Quoted: 4748 Post(s)
Liked: 2780
Originally Posted by
genaccmiller
Yes got it. By two step process I meant drilling a hole big enough for hand to get in and second hole to poke to pull the wire out. This will be followed by patching the first hole made. Does not seem insurmountable. I will look at some YouTube videos. The painter is applying only the first coat this weekend.
Sent from my Moto G (5) Plus using Tapatalk
Do not drill a hole. You have to cut the drywall with a skill knife and preserve the piece of drywall to put it back into place. Drilling will only destroy the drywall. You'll probably have to cut a small hole above the pieces of wood support or you'll never be able to reach in to pull on the wire.
You made a mistake and will just have to do the best you can to fix it.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
