoted: 24 Post(s)
Liked: 25
Just an FYI for anyone reading or following this thread - I put a bunch of files on a flash drive and tried to play them on the PS4, but was not successful. See this page for more information on what's supported. Kind of disappointing, but at least my HTPC plays them for the most part.
post #105 of 155 Old 08-06-2019, 12:27 PM
scubasteve2365's Avatar
Quoted: 326 Post(s)
Liked: 367
Is anyone successfully playing all of these via Kodi? I have a shield and an HTPC and when I add the folder to Kodi on both devices, only a handfull of the files make it into the library. Of the ones that do (a couple from the scope folder, a couple from the 16x9 folder, and many from the music folder) all play just fine and in Atmos. Basically, there are many files that Kodi is just flat out ignoring to see.
"The Scuba Tank" thread here
PSN/XBL/Steam : ScubaSteve2365 - PC = i7-8700k, RTX 2080Ti, DDR4-3200 Ram
My VR Podcast on Youtube - VR Roundtable - Pimax, Playstation VR, Rift-S, and Quest
Theater = Epson 5040UB, Denon x4400, Klipsh RF 7.2.4, 4-FiCar 18" IB, HTMarket Pembrokes, Aura BassShaker
scubasteve2365 is online now
post #106 of 155 Old 08-06-2019, 02:38 PM
Quoted: 326 Post(s)
Liked: 367
I found the solution for the above problem, didn't see it mentioned in this thread.
Kodi seems to ignore filenames that have the trademark icon/symbol within it. Almost all of the files in the torrent have that symbol in the filename. Simply deleting that symbol has made Kodi start seeing all of the files, unfortunately it means one cannot seed the torrent unless they are willing to have two copies.
mrtickleuk likes this.
post #107 of 155 Old 08-07-2019, 08:15 AM
whiteboy714's Avatar
Quoted: 1896 Post(s)
Liked: 815
I added them yesterday and as far as I know they all show up. But I specifically didn't want them in the library. So this way they don't show up as if they are all movies which is what I did at first.
This way I just go to the files section and view them as a list.
TCL 65R625 -- Denon X3500h -- Klipsch RP600m -- RP450C -- Ascend HTM 200 SE -- Dual Klipsch RW-10
whiteboy714 is online now
post #108 of 155 Old 08-07-2019, 08:35 AM
Quoted: 326 Post(s)
Liked: 367
I too did not want them on my movie wall and only wanted to view them via the files section. Kodi (8.3) on shield and on my PC ignored the files completely (not available in the file view) until I deleted the symbols from the file name.
post #109 of 155 Old 08-07-2019, 08:41 AM
Liked: 815
Here's what I'm seeing. I'm on 17.x as I use the version with DSplayer. Not sure if that makes a difference.
post #110 of 155 Old 08-07-2019, 12:33 PM
Quoted: 326 Post(s)
Liked: 367
Yes understood, it appears to be something has changed with v18.
post #111 of 155 Old 08-07-2019, 12:57 PM
Liked: 815
Ok it must have then.
post #112 of 155 Old 08-27-2019, 03:49 PM
Quoted: 156 Post(s)
Liked: 48
could somebody help me out, tried to download this but cant get anything. magnet link simply hangs never doing anything other than try to open. What program did you use to download as i have no idea how to get this to even start downloading with what i got.
[email protected] is offline
post #113 of 155 Old 08-27-2019, 04:24 PM
Liked: 815
Install this program https://www.q**********.org/ and then grab the torrent file and open it with that program.
post #114 of 155 Old 09-18-2019, 11:17 PM
Liked: 1
Originally Posted by Contuzzi View Post
I have some .mkv clips from various 4K DTS/Dolby Demo discs if interested and want to add them. PM me.
pm
Albert Gold is offline
post #115 of 155 Old 09-18-2019, 11:17 PM
Liked: 1
MKV Clips
pm
post #116 of 155 Old 09-19-2019, 06:54 AM
Quoted: 23 Post(s)
Liked: 24
Thanks! really awesome of you to put this together! I am downloading now and will seed off my server indefinitely
Stephen Cagle is offline
post #117 of 155 Old 09-19-2019, 03:46 PM
Liked: 2
That's what I thought too but I underestimated the popularity of this. In two days I've uploaded 1.5TB. It's been going between 100-150Mb/s nonstop. I'll jump back in every once in a while but I don't need my ISP sending me nastygrams for uploading 22TB a month...
Huge thanks for putting this together. Now to see if I can figure out why Plex doesn't play a few of these correctly when windows handles them fine...
NotShorty and mystickid like this.
LG C8 65" | Denon AVR-X3500H | Nvidia Shield
JBL Studio 590 (L/R) | JBL Studio 520C | JBL Studio 230 (SL / SR)
SVS Prime Elevation (Front Height)
HSU VTF-3 MK5 HP
CynicalCypher- is offline
post #118 of 155 Old 09-22-2019, 07:09 AM
Liked: 0
pjvader, thank you very much for all your work!!!!!!
thank you everyone who have given advice within this thread!!
I'm currently dl, and will seed accordingly. Only problem is I won't be able to utilize any of these files until May 2020 when the house is done building, can't wait!!!!
viscera912 is online now
post #119 of 155 Old 10-03-2019, 10:50 PM
Chris Young's Avatar
Quoted: 75 Post(s)
Liked: 249
Thank you @pjvader for this Awesome collection I downloaded it yesterday and will be happy to seed for the long haul.
Let me know if you post another version of this, an added addition or volume and do the same for that as well
Have fun,
ian#77 likes this.
"The Boy has no patience" Yoda
"He will learn patience. Was I any different when you taught me?" Obi-Wan
My attempt living room build The Story Time Theater
3 DIY HTM-12 LCR 10 M&K S-100B, 2 24" SI HS-24 MKIII. 1 HoverBOSS 3 JBL 12's and 3 BK LFE, 2 Adire Tempest Side Columns Near field Fun all in one room.
Chris Young is offline
post #120 of 155 Old 10-24-2019, 06:38 PM
Liked: 1
MKV Clips
would be much obliged if you would forward me the mkv clips.
ian#77 likes this.
