step/riser lights - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By texpilot
  • 3 Post By sassuki
  • 1 Post By elitemikes
post #1 of 6 Old 07-04-2019, 12:12 PM - Thread Starter
elitemikes's Avatar
Quoted: 44 Post(s)
step/riser lights
For those of you that have lights to light up the riser steps. Do you leave them on all times? are they dimmable? Are they on a photo cell?
I just bought 2 of these https://www.lowes.com/pd/Eaton-White...r-2-in/3447528 and they are too bright. I am considering at least putting them on an insteon on off relay https://www.insteon.com/on-off-in-linelinc so i can at least turn them off during the movie
elitemikes is offline
post #2 of 6 Old 07-04-2019, 01:15 PM
texpilot's Avatar
Quoted: 232 Post(s)
Liked: 130
In my experience you definitely want them in a dimmer. Turning them entirely off during the movie is a safety hazard if someone wants to get up during a dark scene.
I’m very pleased with my Insteon dimmers, they are able to dim quality LEDs very very low. That said, I have yet to try my IR to Insteon “bridge” device, and if it doesn’t work I’ll have to use a separate Insteon remote rather than my programmable URC remote, but that’s okay with me. Just want you to be aware.
elitemikes likes this.
texpilot is offline
post #3 of 6 Old 07-04-2019, 01:41 PM
sassuki's Avatar
Quoted: 88 Post(s)
Liked: 195
I haven’t tried them on a dimmer yet, but these are what I used:
https://www.legrand.us/radiant/produ...horztccc6.aspx
I really like the look of them, and even without a dimmer switch, they have the ability to set the brightness (5 levels) by tapping on them. You really don’t need much when in a light controlled room.
texpilot, elitemikes and sirjaymz like this.
sassuki is offline
post #4 of 6 Old 07-04-2019, 04:04 PM - Thread Starter
elitemikes's Avatar
Quoted: 44 Post(s)
I wish i would have known about these. Maybe I'll try and return the 2 i just bought from Lowes.
post #5 of 6 Old 07-27-2019, 06:08 AM - Thread Starter
elitemikes's Avatar
Quoted: 44 Post(s)
I finally installed these last night and they work great. Sadly I think they'll always be on when the louver is on, but I'm not concerned about electrical usage. Thanks for directing me to these.
sassuki likes this.
post #6 of 6 Old 07-28-2019, 12:34 PM
sassuki's Avatar
Quoted: 88 Post(s)
Liked: 195
Good to hear! Glad you like them.
sassuki is offline
