Drywall door?????? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-22-2019, 05:24 AM - Thread Starter
gazander's Avatar
Drywall door??????
If i have some left over 5/8, was thinking to do 3 sheets with green glue between. Just a thought, and i can also laminate in wood for durability and frame the edges....
gazander is offline
post #2 of 7 Old 05-22-2019, 06:17 AM
Quoted: 91 Post(s)
Liked: 45
X and Y forces are easy to visualize and minimize with good framing but doors experience a lot of torsional/twisting forces which are not intuitive. If you want to try for fun then make sure each side of the door has a very well fitted '2x4' X across the entire plane, like a large barn door, or sandwich the door between 2 sheets of plywood so you won't see the cracks. Now your door weighs 3 tons so plan on much stronger hinges, but the door will still sag over time so also plan on flexible weather stripping because door gaps is where you'll leak the most sound anyway.
cathodeRay is offline
post #3 of 7 Old 05-22-2019, 07:23 AM
Mocs123's Avatar
Quoted: 159 Post(s)
Liked: 58
Would Corning 703 be better than sheetrock?
7.1.4 Theater Room (In Progress): JVC-RS46U, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic DBT-110, JBL Studio 270’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne
Mocs123 is online now
post #4 of 7 Old 05-22-2019, 07:32 AM
Quoted: 36 Post(s)
Use MDF with GG. Its more dense.
Door creation is a tricky thing. You need to consider the swing and close gap as you thicken it and if needed a beveled edge for proper closure.
I created my door from a standard solid core and laminated 3 sheets of 5/8 MDF + GG and finish nails. Complete the surround with custom header and Frame. Complete the seal of the outside with rubber gasket jambs. You can get the jamb kit from SoundProofing Company online.
ID:	2570050   Click image for larger version
ID:	2570052   Click image for larger version
ID:	2570054   Click image for larger version
ID:	2570056   Click image for larger version
ID:	2570060   Click image for larger version
ID:	2570062   Click image for larger version
Video: Dedicated Light Controlled Room | JVC NX5 | 100" AT Silver Ticket 1.1 gain Screen
Audio: Sound Controlled Room | Denon X4500h running 5.1.4 | LR/Atmos - Pioneer SP-EFS73, Center - Pioneer SP-EC73, Rear/Atmos - Pioneer SP-EBS73-LR, Sub - SVS PC-2000
Sources: Nvidia Shield | Panasonic UB-820
smhunter1983 is offline
post #5 of 7 Old 05-22-2019, 07:33 AM - Thread Starter
gazander's Avatar
Yeah, thats a good idea... Don't think corning will work well, i had mass in mind.
gazander is offline
post #6 of 7 Old 05-22-2019, 12:51 PM
Quoted: 5550 Post(s)
Liked: 5142
Damped mass is good. Weight and hinge strength will be critical, it will sag over time. If you used a pre-hung door the screws are only jamb thickness long. They should be replaced with longer screws into the rough in framing. Maybe add more hinges, Total of two at top and two at bottom. Make sure you can still pull the pins. You will need to either move the door stop molding or deal with a door that is not flush with the wall by building up the molding around it depending on what side you add the layers. Just a heads up the door lock side of the door is tapered not perfectly square. It is very not noticeable but you need to take that into account in your planning.
post #7 of 7 Old 05-22-2019, 04:30 PM - Thread Starter
gazander's Avatar
thanks all
gazander is offline
