Atmos or not? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-21-2019, 12:52 PM - Thread Starter
blipszyc's Avatar
Quoted: 150 Post(s)
Liked: 78
Atmos or not?
So even though I said I wouldn't build another dedicated theater (this will be #4 ), my wife is encouraging me to do so. With that said, it's been a few years since #3 and now Atmos and other 3D audio technology is out. Would that work in with this type of room layout?
Room (from proposed screen location to back wall) is 11'10" x 24'8" x 8'. Side walls are 5' before slant/roofline.
Name:	3D Front.png
ID:	2569778   Click image for larger version
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
4.0 - TBD
blipszyc is offline
post #2 of 7 Old 05-21-2019, 01:35 PM
Quoted: 5497 Post(s)
Liked: 5081
maybe, it makes sense on every new build project.
post #3 of 7 Old 05-21-2019, 04:00 PM
Quoted: 25 Post(s)
At a minimum I would plan for where the Atmos speakers will be and wire for it. When I built my theater, I didn't have funds for the extra amp and speakers for Atmos right away. Probably spent 3-4 months before I had some disposable $ to buy them.
So I have lived with and without Atmos in the same theater. When the source material is encoded for Atmos...WOW! Awesome! VERY COOL!. When the processor interpolates it, not that big of a deal. But lets face it, object based surround appears here to stay. More and more material should go this way. So at a minimum plan for the future and run the speaker wires, extra XLR/RCA and make sure there is room where the speakers should go (duct work, can lights and all the other things that screw up ceiling placement later on)
HighModulus is offline
post #4 of 7 Old 05-21-2019, 04:17 PM
sdurani's Avatar
Quoted: 6915 Post(s)
Liked: 5874
Side walls are tall enough to place surrounds at ear height or even slightly higher. You should easily be able to separate sounds around you versus sounds above you, which is the hallmark of a good Atmos set-up. How wide is the flat part of the ceiling?
Sanjay
sdurani is offline
post #5 of 7 Old 05-21-2019, 05:02 PM
Mocs123's Avatar
Quoted: 100 Post(s)
Liked: 27
One other option (and what I’m considering) is to figure out what speakers you want to use and then get a Monoprice speaker with the same cutout (or slightly less) to use in the meantime and swap them out when you get more $$$.
I’d prewire at the very least as it’s so much easier now then it is later.
7.1.4 Theater Room (In Progress): JVC-RS46U, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic DBT-110, JBL Studio 270’s, NXG-NX BAS 500 (for now)
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne
Mocs123 is online now
post #6 of 7 Old 05-21-2019, 07:09 PM - Thread Starter
blipszyc's Avatar
Quoted: 150 Post(s)
Liked: 78
The flat part looks to be about 6' wide. Was planning on using in-wall/in-ceiling speakers, so are you saying to put the atmos ones in the flat part and side surround speakers on the side walls?
4.0 - TBD
blipszyc is offline
post #7 of 7 Old 05-22-2019, 08:05 AM
sdurani's Avatar
Liked: 5874
Surrounds definitely on the side walls, around seated ear height or slightly above. Height speakers can be spread wide enough apart so that they're on the angled part of the ceiling, which would end up aiming them towards the listening area (that's not a bad thing).
Sanjay
sdurani is offline
