wiring AC to DC led lights help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-18-2019, 11:39 AM - Thread Starter
Quoted: 277 Post(s)
Liked: 146
There might be other forums for this, but I don't belong to them and some of you guys are wildly knowledgeable to here goes.
I have some under cabinet halogen ac lighting that I want to switch LED strip lighting. AC to transformer to controler to strip is the easy part. There are 3 separate light fixtures controlled by 1 switch. Would I need to put a transformer at each fixture? Would I have to put a controller at each fixture? If so, would there be a way to link the 3 controllers together?
I haven't pulled the switch off the wall yet, so Im unsure exactly how it is wired.
Marantz SR7010 - Emotiva XPA-3 Gen 3 - SeymourAV 16:9 Premier 130" XD - JVC DLA-RS540 - 7.2.4 - L/C/R DIY Fusion 15 Sentinel - Surrounds RSL CG3 - Ceiling Polk RC80i - Dual UM-18s in sealed 4 cu ft with bridged Crown XLS 2002s
klimo is offline
post #2 of 9 Old 06-18-2019, 11:48 AM
Quoted: 5535 Post(s)
Liked: 5129
one controller and transformer is usually good for 15 ft of LED strip lighting. Refer to the specifications and instructions of your brand and model. If your LEDs are a two wire design you might be able to use any existing jumper wires xonnecting one lighted cabinet to tne next as jumpers for the LEDs with the right adapters. This problem has a lot of unknowns.
post #3 of 9 Old 06-18-2019, 11:51 AM - Thread Starter
Quoted: 277 Post(s)
Liked: 146
I probably asked my question poorly.
There are currently 3 light fixtures with power going to each one of them. Once I put the transformer in the line, does that step down all 3 or just the one? The led strips would not be connected to each other, except for the AC power running to each one. Would I then need to put a controlled at each separate led strip?
klimo is offline
post #4 of 9 Old 06-18-2019, 11:57 AM
Liked: 5129
depends if your wiring is currently daisy chained or individual home runs to a power source. If a wire runs from one cabinet to the next if you intercept it before the first cabinet with a transformer everything else will on the same voltage. Is your LED a two wire system or multi-color 4 wire?
post #5 of 9 Old 06-18-2019, 12:03 PM - Thread Starter
Quoted: 277 Post(s)
Liked: 146
Ok. That was sort of what I was thinking. I’ll have to see if they are daisy chained or all sent individually to the switch/power.
The LEDs are rgbw
klimo is offline
post #6 of 9 Old 06-18-2019, 12:26 PM
Liked: 5129
Originally Posted by klimo View Post
The LEDs are rgbw
that would mean 4 wire connections, you won't be able to use any existing 2 wire line voltage wire other than for 120v power connections to a switch. You will probably need a transformer/controller at each cabinet and leave the existing wall switch in place. The best you can hope for is your handheld remote will control all the strips simultaneously. The system should have memory so if you pick a color the wall switch will turn them on and off at that color until you change it.
post #7 of 9 Old 06-18-2019, 12:28 PM - Thread Starter
Quoted: 277 Post(s)
Liked: 146
Ok. Sounds good.
Thanks BIG!
klimo is offline
post #8 of 9 Old 06-18-2019, 12:31 PM
Liked: 5129
unless you can fish 4 wire jumpers in the walls, cabinet to cabinet. Or up in crown molding.
post #9 of 9 Old 06-18-2019, 12:37 PM - Thread Starter
Quoted: 277 Post(s)
Liked: 146
That might be a real option. going cabinet to cabinet.
klimo is offline
