Speaker Placement? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BIGmouthinDC
post #1 of 14 Old 05-21-2019, 08:36 AM - Thread Starter
Helheim's Avatar
Quoted: 42 Post(s)
Liked: 90
Speaker Placement?
Originally I was going to place the LR speakers behind the screen and fill the corners with rigid fiberglass but would I gain anything putting them on the outside of the screen?
ID:	2569568   Click image for larger version
Helheim is offline
post #2 of 14 Old 05-21-2019, 09:46 AM
Quoted: 6360 Post(s)
Liked: 6132
Can you toe them in toward the MLP if yes I would do it.
Helheim likes this.
post #3 of 14 Old 05-21-2019, 08:19 PM
Nyal Mellor's Avatar
Quoted: 546 Post(s)
Liked: 386
Yep those look like JTRs, they need to be toed in as their dispersion is very low. Not sure which horn that is but the new ones are only 60 degrees horizontal at -6dB, that means if you are 15 degrees away from on axis you’ll be -3dB which is as much high frequency loss as I recommend.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is online now
post #4 of 14 Old 05-22-2019, 08:04 AM - Thread Starter
Helheim's Avatar
Quoted: 42 Post(s)
Liked: 90
Yes they are the old JTR Noesis 212HT-LP ones with the 60/40 dispersion pattern. Do I want to try and point them directly at the main listening position then?
Name:	043 Helheim - Devin - 021 speakers - measurements.png
Helheim is offline
post #5 of 14 Old 06-03-2019, 11:04 AM - Thread Starter
Helheim's Avatar
Quoted: 42 Post(s)
Liked: 90
Option 1 or 2? I don't have a lot of room so I can't toe them in as far as I'd like.
Option 1
Option 2
ID:	2575380   Click image for larger version
Helheim is offline
post #6 of 14 Old 06-03-2019, 01:48 PM
sirjaymz's Avatar
Quoted: 494 Post(s)
Liked: 609
I'd go Option 2, and stuff the corners with rigid fiberglass like you were going to orginally. I think based on the dispersion pattern, you'd not want to have the -3db at the MLP if you went with Option 1.
HT1.0 | HT2.05
JVC RS-2000 / Seymour AV Center Stage 130"diag, 2.35 / nVidia Shield
11.2(22).6 Atmos / Denon 7200WA / Denon 6300 / 2x miniDSP2x4HD / DIY treatments
2x NU6000DSP / 2x NU3000DSP / 2x Klipsch R-112SW / 4x UM18-22 / 4x PA-460 / 12x JBL 12"
Klipsch RF-82/RC-64II/RS-42/RS-41/BS-62/CDT3800-C-II
sirjaymz is offline
post #7 of 14 Old 06-03-2019, 03:08 PM
Liked: 6132
1) I'd slice 1/2 the face of the uprights off in the area of the speaker
2) carve out the treatment in for the back corner of the speaker and angle the speaker as much as possible
3) I'd pull the speaker forward a bit to avoid edge diffraction effects when the screen frame is in place
4) build the outside left and right fabric panels at an angle matching the speakers instead of flat screen wall
post #8 of 14 Old 06-04-2019, 06:47 AM - Thread Starter
Helheim's Avatar
Quoted: 42 Post(s)
Liked: 90
Kind of like this you mean? The screen frame will go right the edge of the support post so if I notch it out then part of the speaker would be behind the aluminum frame.
Helheim is offline
post #9 of 14 Old 06-04-2019, 08:54 AM
Liked: 6132
Oh, I thought the screen frame only went to the middle of the front face of the upright. If it goes to the outside edge you really don't have room to place the speakers outside the screen. The reason to go to the middle is so you have a backer for the outside fabric panels.
post #10 of 14 Old 06-04-2019, 08:58 AM - Thread Starter
Helheim's Avatar
Quoted: 42 Post(s)
Liked: 90
Damn didn't think of that. So would you do option 2 then? Is it going to reflect off the sub though like that?
Thank
Helheim is offline
post #11 of 14 Old 06-04-2019, 09:10 AM
Liked: 6132
you are trying to put too many potatoes in that bag. It won't be perfect but I doubt many theaters are.
post #12 of 14 Old 06-04-2019, 09:23 AM
Liked: 6132
what would happen if you laid the sub on it's side in the center of the stage and used it as a stand for a horizontal orientation of the center channel JTR. You would mitigate any width wise bass nulls. not sure of the effect on the center channel.
post #13 of 14 Old 06-04-2019, 11:39 AM - Thread Starter
Helheim's Avatar
Quoted: 42 Post(s)
Liked: 90
The long term plan was to get another sub for the other side but the wife would be happy if I didn't buy another one. Guess I can try it. Thanks for the help.
Helheim is offline
post #14 of 14 Old 06-04-2019, 11:44 AM - Thread Starter
Helheim's Avatar
Quoted: 42 Post(s)
Liked: 90
Hmm maybe cut a hole in the wall so I can slide the sub back more but I have electrical behind it. I guess I should have used smaller speakers.
Helheim is offline
