Full Circle Cinema Build - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 1507Likes
post #691 of 705 Old 05-05-2020, 07:24 PM - Thread Starter
pkinneb's Avatar
Quoted: 372 Post(s)
Liked: 1268
Didn't get much time today but I was able to mill up the frame parts, cut the miters, and dial them in with a hand plane and shooting board.
Tomorrow I will profile the edges (just a round over) and glue up the frame. Unless I get sidetracked with a new power tool that is supposed to be delivered
ID:	2721792   Click image for larger version
ID:	2721794   Click image for larger version
My Theater Build - Full Circle Cinema
Left over Supplies for Sale - For Sale
pkinneb is offline
post #692 of 705 Old 05-08-2020, 05:14 AM
DougUSMC's Avatar
Quoted: 771 Post(s)
Liked: 677
Beautiful work! What's that clamp?
DougUSMC is offline
post #693 of 705 Old 05-08-2020, 06:00 AM - Thread Starter
pkinneb's Avatar
Quoted: 372 Post(s)
Liked: 1268
Thanks! Its a MLCS 9012 Band clamp
https://www.amazon.com/MLCS-9012-Woo...s%2C176&sr=8-4
I actually bought it on sale last Nov, black Friday, and this was the first chance I got to use it. It works very well! If you have used a cloth strap one you know they are very hard to work with becuase they don't hold their shape the metal band on this one resolves that.
DougUSMC likes this.
pkinneb is offline
post #694 of 705 Old 05-08-2020, 06:07 PM
bluer101's Avatar
Quoted: 673 Post(s)
Liked: 923
Looking great. I don’t know where yours is located but with mine being on the exterior wall of my theater I used 4 small pieces of thin felt on the frame to keep it from rattling. Plus it helps for remove and install the frame.
pkinneb likes this.
bluer101 is offline
post #695 of 705 Old 05-08-2020, 07:32 PM - Thread Starter
pkinneb's Avatar
Quoted: 372 Post(s)
Liked: 1268
Thanks I was going to ask what you used between the TV and frame!! Ours is on an adjacent wall so rattling shouldn't be an issue but it will help remove it from the frame.
One of our huskies was getting into Jurassic World tonight
pkinneb is offline
post #696 of 705 Old 05-08-2020, 09:03 PM
b_scott's Avatar
Quoted: 569 Post(s)
Liked: 185
how did that Kilmat work on your pipes? I need something for my drain pipes but also my HVAC ducts.
b_scott is online now
post #697 of 705 Old 05-09-2020, 05:53 AM - Thread Starter
pkinneb's Avatar
Quoted: 372 Post(s)
Liked: 1268
So the quick answer is it helped but...with just the Kilmat you could still hear the water running down the main stack.
Now with the room complete Kilimat, rockwool, pink fluffy, double drywall, GG, and Oc703 you cannot hear anything even with nothing on in the room. I have become a believer in the fact that sound proofing/ superior audio in a theater is the culmination of many things and while doing some may help, to get the full benefit, you really need as many as possible. I would guess in my room I have about $4k (about 13% of the total build) into soundproofing and it is the single best decision I made for a couple reasons. First it’s not something that can be easily updated later and second I personally believe it has more to do with great sound in the room then the speakers, receivers/amps, etc which can all be upgraded over time.
pkinneb is offline
post #698 of 705 Old 05-09-2020, 06:14 AM
b_scott's Avatar
Quoted: 569 Post(s)
Liked: 185
Now with the room complete Kilimat, rockwool, pink fluffy, double drywall, GG, and Oc703 you cannot hear anything even with nothing on in the room. I have become a believer in the fact that sound proofing/ superior audio in a theater is the culmination of many things and while doing some may help, to get the full benefit, you really need as many as possible. I would guess in my room I have about $4k (about 13% of the total build) into soundproofing and it is the single best decision I made for a couple reasons. First it’️s not something that can be easily updated later and second I personally believe it has more to do with great sound in the room then the speakers, receivers/amps, etc which can all be upgraded over time.
Thank you!
pkinneb likes this.
post #699 of 705 Old 05-16-2020, 10:05 AM - Thread Starter
pkinneb's Avatar
Quoted: 372 Post(s)
Liked: 1268
Got the digital movie poster frame completed and installed. Really happy with how it turned out. A big thanks to @bluer101 for the great design! Just waiting on my MovieNow pkg to arrive so I can get that up and running.
I have also been playing with the automation. I added an Echo dot to the theater and have been getting it setup for both the Insteon lights and the Harmony hub. Still have work to do but its going to be awesome when dialed in.
Took the time to cut in an outlet to the back of the column. I have been meaning to do this for sometime but needed to vacuum and realized there are no easily accessible outlets, problem solved.
Most importantly we are enjoying the heck out of the room
In other basement news: I finally got my pool cue rack hung in the rec room
I'm off next week and if all goes well hope to finish the bar cabinets and counters...
ID:	2727110   Click image for larger version
ID:	2727112   Click image for larger version
ID:	2727114   Click image for larger version
ID:	2727124   Click image for larger version
pkinneb is offline
post #700 of 705 Old 05-16-2020, 10:28 AM
tjambro's Avatar
Quoted: 60 Post(s)
Liked: 167
That virtual poster looks great! Will be interested in your Alexa Insteon Harmony setup as I will be attempting the same. I may try to integrate it all into Home Assistant also.
Sent from my SM-N975U using Tapatalk
pkinneb likes this.
tjambro is offline
post #701 of 705 Old 05-16-2020, 03:34 PM
bluer101's Avatar
Quoted: 673 Post(s)
Liked: 923
Glad the poster designed worked for you too.
I have Alexa with Insteon and irule. I have to still put one of my echo dots in my column behind the fabric.
pkinneb likes this.
bluer101 is offline
post #702 of 705 Old 05-20-2020, 08:57 AM - Thread Starter
pkinneb's Avatar
Quoted: 372 Post(s)
Liked: 1268
Dart board cabinet done and installed. I will make and install the doors along with those for the bar. This marks a milestone in the basement there are no more unfinished openings
ID:	2729620   Click image for larger version
tortelvis, tjambro, sor and 7 others like this.
pkinneb is offline
post #703 of 705 Old 05-22-2020, 03:13 PM
A.T.M.'s Avatar
Quoted: 65 Post(s)
Liked: 93
Outstanding, as always.
Aaron
pkinneb likes this.
All ya need is love, and Hi Fi sound.
Asthetix, Audreal, Arcam FMJ, Musical Fidelity, Harmonix, Marantz, Tannoy, MIT, PS3, Sony Masters, OPPO
A.T.M. is online now
post #704 of 705 Old 05-24-2020, 07:29 PM
flynfish's Avatar
Quoted: 95 Post(s)
Liked: 54
Awesome build! Is your movie poster tv a 43in?
Sent from my iPhone using Tapatalk Pro
flynfish is online now
post #705 of 705 Old 05-24-2020, 08:31 PM - Thread Starter
pkinneb's Avatar
Quoted: 372 Post(s)
Liked: 1268
40”
flynfish likes this.
pkinneb is offline
