DreamWorks Theatre - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 2 Post By koolego
  • 1 Post By koolego
  • 1 Post By BIGmouthinDC
  • 1 Post By Luddy111dog
  • 1 Post By brazensol
  • 1 Post By mushroommunk
post #1 of 15 Old 06-06-2019, 05:44 AM - Thread Starter
Liked: 3
DreamWorks Theatre
Hello Forum Party Goers.
Well, the theatre is started after many years. Thus the name of this theater, DreamWorks home theatre!
By way of introductions, Mark is my name, I live on the Central Coast, New South Wales, Australia. It's about 1 hours drive north of Sydney. It all started when I was given a motorized drop down projector screen from work. In a very small room I set up a projector and audio system and I was hooked. At that stage we lived in what is called a Pole Home, while it had great views, I did not really have anywhere to set up a reasonable size room for a home theatre, when an opportunity came about, we moved into an older house on the flat ground that could be renovated and received official approval from management (my wife) to include a home theatre.
The good news, it is two small bedrooms and a hallway. This makes a size of 8 x 4 meters.
The bad news, in order to acquire this space, I had to keep the two windows so some window plugs maybe on the cards.
So it begins...
THEATER GOALS
Build a space to watch movies on a big screen just like or better than the movie theatres
Create a level of sound isolation however maximizing space suitable for:
- Watching Movies
- Kids playing xbox / games.
Maximize build space without losing too much space
A space that feels visually great to be in without going over the top on budget.
Ability to upgrade system components and cabling when required.
EXPECTATIONS
Build a great looking room with sound isolation without going over the top.
Complete the build in 6 months
EQUIPMENT SELECTION
Screen: Size is TBA
Screen Type: Acoustically transparent
Aspect ratio: ? 16:9 or 2.35 - Not sure at this stage
Projector: JVC DLA-X500B
AV: Denon AVC-X6500H
SPEAKERS
Front Speakers: 2 x Front Speaker - E 875 (to updated later).
Subs: 2 x E 8SUR.2 (to upgrade later)
Side/Rear Speakers: would like to DIY would need a forum help
Ceiling Speakers: as above
SOUND
Sound Config: 7.1.4 with front speakers & subs behind the screen
Sound Setup: Dolby atmos
SOURCES
Sources: Fetch TV, Xbox One X, Foxtel, Nvidia Shield
EQUIPMENT
Equipment location: Built open shelving in a separate room but may do a small rack for rear accessibility.
Automation: CBus Lighting. Blinds tab
Remote: Harmony Ultimate One
Seats: tba
ROOM DETAILS
Spaced: 7 x 4 meters (22 x 13 foot)
Seating: Two rows. The second row can be turned to face the back wall with TV and gaming. Turn back when friends over
Room within a Room type but not the full specs as I want to maximize space.
SOUND ISOLATION
Building isolation framework inline with Mass, Air Space, Sealing and Decoupling approach without going full on.
Walls: Older house with 3 extensions added on over time with different wall thickness and wood type including hardwood, decided it would be easier to a room within a room.
Drywall:16 mm by 2 sheets (all 15 mm seems to be 16mm fyrchek and expensive)
Glue: Started with Quiteglue pro on outer skin however it seems to run
Windows: Removal wall plugs (ahhh - wife factor)
POWER LOCATIONS
Behind Screen front wall
Base shakers & seating
Columns
Back wall
LIGHTING
Maybe around columns LED
Sofits down lighting
Onto ceiling from sofits
TBA other locations
OTHER
Painted Star lighting
Name:	Screen Shot 2019-06-01 at 10.03.59 PM.png
ID:	2576588   Click image for larger version
ID:	2576590   Click image for larger version
pkinneb and sirjaymz like this.
koolego is offline
post #2 of 15 Old 06-16-2019, 03:05 AM - Thread Starter
Liked: 3
Removing the Gyprock & Installation
After knocking out the walls between the rooms to create a larger space, we have started stripping out the gyprock from walls and ceiling.
The gyprock is the old horsehair gyprock, heavy, we bent it 90 degrees and it still will not break the house was built back in the 1950's some time I believe.
The worst part was all the loose installation used in the roof, we counted 31 large bags.
