How To Connect Riser Wiring to Wall? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-16-2019, 12:07 PM - Thread Starter
mhutchins's Avatar
Quoted: 252 Post(s)
Liked: 237
Question How To Connect Riser Wiring to Wall?
I've been searching for several hours and I still haven't found a good explanation for this.
What is the best practice method for connecting the line voltage and low voltage wires to the riser from the wall? Are people just spanning the small gap with bare wire or are they using flexible conduit? How are you maintaining sound isolation at the wall connection?
Mike
mhutchins is offline
post #2 of 3 Old 03-16-2019, 01:25 PM
Quoted: 5840 Post(s)
Liked: 5406
Small gap 1 inch or less = bare Romex between the wall and the riser framing tucked below the top edge of the riser framing out of sight and out of reach. The carpet and any molding will cover the gap
Larger gap add some blocking to protect the wire.
post #3 of 3 Old 03-16-2019, 05:56 PM - Thread Starter
mhutchins's Avatar
Quoted: 252 Post(s)
Liked: 237
