AT (Acoustically Transparent) Theater build thread - Page 30 - AVS Forum | Home Theater Discussions And Reviews
 245Likes
post #871 of 957 Old 12-02-2019, 08:55 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3886 Post(s)
Liked: 1811
Originally Posted by p3bham View Post
Though I agree that you must take care with any bit to avoid rounding it over as much as possible, I agree with genac that the bits are terrible. And I'm not a newbie in anything to do with woodworking having done it professionally for over 15 years. They are poorly made with brittle, soft metal. I've had a dozen of them (I own a lot of Kreg kits lol) not round over but crack and have the square head split off. Better to move to a higher quality impact rated bit - even though you shouldn't be using an impact driver to work with pocket holes.
If you could point to / link to a higher quality Heat Tempered long shafted Square Drive of the right size, that would be the best possible thing for all concerned.
(Want sumthin' dun...du it yurself.......... https://www.amazon.com/Square-Drive-.../dp/B001DT300Y
A veritable plethora of choices.....but this one might be best...
MississippiMan is offline
post #872 of 957 Old 12-02-2019, 05:23 PM - Thread Starter
genaccmiller's Avatar
Quoted: 699 Post(s)
Liked: 159
Anyone know of an alternative to Logitech? The models I am looking at seem fairly expensive and I had rather not spend that much on just a controller.
Sent from my Moto G (5) Plus using Tapatalk
genaccmiller is offline
post #873 of 957 Old 12-02-2019, 06:28 PM
Liked: 0
Don't mean to throw this off topic but.. What would be a good value sound absorption material to put on the wall behind the baffle wall/screen?
Mach11 is offline
post #874 of 957 Old 12-02-2019, 07:51 PM
Liked: 1811
All the others that do what you need to have done cost even more.
The trick is to find a deal...and sometimes that means going with a Refurb. What you can't do is go without.
Even at full price, purchasing the "right" Controller and Hub separately is often the way to go.
The trick being to know what Control does what...
post #875 of 957 Old 12-02-2019, 08:29 PM
Liked: 1811
Here's a good "all new" combo.
https://www.amazon.com/dp/B00IAKLM54/ref=emc_b_5_t
https://www.amazon.com/Logitech-Harm...dp/B00N3RFC4Q/
This would be perhaps the best of all to consider
https://www.amazon.com/dp/B014PDFP9S..._wdg_tit_nw_mr
If you must get "something" for the least...get this:
https://www.amazon.com/Logitech-915-.../dp/B00ZYFUW72\
All will provide IR in-room for Projector operation, and RF/BlueTooth to IR for Closet Control.
post #876 of 957 Old 12-02-2019, 09:11 PM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
I dont have a complicated set up. What about something like this?
BAFX Products (Infrared) IR Remote Control Extender or IR Repeater Kit - Control 1 to 8 Devices (Expandable to 12!) https://www.amazon.com/dp/B009ZGK6QS..._F9D5DbD6TAFE1
post #877 of 957 Old 12-02-2019, 11:04 PM
Liked: 1811
Terribly old school. CroMangon even.................
It'll work...but the Receiver must be placed up front...hopefully directly behind the Left side Spandex wall, and the Mini-Plug wire might need an extension. Expect to see a bright flashing Red LED light whenever you use the remote. Annoying....
Don't take this wrong but IR Repeaters are really slummin' in a modern Home Theater.
You deserve a simplistic, touch-screen remote that doesn't need to be pointed at a specific IR receiver.
This is a "Smart spend" item.......worth the investment.
post #878 of 957 Old 12-03-2019, 06:23 AM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
Speaker stand design from @MississippiMan
post #879 of 957 Old 12-03-2019, 06:28 AM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
Screen frame support design from @MississippiMan
post #880 of 957 Old 12-03-2019, 06:30 AM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
Spandex material stretching sequence from @MississippiMan
post #881 of 957 Old 12-03-2019, 06:32 AM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
Support frame diagram from @MississippiMan
post #882 of 957 Old 12-03-2019, 08:57 AM
Quoted: 156 Post(s)
Liked: 205
As you undoubtedly discovered, they aren't hard to find. Kreg makes wonderful tools - their drivers aren't among them...
