Smallest reciver available? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By corradizo
  • 1 Post By LeoRavus
post #1 of 8 Old 07-22-2019, 03:05 AM - Thread Starter
Liked: 0
Alright guys,
I'm Adding a cinema to my basement and require the smallest Av system i can get my hands on.
System so far is as follows
Benq w2700
2 x Monitor audio Wss430
1 x W10 Subwoofer.
Ill be running a 2.1 configuration with 2 main sources, My issue is the unit i wish to house the system is only 26 cm (260mm) Deep
So far I'm Stumped, short of putting a slim line Av system on its side which is hardly ideal im out of ideas?
Can any one help
Cheers
Dave.
davetrials is offline
post #2 of 8 Old 07-22-2019, 03:12 AM
JRock3x8's Avatar
Quoted: 1796 Post(s)
Liked: 557
Maranta makes a "slim" receiver
JRock3x8 is offline
post #3 of 8 Old 07-22-2019, 03:55 AM - Thread Starter
Liked: 0
whats everyone's thoughts on using an AV receiver on its side? there's no vents so breathing wont be an issue?
(just realized i miss spelled receiver in the title )
post #4 of 8 Old 07-22-2019, 12:27 PM
Quoted: 37 Post(s)
Liked: 54
I run my Denon 4400 on it's side for now. I am using it in my living room and my cabinet is not deep enough for it.
PS..
You might have better luck posting in the Audio/Receivers section not the dedicated home theater one..
PreciseD is offline
post #5 of 8 Old 07-22-2019, 04:25 PM
corradizo's Avatar
Quoted: 1530 Post(s)
Liked: 1589
Cut the back out. This is how I got my days Onkyo to fit. Helps keep it cool also. It was tough (mentally) to take a skill saw to a brand new piece of furniture but the wife is happy as can be.
LeoRavus likes this.
corradizo is online now
post #6 of 8 Old 07-22-2019, 04:57 PM
Mocs123's Avatar
Quoted: 172 Post(s)
Liked: 74
I doubt you will find something that shallow. Most everything I see is at least 12.5" deep and then you still need some room behind for cables, etc.
7.1.4 Theater Room (In Progress): JVC-RS46U, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic DBT-110, JBL Studio 270’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne
Mocs123 is offline
post #7 of 8 Old 07-25-2019, 07:19 AM
chirpie's Avatar
Quoted: 391 Post(s)
Liked: 564
Trying to think outside the box... what about something like these as a combo? Then they fit easily. The only issue is no dedicated sub output and would require the sub to have the crossover.
https://www.monoprice.com/product?p_...SABEgKVvvD_BwE
plus
https://www.monoprice.com/product?p_...SABEgKiuvD_BwE
use a headphone to rca cable out of the side, done.
EDIT: Eh, no easy volume control with that setup. Guess I should keep digging.
chirpie is offline
post #8 of 8 Old 07-25-2019, 09:53 AM
Quoted: 28 Post(s)
Liked: 8
Funny, I'm in the process of doing the same thing to my stand to make my giant old faithful Onkyo fit after installing banana plugs and have the same furniture sliders under the feet. I'm leaving them there since it makes it so much easier to move and get to everything.
Sorry not to add more to the discussion but I feel like it's a good idea now.
corradizo likes this.
LeoRavus is offline
