Wireless electrical outlets? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By tjambro
  • 3 Post By weavinator
  • 1 Post By pkinneb
post #1 of 16 Old 06-26-2019, 07:00 PM - Thread Starter
blipszyc's Avatar
Quoted: 153 Post(s)
Liked: 79
My wife would like me to hang a couple lighted posters on walls that are pretty far from a light switch. I can easily tie into an existing outlet for power, but need a way to turn the outlet on/off.
Any recommendations for a wireless outlet that can be controlled via a smart app and/or a wireless switch, preferably one that looks like a normal switch. I don’t have anything like a smarthub or Alexa or Google Home, so it needs to be able to be controlled without those.
I do have a couple Smarthome 2477 switches lying around. Not looking to necessarily reuse these, so open to anything.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
4.0 - TBD
blipszyc is offline
post #2 of 16 Old 06-26-2019, 07:10 PM
ManMower's Avatar
Liked: 25
Would something like https://www.amazon.com/Lutron-Wirele...QG0/ref=sr_1_9 do what you want?
The pico remote can be mounted to the wall with a kit (surprise, you get to buy that too) that makes it look just like a normal Lutron switch.
The remote will pair with the dimmer without the need for their hub.
ManMower is offline
post #3 of 16 Old 06-26-2019, 07:28 PM - Thread Starter
blipszyc's Avatar
Quoted: 153 Post(s)
Liked: 79
Thanks for the recommendation. I actually don’t have the outlet wired into the wall yet...and I only need on/off, not dimming, but perhaps Lutron has what I need in another product.
4.0 - TBD
blipszyc is offline
post #4 of 16 Old 06-27-2019, 05:22 AM
tjambro's Avatar
Quoted: 35 Post(s)
Liked: 100
If the posters will be hardwired and are deep enough you could add a simple toggle or push button switch to the poster box and just turn it on or off as needed. I did just this in my last theater's lobby. I wanted one more poster that couldn't be wired to the existing wall switch so I just installed a small push button switch on the bottom of the case that you couldn't see unless you bent down and looked for it. I tied into the romex for a nearby outlet.
Tom
Tedd likes this.
tjambro is offline
post #5 of 16 Old 06-27-2019, 06:31 AM
impreza276's Avatar
Quoted: 511 Post(s)
Liked: 765
Searching amazon for "remote power outlet" returns a ton of results such as this: https://www.amazon.com/Etekcity-Cont...gateway&sr=8-4
impreza276 is offline
post #6 of 16 Old 06-27-2019, 07:41 AM
thrillcat's Avatar
Quoted: 551 Post(s)
Liked: 517
I've had excellent luck with these, and they connect directly to your WiFi without requiring a hub setup. They sell a 3-pack, too.
https://www.amazon.com/iDevices-Swit.../dp/B00U31IO3Q
I love my iPhone, but it will never replace my turntable. I've never seen Titanic OR XXXXXXXXX. Alexa is a stripper name.
The Cinema 1858 Remodel Thread
thrillcat is online now
post #7 of 16 Old 06-27-2019, 08:58 AM
weavinator's Avatar
Quoted: 42 Post(s)
Liked: 86
I'm a fan of Insteon. You could use either a switched outlet or a plug-in relay with a mini remote mounted to the wall. No hub needed unless you want to control it from your phone.
BIGmouthinDC, pkinneb and sirjaymz like this.
weavinator is online now
post #8 of 16 Old 06-27-2019, 11:50 AM
sirjaymz's Avatar
Quoted: 481 Post(s)
Liked: 578
https://www.smarthome.com/promotions/insteon.html
This is where I get my Insteon gear...
EDIT: They usually have deals during holidays.. like the one coming in a couple of days.
HT1.0 | HT2.05
JVC RS-2000 / Seymour AV Center Stage 130"diag, 2.35 / nVidia Shield
11.2(22).6 Atmos / Denon 7200WA / Denon 6300 / 2x miniDSP2x4HD / DIY treatments
2x NU6000DSP / 2x NU3000DSP / 2x Klipsch R-112SW / 4x UM18-22 / 4x PA-460 / 12x JBL 12"
Klipsch RF-82/RC-64II/RS-42/RS-41/BS-62/CDT3800-C-II
sirjaymz is online now
post #9 of 16 Old 06-27-2019, 12:00 PM
weavinator's Avatar
Quoted: 42 Post(s)
Liked: 86
I usually buy from Smart Home (they're the manufacturer) because they have deals and you earn rewards. I've also found good warehouse deals on Amazon.
post #10 of 16 Old 06-27-2019, 02:35 PM
Quoted: 134 Post(s)
Liked: 371
I picked some addl needs up yesterday 50% off through 6/28
sirjaymz likes this.
My Theater Build - Full Circle Cinema
pkinneb is offline
post #11 of 16 Old 06-30-2019, 04:27 PM - Thread Starter
blipszyc's Avatar
Quoted: 153 Post(s)
Liked: 79
Has anyone used one of these? GE Remote Switch
Was hoping to take apart the remote switch and mounting it with my other wired switches.
4.0 - TBD
blipszyc is offline
post #12 of 16 Old 07-01-2019, 10:41 AM
elitemikes's Avatar
Quoted: 44 Post(s)
I have a variety of smart stuff in my home. My theater is entirely insteon, but in other ares I have zwave GE devices. I don't have this, but if i wanted a smart outlet I'd do this https://www.amazon.com/GE-Receptacle...gateway&sr=8-3
For ares where I do have switched plugs, i use the plugin modules. My under cabinet lighting was done with plugins instead of replacing the outlet. There are many wifi ones out there. Most good systems require a hub to control the devices. This has nothing to do with voice control.
What you posted may work just fine for your needs. For that price, try it and return it if not.
elitemikes is offline
post #13 of 16 Old 07-01-2019, 11:09 AM
Mocs123's Avatar
Quoted: 235 Post(s)
Liked: 119
Do these work with a Harmony Hub? They don't seem to be listed as compatible devices, so I assume not.
7.4.4 Theater Room: JVC-RS46U, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic DBT-110, JBL Studio 270’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne
Mocs123 is offline
post #14 of 16 Old 07-01-2019, 11:10 AM
thrillcat's Avatar
Quoted: 551 Post(s)
Liked: 517
I don't think so, but my Harmony only controls my theater, and I don't have any of these in there, so I haven't tried it.
post #15 of 16 Old 07-01-2019, 05:41 PM - Thread Starter
blipszyc's Avatar
Quoted: 153 Post(s)
Liked: 79
I looked at those, but would probably want some sort of remote switch to control it. Insteon has what would work, but I'd have to spend nearly $200 for my setup (3 lighted posters, 2 switches). The Lutron Caseta looked promising, but the lamp module only is 2-prong and my posters are 3-prong. (Could probably unground the poster boxes if needed)
4.0 - TBD
blipszyc is offline
post #16 of 16 Old 07-02-2019, 10:41 AM
elitemikes's Avatar
Quoted: 44 Post(s)
Understandable. I went with the wink hub 2 originally. It allows me to pick just about any device I want except for insteon. I can use a lutron pico remote to turn on any wireless outlet now. I
