Acoustically Transparent Black Velour - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By BIGmouthinDC
  • 1 Post By hd0823
  • 2 Post By corradizo
post #1 of 15 Old 04-19-2019, 04:11 PM - Thread Starter
rbouch8828's Avatar
Quoted: 57 Post(s)
Liked: 54
Does anyone know of a source/manufacturer of acoustically transparent black velour? I have a black velour surround all around my acoustically transparent screen with my three front speakers behind and two subwoofers are below the screen in cutouts of the black velour. I would like to cover them with two pieces of acoustically transparent black velour.
Can anyone point me in the right direction?
Best,
RB
rbouch8828 is offline
post #2 of 15 Old 04-19-2019, 04:45 PM
69glamboy's Avatar
Quoted: 225 Post(s)
Liked: 95
Best,
RB
Why not use speaker cloth? Staple it on the back side of your openings. You can get that at any textile shop. Hope this helps
Thee Rock n' Roll Theatre-coming soon.
69glamboy is offline
post #3 of 15 Old 04-19-2019, 04:58 PM - Thread Starter
rbouch8828's Avatar
Quoted: 57 Post(s)
Liked: 54
I have that now and it just doesn’t have the same look as the black velvet on the rest of the wall.
post #4 of 15 Old 04-19-2019, 05:03 PM
Quoted: 6685 Post(s)
Liked: 6566
At one time Hancock fabrics (now bankrupt) had a Micro Velvet that had a good openness factor and I suspected it was about as good as you can expect from Velvet. Keep in mind that there isn't a single fabric that is perfect, Some equalization may be required. some pictures comparing FR 701 a favorite for hiding speakers and the Micro Velvet.
ID:	2555624   Click image for larger version
ID:	2555626   Click image for larger version
texpilot likes this.
post #5 of 15 Old 04-19-2019, 06:52 PM - Thread Starter
rbouch8828's Avatar
Quoted: 57 Post(s)
Liked: 54
Any sources that you know of?
post #6 of 15 Old 04-19-2019, 06:58 PM
Liked: 6566
post #7 of 15 Old 04-19-2019, 08:30 PM - Thread Starter
rbouch8828's Avatar
Quoted: 57 Post(s)
Liked: 54
Hi Jeff,
I couldn’t navigate the German. I wasn’t sure how to place an order. Also, it wouldn’t take my eBay login info.
RB
post #8 of 15 Old 04-19-2019, 08:47 PM
Liked: 6566
post #9 of 15 Old 04-19-2019, 09:12 PM
Orbitron's Avatar
Quoted: 609 Post(s)
Liked: 611
http://projectiondream.com/en/protos...velvet-devore/
Might try Whaleys in the UK for Devore.
Orbitron is offline
post #10 of 15 Old 04-20-2019, 12:57 AM
Little Chris's Avatar
Quoted: 107 Post(s)
Liked: 281
I have used the Devore black velvet for my front stage around the screen. I also have two subwoofers below the screen, which I was planning to cover with normal speaker fabric. However, maybe it would be possible to use velvet for that as well, if it doesn't block the sound that much. After all, it is only the low frequency sound waves that needs to travel through the velvet, so it might not impact the SPL that much. I guess some quick measurements with REW would confirm/deny that hypothesis. I might go ahead and try that soon(ish)...
I have quickly snapped a few pictures, which show the difference between the two pieces of fabric. Obviously, the Devore velvet is much darker, although in real life the difference is not as big as the pictures would indicate (the speaker fabric is more dark in real life).
ID:	2555762   Click image for larger version
My Small Home Theater Build
JVC RS400 / 110" 2.40:1 Curved DIY AT Screen w. Masking / Prismasonic A-Lens / Marantz SR7011 / Emotiva XPA-5 / Behringer EP4000 / Oppo UDP-203 / PS4 Pro / Apple TV 4K / 7.2.2 Surround / DIY LCR's / 4xFI IB3 15" IB Sub
Little Chris is offline
post #11 of 15 Old 04-20-2019, 03:54 AM
Liked: 6566
If you search for Micro Velvet there are a number of vendors including Amazon. You would have to order a sample to see how open it is.
post #12 of 15 Old 04-20-2019, 05:08 AM
SteveCallas's Avatar
Quoted: 1074 Post(s)
Liked: 975
https://www.morexfabrics.com/stretch...0-width-58-60/
I have a sample of this. It def seems porous enough to be AT when stretched just a bit, but just make sure you dont have anything bright or light colored behind it, because it will show some of it. Heres with morning sunlight.
ID:	2555796   Click image for larger version
SteveCallas is offline
post #13 of 15 Old 04-20-2019, 05:36 AM
hd0823's Avatar
Quoted: 946 Post(s)
Liked: 1798
You'll be 100 percent fine I have royalty 3 velvet from joann fabrics over my subs on the side and literally with the panel off you can hear no difference
Sent from my SM-N950U using Tapatalk
Little Chris likes this.
hd0823 is offline
post #14 of 15 Old 04-20-2019, 09:39 AM - Thread Starter
rbouch8828's Avatar
Quoted: 57 Post(s)
Liked: 54
Ok, will get it. Thanks.
post #15 of 15 Old 04-20-2019, 02:21 PM
corradizo's Avatar
Quoted: 1554 Post(s)
Liked: 1638
I have the stretchy Joann Black Velvet covering part of my subs, no issues.
brettus and hd0823 like this.
corradizo is offline
