Custom rack - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By TexmasterPEB
  • 2 Post By bluer101
post #1 of 5 Old 07-23-2019, 07:26 AM - Thread Starter
Quoted: 63 Post(s)
Liked: 33
Custom rack
I would like to rack mount my gear, and my best option to do so is by creating a recess in a false wall. Its plenty deep, I can get power to it and cables from it, and heat out of it.
My question is how do I accomplish the rack itself? Can I just mount vertical rails at the front at the proper width, and be done? If so, where can I get the rails? I would need 20RU of rail. Also, they would be anchored into 2x4s so they will be secure.
bluer101 likes this.
TexmasterPEB is offline
post #2 of 5 Old 07-23-2019, 08:58 AM
Quoted: 5739 Post(s)
Liked: 5299
I think you would want to dress up the hole in the wall and bare 2x4 with some finish grade trim molding before attaching the rails. Measurement of rail spacing will be critical. Here is one source of rails, there are many.
https://www.parts-express.com/penn-e...-4725--262-396
post #3 of 5 Old 07-23-2019, 09:03 AM - Thread Starter
Quoted: 63 Post(s)
Liked: 33
Of course the cavity would be finished out w sheetrock and trim. I was just stating that the rack rail would be securely anchored.
post #4 of 5 Old 07-23-2019, 09:08 AM
sirjaymz's Avatar
Quoted: 445 Post(s)
Liked: 532
I used one of these in HT1.0, and it installed very nicely in a space you described. They are not the cheapest in the world, but definitely work really well.
middle atlantic srsr-4-20
HT1.0 | HT2.05
JVC RS-2000 / Xbox One X / nVidia Shield / DIY treatments
Seymour AV Center Stage 130" 2.35 / Denon 7200WA / Denon 6300 / 2x miniDSP2x4HD
2x NU6000DSP / 2x NU3000DSP / 2x Klipsch R-112SW / 4x UM18-22 / 4x PA-460 / 12x JBL 12"
11.2(22).6 Atmos/Klipsch RF-82/RC-64II/RS-42/RS-41/BS-62/CDT3800-C-II
sirjaymz is offline
post #5 of 5 Old 07-23-2019, 06:39 PM
bluer101's Avatar
Quoted: 634 Post(s)
Liked: 723
I used middle Atlantic rack rails and a plywood frame. Then bought all the custom component shelves and faceplates.
My rack rails.
https://www.bhphotovideo.com/c/produ..._Rackrail.html
BIGmouthinDC and pkinneb like this.
bluer101 is offline
