AT (Acoustically Transparent) Theater build thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 251Likes
post #541 of 998 Old 10-24-2019, 04:25 PM - Thread Starter
genaccmiller's Avatar
Quoted: 731 Post(s)
Liked: 165
Originally Posted by PreciseD View Post
https://www.fabric.com/find?SearchTe...etic+Mesh+Knit
I bought this stuff in black and charcoal. I signed up for emails to get a 10% off coupon too..
easier pill to swallow than that stuff that is $10-11 a yard...
How easy was it to wrap the panels and how are the acoustic properties?
Sent from my Moto G (5) Plus using Tapatalk
genaccmiller is offline
post #542 of 998 Old 10-24-2019, 04:28 PM
Dan Hitchman's Avatar
Quoted: 4752 Post(s)
Liked: 2782
If you have left and right speakers and subs behind the false wall (with center through an AT screen), you want transparent fabric. GOM FR701 black is a known commodity... if you want to be on the safe side. You don't need a hell of a lot (unless you want to use the excess for DIY acoustic absorption and diffusion panels).
The top panel can be dark black, non-shiny velvet. There are countless threads on which kind is good enough for the money.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #543 of 998 Old 10-24-2019, 04:42 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
Is this the one you are recommending?
https://www.guilfordofmaine.com/swatches/2100-408
AT properties seem great per the attached.
Rjloper9 likes this.
post #544 of 998 Old 10-24-2019, 04:46 PM
Liked: 2782
Yup.
post #545 of 998 Old 10-24-2019, 04:49 PM
Quoted: 6043 Post(s)
Liked: 5621
FR701 is a well known fabric used by award winning internationally recognized theater designers. GOM also has other fabrics with similar performance. It also has a fire safety rating meeting the demands for commercial public spaces, many fabrics do not.
Rjloper9 and pkinneb like this.
post #546 of 998 Old 10-24-2019, 05:26 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
With the red wall and black ceiling the four can lights are ok but not bright enough. I have asked the contractor to stop by for an estimate on additional lights tomorrow. He says they will need to cut up drywall to install. Any recommendations on what additional lighting is better?
post #547 of 998 Old 10-24-2019, 05:28 PM
Liked: 5621
it this a theater or a library? How many will you have on during a showing?
Dan Hitchman, PreciseD and pkinneb like this.
post #548 of 998 Old 10-24-2019, 05:32 PM
Liked: 2782
You only need enough light not to trip and fall on your rear.
post #549 of 998 Old 10-24-2019, 05:40 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
I think I have more than enough light for that.
post #550 of 998 Old 10-24-2019, 05:42 PM
Quoted: 238 Post(s)
Liked: 250
Put brighter lights in the cans if it's a problem.. I wouldn't add more..
PreciseD is offline
post #551 of 998 Old 10-24-2019, 07:36 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
Theater plus a place where I can lounge and listen to music while reading a book. Depending on type of furniture, I could decide the number of seating. Need to figure out what furniture to buy. Basement entry is standard sized door which goes down three steps to a landing and turns right. So furniture needs to be able to turn at that area.
post #552 of 998 Old 10-24-2019, 09:03 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3903 Post(s)
Liked: 1816
If you purchase Theater Seating, virtually all types come in two pieces...the Seat and the Back. You should have no issues taking any seating down the staircase if it is unboxed.
You have little choice as far as the number of seats....as I stated long ago, the most you can get in that space is 4 abreast and still have any decent amount of traffic area along the sides. (seating will range between 120" to 135" wide)
If you purchase 90 Watt Halogen Spots or (yuck) Floods, you should have no issues with having enough lighting....but you will need a Dimmer such as a Lutron Maestro of similar.
Please don't let yourself be convinced you need additional lighting............if you equip the front Cans with Eyeball Lenses and direct the light toward the seating, you not going to be poorly illuminated.
pkinneb likes this.
MississippiMan is offline
post #553 of 998 Old 10-24-2019, 09:11 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
Thanks. I did not know they come in two pieces.
post #554 of 998 Old 10-25-2019, 08:08 AM
Quoted: 238 Post(s)
Liked: 250
They do, but they usually need a 32" door to get the lower half in. Check with the manufacturer/distributor on what they require.
PreciseD is offline
post #555 of 998 Old 10-25-2019, 09:09 AM
Liked: 1816
Pretty darn certain the OP has at least 3.0 doors and a 4' right angled landing. He should have no issue unless he purchases oversized, over stuffed Theater Chairs that cost $900.00^+...especially if he chooses leather.
