Peppercorn and tricorn black theater - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By 4fit?
post #1 of 12 Old 04-08-2019, 08:27 AM - Thread Starter
Quoted: 59 Post(s)
Liked: 0
Has anyone used this color combo that wouldn’t mind posting a picture of results? I’m leaning to tricorn black on ceiling and screen wall and the peppercorn grey on the walls.
SDoutdoorsman is offline
post #2 of 12 Old 04-08-2019, 09:42 AM
brazensol's Avatar
Quoted: 699 Post(s)
Liked: 510
No pics but I think that would be a very nice looking combo!
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP's; (3) HTM-12's; (14) RSL C34e surrounds; (2) 18" Dayton Audio RSS460HO-4 Subwoofers; (1) Dayton Audio UM18-22 18" Ultimax Subwoofer; (4) Dayton Audio RSS390HO-4 15" Reference HO Subwoofers
brazensol is offline
post #3 of 12 Old 04-09-2019, 07:59 AM
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 515
I used tricorn black on my ceiling and considered peppercorn grey on walls but wound up going with Westchester grey as it fit better with the fabric covering the acoustic panels. Feel free to check out my theater build "The Force Theater" in my signature line below
jedi1982 is offline
post #4 of 12 Old 04-09-2019, 08:38 AM
sirjaymz's Avatar
Quoted: 416 Post(s)
Liked: 501
In HT1.0, I went with Peppercorn latex on the ceiling, however, in HT2.0, went with Tricorn on everything, latex for the ceiling, and oil base for all the columns and trim.
If this is your first time doing a dark color on the ceiling , Peppercorn will look almost black to you, and it actually is a very nice dark color, but not quite as black as Tricorn.
You can get some samples from Sherwin-Williams that will cost about 8 bucks a pop , but then you can paint some samples and see which one you like better..
Personally, I really like both of them, as I have used them both, so IMHO, I would use either or...they both look great.
HT1.0 | HT2.0 (Finally Fully Operational )
JVC RS-2000 / Xbox One X / nVidia Shield / DIY treatments
Seymour AV Center Stage 130" 2.35 / Denon 7200WA / Denon 6300 / 2x miniDSP2x4HD
iNuke NU6000DSP / iNukeNU3000DSP / 2x Klipsch R-112SW / 2x UM18-22 / 12x JBL 12"
11.2(16).6 Atmos/Klipsch RF-82/RC-64II/RS-42/RS-41/BS-62/CDT3800-C-II
sirjaymz is offline
post #5 of 12 Old 04-09-2019, 09:56 AM - Thread Starter
Quoted: 59 Post(s)
Liked: 0
It is my first time doing a dark ceiling, and surprisingly my wife is onboard with it so that’s a plus. I’ll have to check your guys theaters! Thanks for the input.
post #6 of 12 Old 04-09-2019, 10:11 AM - Thread Starter
Quoted: 59 Post(s)
Liked: 0
what type of finish did you use? Did you go all the way to flat or i have also heard eg shell is a good compromise between not as glossy but also not leaving fingerprints and what not.
post #7 of 12 Old 04-09-2019, 11:26 AM
4fit?'s Avatar
Quoted: 74 Post(s)
Liked: 46
Not my theater, but here are a few good shots of @Juiced46 's theater which is Tricorn and Peppercorn. I will be going with this color scheme as well with a fabric front false wall.
https://www.avsforum.com/forum/19-de...l#post53295434
Juiced46 likes this.
4fit? is offline
post #8 of 12 Old 04-09-2019, 02:48 PM
Juiced46's Avatar
Quoted: 425 Post(s)
Liked: 148
Here are a few more updated pictures of my setup of Tricorn Black and Peppercorn. Also, Sherwin Williams mixed a darker primer for me for the Tri corn so I can get it as dark as possible. I used Tricorn on the screen wall and ceiling up to the front row.
ID:	2550986   Click image for larger version
ID:	2550988   Click image for larger version
ID:	2550990   Click image for larger version
ID:	2550992   Click image for larger version
Juiced46 is offline
post #9 of 12 Old 04-09-2019, 05:11 PM
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 515
I did eggshell on ceiling to help reflect some of the LEDs but did flat on walls.
jedi1982 is offline
post #10 of 12 Old 04-10-2019, 01:55 AM
tlzkaasen's Avatar
Liked: 24
Good Morning,
We're still in the final phases of setting up our HTR, but all walls and ceiling are TRICORN matte. Taking pics of a "black" room are really, really tough. The trim was done in a TRICORN "satin". Application - I was fortunate I was able to spray the Tricorn because this was a newly built lower level. I have some other pics to help show the black.
These pictures are really terrible the more I look at them. -- Sorry, I'll see if I can capture some better ones tonight
ID:	2551172   Click image for larger version
Samsung 82" Q6 Series QLED |Marantz SR7012 | (2) Marantz MM7025 2 channel AMP | Sony UBP-X700 Utra Blu-Ray | RSL (5) CG23 (2) RSL Speedwoofer wireless (2) RSL CG3 (2) RSL C34E| Lutron Caseta dimmers w/ Hub | Panamax M5300-M | Logitech Harmony Elite Controller |
TRICORN all Black Home theatre 14.6 x 15.2 with 8 Trayed ceiling ....
tlzkaasen is offline
post #11 of 12 Old 04-10-2019, 07:05 AM - Thread Starter
Quoted: 59 Post(s)
Liked: 0
Do you have problems with the flat walls showing fingerprints or scuffs or anything.
post #12 of 12 Old 04-10-2019, 07:27 AM
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 515
Nope, but I don't make it a habit to lick my walls either LOL
But in all seriousness, we just make it a point not to touch the walls like any other room in the house as there is enough space to move around without doing so. If someone does touch it though, we've not had any issues. If something were to scuff it up, that's what leftover paint and sponge brush is for
jedi1982 is offline
