The Dawkness Theater - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #31 of 50 Old 07-04-2019, 04:13 AM
toddwz's Avatar
Quoted: 48 Post(s)
How would you seal the doors? In my case the weather strips don't look well on doors. Thanks.
toddwz is offline
post #32 of 50 Old 07-04-2019, 10:43 AM - Thread Starter
weavinator's Avatar
Quoted: 33 Post(s)
Liked: 59
You mean at the base where the two floor surfaces meet? I'll have to discuss with the builder but there will have to be some kind of threshold. I want it to be low profile to be easy on the feet. The FLOOR carpet tiles are about 1/8" thick. I'm thinking maybe just a piece of painted steel.
weavinator is offline
post #33 of 50 Old 07-04-2019, 06:44 PM - Thread Starter
weavinator's Avatar
Quoted: 33 Post(s)
Liked: 59
Happy Independence Day to my friends in the US! To my surprise the guys worked a half day today getting a head start on framing. They're a hard working pair of guys. It's nice having 2 of the builder's staff doing most of the work throughout the project vs various subcontractors coming and going.
I ordered 2 50' rolls of 1.5" Resi-Gard orange conduit for the low voltage wiring. My current thinking is to run everything into the room in conduit termininated in backer boxes. One run to each major zone in the room and then final runs along the wall/ceiling hidden behind acoustic panels, etc. I'm just looking for a clean install and flexibility for future upgrades.
post #34 of 50 Old 07-05-2019, 03:49 AM
toddwz's Avatar
Quoted: 48 Post(s)
In the soundproof section, you said "Seals & automatic door bottoms". I just wonder how you would seal the door. Perhaps I misunderstood?
toddwz is offline
post #35 of 50 Old 07-05-2019, 06:35 AM
A.T.M.'s Avatar
Quoted: 35 Post(s)
Liked: 56
From the soundproofing company inc (as an example)
[...Adjustable Door Jamb Stop
Secured directly to the door jamb, these acoustical gaskets feature our unique Compress-O-Matic™ design with a sound-absorbing neoprene bulb that compresses to form a tight seal as the door is closed.
Both models include adjusting screws for field correction of irregular clearances that might compromise actual sound performance.
When used with a metal cased-opening frame, the #770 offers the added benefit of eliminating the need for an additional frame stop–and its unaesthetic projection into the door opening.
The gasket is also listed for use with both wood and metal acoustical doors with fire listings ranging from 20 to 90 minutes under both negative a positive-pressure testing standard. It is exceptional engineering, design features, and performance have made the #770 our long-time favorite for acoustical engineers and specifier.
Features
UL Rated
Aluminum Finish
Solid neoprene seal - weatherproof and remains flexible in extreme temperatures.
Fully Adjustable upto .3 inches
Installed as surface mounted
Easily Trimmable...]"
etc.. I think that is what he is talking about.
Aaron
All ya need is love, and Hi Fi sound.
Asthetix, Audreal, Arcam FMJ, Musical Fidelity, Harmonix, Marantz, Tannoy, MIT, PS3, Panasonic, OPPO
A.T.M. is offline
post #36 of 50 Old 07-05-2019, 07:11 AM - Thread Starter
weavinator's Avatar
Quoted: 33 Post(s)
Liked: 59
Gotcha. The specs I gave to contractor call for "Zero International perimeter door seals and automatic door bottom". I haven't sought out specific models yet. I like the #8878 though because it has concealed screws for a clean look. https://www.tmhardware.com/Door-Gask...Ring-Seal.html
post #37 of 50 Old 07-05-2019, 10:26 AM
toddwz's Avatar
Quoted: 48 Post(s)
Features
UL Rated
Aluminum Finish
Aaron
Thanks. That's a lot to digest for me.
Looks good.
toddwz is offline
post #38 of 50 Old 07-22-2019, 08:35 PM - Thread Starter
weavinator's Avatar
Quoted: 33 Post(s)
Liked: 59
The slab was poured almost three weeks ago and now the first floor framing is done and the first layer of suboor is going down on the 2nd floor (say that 3 times fast) .