ID:	2580666   Click image for larger version
pkinneb likes this.
koolego is offline
post #3 of 15 Old 06-16-2019, 07:28 AM
Quoted: 40 Post(s)
Liked: 50
Wow that looks like it was fun. Nice job
My Theater Build - Full Circle Cinema
pkinneb is online now
post #4 of 15 Old 06-21-2019, 11:33 PM - Thread Starter
Liked: 3
Room gutted - problems found.
After gutting the room, we have identified a few areas of interest we are going to have to work on.
Its like a little surprise package, you never know what you are going to find.
Problem one
Sound isolation: The gaps between the frame and outside weatherboard.
Problem Two
Sound isolation: The gap also between the theatre room and the level above. Will need to be blocked off with gyprock.
Problem three
Floor level from removing the internal walls for the two bedrooms and the hallway will need to use some floor leveling.
Problem four
Walls are not aligned. You can see the difference in wood from the early building standards with hardwood (the dark wood), guessing this was used in the mid 19th century. The brown wood is softwood towards the end of the 19th century and the green is what is in use today.
This will be a good reason to double stud wall internally.
ID:	2582994   Click image for larger version
ID:	2582996   Click image for larger version
ID:	2582998   Click image for larger version
koolego is offline
post #5 of 15 Old 06-22-2019, 05:32 AM
Luddy111dog's Avatar
From one Aussie to another.....go for the throat mate & don't hold back.
What's your time frame on the build? I started mine around Xmas thinking it would be a 6-week turnaround but I'm thinking now around when "Bathurst" starts. For those outside of Australia, BATHURST is a town 250k west of Sydney that host the best car-race in the world. Here's a snippet from last years race for those who love V8's. Turn on your theatre. Crank up AMP --->
This race is held annually on the 1st week of October....& its 163 laps. The race shown above are only the Golden Oldies. The SUPERCARS reach 300k or over 180 miles an hour around this track.
Talk soon, Mark.
Regards, Steve ;-)
Luddy111dog is online now
post #6 of 15 Old 06-22-2019, 08:57 AM
brazensol's Avatar
Quoted: 706 Post(s)
Liked: 528
There some seriously nice vintage iron in that video!
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP's; (3) HTM-12's; (14) RSL C34e surrounds; (2) 18" Dayton Audio RSS460HO-4 Subwoofers; (1) Dayton Audio UM18-22 18" Ultimax Subwoofer; (4) Dayton Audio RSS390HO-4 15" Reference HO Subwoofers
brazensol is offline
post #7 of 15 Old 06-24-2019, 05:19 AM - Thread Starter
Liked: 3
Hey Steve,
Go Bathurst, some amazing video, that would sound awesome in a good theatre, I have in fact done 5 laps with Craig Lowndes at Oran park (the track was not as good as Bathurst) in his V8 Supercar. It was hot, around 60 degrees (140 Fahrenheit) in the car with a fireproof suit on, I can say, it scared the tuck out of me, it was some time ago, I think we got up to around 260km (160 miles) per hour. I dont know how they drive for any more than 15 mins at a time.... amazing people.
Time frames, well, its the sound isolation that's killing me, extremely time-consuming. I would say within 5 months, I am learning along the way, have made a couple of mistakes, and had to redo some areas. (weekend work only)
Will have to post some more photos and work from the weekend.
Love to hear another Aussie, will have to jump onto your thread.
Thanks for saying hello Steve.... :-)
Mark
koolego is offline
post #8 of 15 Old 06-28-2019, 05:24 AM - Thread Starter
Liked: 3
Framing
We started to frame up the inner wall however we have done this a little different.
To maximize space we turned the studs and noggings flat, we could not do this around the doors clearly. This allowed us to get the space needed, removed the problem with uneven walls and provided some separation for sound. Stud Wall Sound Isolation Mounts used, I will need more for the top half of the wall.
The builder did not know or misheard we are planning to cut off the roof joists to disconnect them from the outer wall. With the top plate not strong enough to hold the joist, we are now moving to clips and hat channels for the roof.
Doh. In any event, the silver lining is we will get some extra hight.
You can also see we have started sealing up the gaps between floors with double layer gyprock and glue. Man, this is taking a lot of time to do by the time you frame it up, cut the gyprock to fit and then quite glue.