Can't see that happening for the two obvious reasons....size won't allow him more that 3 chairs abreast and the cost is prohibitive.
PreciseD likes this.
post #556 of 998 Old 10-25-2019, 09:17 AM
Liked: 1816
Here are the best choices for Wall Wash Can Light Lenses for the forward Cans up front.
Least Expensive....
(the entire assembly including the Interior Baffle must be painted Black)
Wall Wash w/Black Baffle
The last one is preferred because the Black Baffle also has a Fluted surface which breaks up reflections. You only have to paint the Lens cover and Trim Ring
Fantastic Price on Halogen Spots! You even get 2 spares! And...they are "Dimmable too!
post #557 of 998 Old 10-25-2019, 01:07 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
Now I recall. I had previously purchased recliners from Bob's and it came in two pieces. After that I bought a lazy boy but it came in one piece.
post #558 of 998 Old 10-25-2019, 01:07 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
Least Expensive....
Thank you.
post #559 of 998 Old 10-26-2019, 06:59 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
Today we finished a feather finish skim coat in the theater room and the neighboring room. I could not have done this without the help of my wife. I have shown the pictures of the product and the result after the finish. I will go back again tomorrow and reapply on areas that I already applied today but which after trying may look like it can take additional compound. I bought the Henry feather finish 549. It was extremely easy to use and I went through two bags. I am unable to upload any more photos here. It is asking me to become a VIP member. So here is are the link.
http://imgur.com/gallery/Thrjhse
post #560 of 998 Old 10-27-2019, 05:34 AM
Liked: 1816
Officially re-badged: "The Dalmatian Theater".
I bet your glad you decided to go the sensible resurfacing route suggested. Easy...a lot less expensive...and you got the Wife involved too!
(...not the easiest thing to accomplish....)
So the Forum is hitting you up to support your bandwidth usage, eh?
Go to your Profile Page, select "Attachments", and delete the redundant copies of images you've posted on several different Threads. Coalesce your content. Condense your duplicate Threads down to the one's that address your points most concisely.
It will take a bit a time.....there is a lot.
T'would serve you best to do so....as your Theater progresses, the finished photos deserve their spot far more than duplicated Construction-oriented images do. (All the "Floor Photos.......boring! )
With a little jockeying around of both content and images, you could choose one Thread (this one?) to both condense, and then selectively import images and posts from all the others. Then simply add a descriptive link to your signature for others to follow.
post #561 of 998 Old 10-27-2019, 06:14 AM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
Yep. Will do it.
post #562 of 998 Old 10-27-2019, 04:20 PM
Quoted: 238 Post(s)
Liked: 250
It's the Tapatalk app, they no longer allow more than 1 upload at a time and they reduced photo size unless you pay to become a VIP member..
PreciseD is offline
post #563 of 998 Old 10-27-2019, 05:04 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
Even with one it doesn't allow me to upload now and asking to become a VIP member.
post #564 of 998 Old 10-27-2019, 06:19 PM
Quoted: 238 Post(s)
Liked: 250
You can still upload an image, but you can only select 1 image at a time and then you have to select medium image size..
PreciseD is offline
post #565 of 998 Old 10-27-2019, 06:22 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
Yes I did that as well as small and it says you have uploaded more than 10 photos this month. Join VIP now to post unlimited pictures.
post #566 of 998 Old 10-27-2019, 06:23 PM
Quoted: 238 Post(s)
Liked: 250
Oh I didn't know they put a limit on it too.. That is horsechit
PreciseD is offline
post #567 of 998 Old 10-27-2019, 07:13 PM
Liked: 1816
Worse than that!
Talk about gettin' Tap'd
Looks like you need to download your photos onto your PC and then use the Forum's Attachment feature. No brakes on the process then.
post #568 of 998 Old 10-28-2019, 01:11 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
Any recommendations for theater seating that doesn't break the bank? I Need to be able to take it down to the basement.
post #569 of 998 Old 10-28-2019, 01:18 PM
Liked: 5621
rtheaters.com (New Jersey)
HTmarket.com (Chicago)
Discussion and reviews in the Theater and accessories section of this forum.
post #570 of 998 Old 10-28-2019, 04:21 PM - Thread Starter
Quoted: 731 Post(s)
Liked: 165
In addition to fuzeit kindly recommend additional products to attach base plate securely to concrete floor without needing to drill holes.
