Platform behind screen - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By BIGmouthinDC
  • 1 Post By Tedd
post #1 of 15 Old 04-12-2019, 01:13 PM - Thread Starter
Liked: 0
I'm building a platform behind my screen wall to support my LCRs and a Sub. Can the cavity of the platform be hollow? Or is it best to fill it with something?
orby2000 is offline
post #2 of 15 Old 04-12-2019, 04:00 PM
Quoted: 6194 Post(s)
Liked: 5877
It will resonate, fill it. How big is it?
post #3 of 15 Old 04-12-2019, 08:31 PM
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 195
Fill it
...with more subs
Really though. Think of it like the stage. Some people even fill those with sand to stop the resonance that big mentioned. That’s probably why he’s asking about its size. I’m sure he’s got a solution to fit your needs.
sassuki is offline
post #4 of 15 Old 04-13-2019, 05:48 AM - Thread Starter
Liked: 0
It's a rectangle approx 80" L x 25" W x 35" T I was planning to build it to sit my LCRs and a sub behind an AT screen
orby2000 is offline
post #5 of 15 Old 04-13-2019, 06:18 AM
Liked: 5877
You could build wall mounted shelves for your mains and leave the sub on a rubber pad on the floor. A lot less lumber.
post #6 of 15 Old 04-13-2019, 06:37 AM - Thread Starter
Liked: 0
Thanks Big. Probably best to do that, but would the sub below rattle the shelves above? I thought a box might be more stable?
orby2000 is offline
post #7 of 15 Old 04-13-2019, 06:44 AM
Liked: 5877
really nothing to rattle, the entire front wall should also be treated with absorption
ID:	2552342   Click image for larger version
ID:	2552344   Click image for larger version
ID:	2552346   Click image for larger version
NotShorty likes this.
post #8 of 15 Old 04-13-2019, 06:47 AM
Liked: 5877
You could also just build three pedestal boxes for the mains, I throw a bag of sand in, bag and all for the ones I build.
Tedd likes this.
post #9 of 15 Old 04-17-2019, 01:23 PM - Thread Starter
Liked: 0
Big,
would hanging bats of fiberglass to fill my cavity accomplish the same goal as using 2 layers of Linacoustic to treat my front wall (behind AT screen). The cheapest 100' roll of Lin. I can find within 50 miles is $260 within 50 miles of me. Obviously , the Linacoustic is neater...
orby2000 is offline
post #10 of 15 Old 04-17-2019, 01:32 PM
Liked: 5877
short answer is yes, put it should be unwrapped, you might also want to consider Roxul, or Bonded cotton insulation.
but you can look at the data yourself:
https://www.bobgolds.com/AbsorptionCoefficients.htm
orby2000 likes this.
post #11 of 15 Old 04-20-2019, 12:28 PM - Thread Starter
Liked: 0
Technically, if I have left over Linacoustic, could I do another layer or two, sandwiched with plastic each time? Or is there diminishing returns at a certain point?
orby2000 is offline
post #12 of 15 Old 04-20-2019, 02:11 PM
Liked: 5877
I'm not aware of any data on that, I think it falls under the category "can't hurt"
post #13 of 15 Old 04-20-2019, 04:34 PM
Tedd's Avatar
Quoted: 2250 Post(s)
Liked: 962
Ever consider going in with someone else, and splitting the cost?
Folding hanging batts of fiberglass might not be the best idea if you think about fiberglass potential becoming airborne and ingested.
Tedd is offline
post #14 of 15 Old 04-20-2019, 07:54 PM
Liked: 5877
just cover with a fabric
post #15 of 15 Old 04-21-2019, 04:05 AM
Tedd's Avatar
Liked: 962
A breathable fabric cover will still allow fiberglass strands to become airborne. (I wonder if the insulation made from old jeans would be a better choice???)
The Savoy does have some rope suspended, folded over batts up front, behind the AT screen. I expect they are there to knock off any harsh leading transients
of a potent sound system and reduce slap echoes.
Tedd is offline
