Multiple TV Setup with 1 Audio Output Suggestion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-17-2019, 07:38 PM - Thread Starter
BoostedRS's Avatar
Question Multiple TV Setup with 1 Audio Output Suggestion
Hi everyone,
I did some searching but apologize but was unable to find the answer to my question.
I'm looking to do a Home Theater setup with 3 TV's in one room and wanted to find out what equipment would be needed to streamline my setup.
TVs
My plan most likely is to get (1) 65" LG B8/C8 OLED as the center TV and to do (2) 55" Vizio P series' on each side of the 65".
Audio
This is still up in the air but I'm possibly doing a Nakamichi 9.2 setup or going with a full receiver setup.
Devices
Xbox One
PS4
Firestick
DirecTV
My plan would be to use this mostly to watch sporting events so I could view multiple games at once on each of the TV's. I would like to be able to switch any of the devices on any one of the TV's but wouldn't need to display the same thing across multiple TV's at any point. I would only be using the audio for 1 TV at once but would like the possibility to be able to switch it to another TV if a commercial or important play was happening during one of the other games. Is this a possibility? I have done a little research into HDMI Matrix's and understand I would need one of these to switch the outputs to each of the TVs. What is the easiest way to set this up and how would I allow the audio to be switchable?
Thanks for the input!
BoostedRS is offline
post #2 of 9 Old 07-17-2019, 07:46 PM
impreza276's Avatar
Quoted: 506 Post(s)
Liked: 756
Feed the optical audio outs from your TVs to your receiver as a different source for each. You are then free to switch between them.
impreza276 is offline
post #3 of 9 Old 07-17-2019, 07:59 PM - Thread Starter
BoostedRS's Avatar
This would be the method if I had a 7.2 Receiver, correct? What if I had a sound bar?
post #4 of 9 Old 07-18-2019, 04:39 AM
Quoted: 5838 Post(s)
Liked: 5402
then if you use the optical audio outputs from the TVs you need an optical audio switcher to select one for the soundbar assuming it has an optical input. Here is a 3x1 for $20. https://www.amazon.com/ViewHD-TOSLIN.../dp/B00G188Z7A
I'm wondering how you are going to get 3 independent sports channel feeds to each of your TVs with the list of gear you provided.
post #5 of 9 Old 07-18-2019, 07:26 AM - Thread Starter
BoostedRS's Avatar
Great, thanks! That makes a lot of sense and I didn't think about that previously.
As far as the 3 independent sports channel feeds, that is still up in the air. If I have DirecTV I will be able to login in to the ESPN App, Sunday Ticket, etc on one of the other TV's not utilizing the DirecTV box and stream a game, etc. I would like to have 3 DirecTV boxes to streamline it and be able to easily watch but not sure I want the added expense and there is no way around that to my knowledge?
post #6 of 9 Old 07-25-2019, 09:00 AM - Thread Starter
BoostedRS's Avatar
Any other thoughts please? Recommendation on HDMI Matrix? Should I get a Harmony Elite remote?
post #7 of 9 Old 07-25-2019, 09:09 AM
Quoted: 102 Post(s)
Liked: 137
I just got one and while it is nice to have everything in one remote, this remote is extremely laggy and I hate that...
PreciseD is offline
post #8 of 9 Old 07-25-2019, 09:17 AM - Thread Starter
BoostedRS's Avatar
Ahh man! I hate to hear that. I thought it would make everything more seamless and streamlined.
post #9 of 9 Old 07-25-2019, 09:21 AM
Quoted: 102 Post(s)
Liked: 137
Nope! It is one of the biggest complaints in the all reviews too, but it does allow me to control the video outputs with my receiver and can control my drop down screen... It is laggy when changing channels with my Roku Ultra.. So when I am browsing it doesn't move and then it moves too much.. It is also laggy when trying to adjust my Epson 5040 lens. I am also impatient and get click happy with remotes, so it could be a user issue lol..
PS if you do get it save yourself some money and buy it "used" on amazon. Mine came brand new for $190
PreciseD is offline