The heart of the whole theater arrived today. I picked up a refurbished Marantz AV7704 from Accessories for Less. I was putting off big electronics purchases like this but I hadn't seen any refurbs come up for sale in a while and none of the newer models really add anything I need so it made sense to jump on it now.
post #39 of 50 Old 07-23-2019, 08:00 AM
Ladeback's Avatar
Quoted: 1342 Post(s)
Liked: 478
Send a message via MSN to Ladeback
What are you going to use for amps with you AV7704?
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #40 of 50 Old 07-23-2019, 08:27 AM - Thread Starter
weavinator's Avatar
Quoted: 33 Post(s)
Liked: 59
The plan is Crown XLS 1002 amps all around.
Ladeback likes this.
post #41 of 50 Old 07-28-2019, 03:37 PM - Thread Starter
weavinator's Avatar
Quoted: 33 Post(s)
Liked: 59
I have a question for the soundproofing experts. I've attached pictures of one side of the double stud wall that separates the theater from the equipment closet. As you can see, there's a 2x8 strung along the wall to support the floor joists. Double drywall and Green Glue are planned for both sides of the wall. What can I do to treat below the subfloor? Should I just not worry about it and stuff with R19?
post #42 of 50 Old 07-28-2019, 06:17 PM
Quoted: 5629 Post(s)
Liked: 5199
You can use sound isolation methods on the floor, Float another 3/4 inch subfloor on top of the thick rubber pad. Horse stall mats from Tractor supply are value rubber pads. They should look like ground up tires glued together. Yes insulation below.
post #43 of 50 Old 07-28-2019, 06:33 PM - Thread Starter
weavinator's Avatar
Quoted: 33 Post(s)
Liked: 59
Thanks Jeff. I've already instructed them about horse stall mats under the theater side of the double stud wall. In fact they've already cut them to size for that so it shouldn't be a problem. It looks like there's space to do multiple layers of subfloor plus rubber mat and still match the existing floor height.
This sounds easier than installing short 16" sections of double drywall and Green Glue on the theater side of that wall which is one solution I was thinking of.
post #44 of 50 Old 07-31-2019, 08:35 AM - Thread Starter
weavinator's Avatar
Quoted: 33 Post(s)
Liked: 59
The second floor framing is underway. Most of the wall sections are up.
I found an OK deal on a rack mount kit for the AV7704. The package said it was for the 8803 but it fit so I'm pleased. I also played around with the pre-pro using a minimal setup with just left and right channels connected to my master bedroom zone and playing the Shield through my bedroom UST projector.
Lastly, the first row recliners showed up this morning. We delayed the delivery as long as possible. We're running out of space to store theater furniture!
post #45 of 50 Old 08-01-2019, 12:42 PM - Thread Starter
weavinator's Avatar
Quoted: 33 Post(s)
Liked: 59
Green Glue veteran users: what's the best way to reseal a partially used tube? I haven't been able to find a screw cap that will fit 29oz tubes.
I'm going to build a few backer boxes soon which will require just a small amount of GG and I don't want to waste any unused portion of the Green Glue or sealant.
We should be calling it Green GOLD its so expensive.
post #46 of 50 Old 08-01-2019, 12:54 PM
impreza276's Avatar
Quoted: 488 Post(s)
Liked: 727
impreza276 is offline
post #47 of 50 Old 08-02-2019, 09:12 AM
Tedd's Avatar
Quoted: 2100 Post(s)
Liked: 880
How about a dab of silicone sealant and a screw?
Tedd is offline
post #48 of 50 Old 08-02-2019, 10:02 AM - Thread Starter
weavinator's Avatar
Quoted: 33 Post(s)
Liked: 59
I ordered a pack of the things I don't want to type the name of suggested by impreza276. I had been looking for a nice positive seal, ideally a cap that screwed on like the nozzle does so I'll settle for these.
impreza276 likes this.
post #49 of 50 Old 08-02-2019, 10:38 AM
impreza276's Avatar
Quoted: 488 Post(s)
Liked: 727
They are great. I used to wrap my caulk nozzles with painter's tape, but after switching to these I never looked back. It's good to have protection!
post #50 of 50 Old 08-08-2019, 09:47 PM
A.T.M.'s Avatar
Quoted: 35 Post(s)
Liked: 56
It's coming along nicely. Sorry, I've been gone, or I would have commented on your questions. Keep it up.
Aaron
A.T.M. is offline