Glue, well I picked up some non-Green glue (name not provided) as it was cheaper and had the same specs as Green glue, it worked very well however, it runs if you use too much, a lot. And it's very hard to clean up regardless of what chemical you use . I have enough to treat the outer wall however will be switching to green glue.
A couple of learnings here, I guess I will have a few more by the time the job is done. That's to be expected for an office worker.
Double solid core doors 40mm (1.6 inch) hang.
Outer ceiling gyprock has also started, this section is the roof and not upstairs of the house, noggin blocks and sealant to seal up the gaps at the bottom, it's more to stop noise coming in, not from going out. Will need to frame up the ceiling joints when completed.
Its a lot of work, I know it does not look like it, but it is. I think while I am in the room myself working away, I could be hearing voices "If you build it, they will come" (Fields of Dreams)
koolego is offline
post #9 of 15 Old 06-28-2019, 05:43 AM
Quoted: 5547 Post(s)
Liked: 5139
Actually it is "if you build it, you hope they don't come so you can enjoy it without interruptions, or sticky fingers touching everything"
koolego likes this.
post #10 of 15 Old 07-16-2019, 03:48 AM - Thread Starter
Liked: 3
Help with DIY Sound Group Speakers
Looking for help regarding speaker recommendations.
While I can research lots of information to educate myself on many great posts on this forum, speakers become a completely new world of wonder and imagination.
A number of theatres have used the DIY Sound Group speakers to provide some great results however I am finding it really hard on their site to identify what would work for my home theatre.
Understandably, this would be how big is your wallet, everyone is different and I don't want to recommend something you may not be happy with, however, I can make my own decision at the end of the day however I don't know where to start.
AV would be Denon AVR-X4500H or AVC-X6500H
Atmos 7.1.4
To provide any recommendations, I know you would need some information about my room, so I have attached my Sketchup, its around 24 MB.
https://www.dropbox.com/s/2e4xth1vay...inchs.skp?dl=0
The red boxes are speaker locations. Sketch up is to scale. Even if I get no replies, maybe this will help other people thinking of using sketch up to create a home theatre.
It would be awesome to get some feedback, all feedback is good feedback however if you get too techie, you lose me.
Fire away...
koolego is offline
post #11 of 15 Old 07-16-2019, 05:43 AM
Hi Mark.
I forked out a fortune for 10 PSB speakers & subs....& a pair of niles ceiling speakers. I'm telling you there's no substitute for quality.
My advice is don't skimp on the subbie if you can't afford to spend good money on the others up front....or you could do what I did & buy a couple of pairs at a time. It took me a couple of years to get what I've got now....& it was worth it.
Check this site out to get a feel on whats what ---> https://www.todds.com.au/collections/hidden-speakers
PS.....Your projecter is too far back. Around 4 1/2 to 5 metres from the screen bro.
koolego likes this.
post #12 of 15 Old 07-16-2019, 07:56 AM
brazensol's Avatar
Quoted: 706 Post(s)
Liked: 528
Our rooms appear to be similar in size. I'm running DIYSG HTM-12's and couldn't be happier with them. Best bang for the buck you'll find. Also built my own subs - 4 15's and 3 18's.
koolego likes this.
Denali Cinema
post #13 of 15 Old 07-16-2019, 08:31 AM
Quoted: 105 Post(s)
Liked: 99
I've also got a similar sized room. I went HTM-10 mains and volt-6 surround. You really can't go wrong with the HTM's. I find I don't need the volt-10's or the htm-12s. The 10's get low enough and loud enough to cross over to my IB sub with 6 15's. I don't miss that extra 3dB sensitivity I don't think personally.
koolego likes this.
mushroommunk is offline
post #14 of 15 Old 07-17-2019, 05:14 AM - Thread Starter
Liked: 3
Thanks, what are 4 15's ? is this 4 x 15 inch subs? are theses DIY that sits under the surround and rears?
How do I find out more?
koolego is offline
post #15 of 15 Old 07-17-2019, 06:50 AM
brazensol's Avatar
Quoted: 706 Post(s)
Liked: 528
Yes (4) 15" subs. Head over to the DIY Speakers and Subs area for tons of info on the DIY world.
Denali Cinema