Roll Tide.
p3bham is offline
post #883 of 957 Old 12-03-2019, 09:10 AM
Quoted: 6021 Post(s)
Liked: 5608
If screw bits lasted forever why would they sell these at the contractors exit at Home Depot? I know for the intended application, drywall screw guns, that the tendency is to over spin the bits but still nothing is forever.
post #884 of 957 Old 12-03-2019, 10:58 AM
Quoted: 156 Post(s)
Liked: 205
No nothing is forever. But I've had multiple Kreg bits split in half down the square drive. Never had that happen with any other manufacturer - worn down yes. But a bit that splits in half tells me that the quality is very poor.
Roll Tide.
p3bham is offline
post #885 of 957 Old 12-03-2019, 11:06 AM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
I agree. They are poorly made. I have changed my technique based on @MississippiMan instructions. Let's see if this lasts longer.
post #886 of 957 Old 12-03-2019, 11:14 AM
Liked: 5608
post #887 of 957 Old 12-03-2019, 11:52 AM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
Ok. I am probably buying the harmony companion. I cannot justify a $150 price difference for the elite when I have only 2-3 devices to control.
post #888 of 957 Old 12-03-2019, 12:09 PM
rontalley's Avatar
Quoted: 815 Post(s)
Liked: 415
For total control and cool factor, I would go with a SmartThings Hub for Smart Lighting, etc., Harmony Hub (at least Companion), Amazon Echo device and a Tablet to run ActionTiles (frond end for SmartThings).
I really don’t have to control much in my Cave as it is all automated with voice control.
Buy in cost in relatively inexpensive and it’s expandable to the rest of your home. I have 4 Harmony Hubs.
pkinneb likes this.
My Media Room
AVR 1-Yamaha RX-A3050 (7.2.4), AVR 2 Pioneer VSX-815-K(Used for 4ch Amp TF+TR)
Mains-Polk Audio RTi8, Center-Polk Audio CSi5, Surrounds-Polk Audio RTi4, Ceilings-Micca M-8C, Sub 1- UM18-22 (4cu.ft DIY) - iNuke 6000DSP, Sub 2-Klipsch RW12D
Projector-BenQ 3550 4K, Screen-110" Silver Ticket STR-169110, TV-Vizio P-65 4K
rontalley is online now
post #889 of 957 Old 12-03-2019, 06:05 PM
Liked: 1811
The Harmony Companion does not have a IR function built in the Hand Cotroller, so you'd have to keep the PJ Remote handy for all it's IR control.
Where is the sense in that? You gotta know what will work with your situation and I'm trying to clue you in.
Just get this $249.00 Harmony remote at more than 1/2 off as a Refurb.
Or New at discount since it's discontinued.Go to...
pkinneb likes this.
post #890 of 957 Old 12-03-2019, 08:38 PM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
Ok. Just cancelled the companion and ordered the elite. But since I lost one hour or so in this confusion the delivery is no longer Friday but on Monday.
post #891 of 957 Old 12-04-2019, 06:46 AM
rontalley's Avatar
Quoted: 815 Post(s)
Liked: 415
The Hub has IR outputs where you can put a blaster right at the PJ by simply running an 1/8 extension cable to the PJ...
However, Elites are great remotes!
My Media Room
post #892 of 957 Old 12-04-2019, 08:02 PM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
Screen is done with triple black velvet border.
post #893 of 957 Old 12-05-2019, 04:16 AM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
Anyone knows where I could buy some theater signage?
post #894 of 957 Old 12-05-2019, 06:22 AM
Liked: 5608
post #895 of 957 Old 12-05-2019, 06:50 AM
Liked: 1811
Don't be fooled just because your trying to save cash
Tru dat...........but;
When one has their equipment at the other end of the Room, running a 35' 1/8" extension is just so....1990's, and totally out of the question in a existing location without access.
Harmony has/had RF to IR capability for many years, with almost all their better Remotes featuring IR + RF functionality. Only over the last about 4 years ago did they started to gravitate toward eliminating the IR function on the majority of their top tier Remotes, while introducing WiFi connect-ability and BlueTooth.
Brook no mistake, a primary reason for omitting the IR feature on newer, less expensive "Phone Compatible" models is to drive Customers to the Elite version....just as they did 4 years ago when they came out with the Ultimate.
So now you can still purchase at least two stand alone models that still have IR and upgrade by adding a Hub. But that has led many to mistakenly purchase less expensive Remotes that had Mobile Phone apps only to find out that the core Remote lacked the ability to deliver IR signals.
Why? Because the darn idjuts still consider (rightfully probably) the broader market where people are using the Remotes for Cabinet-hidden Equipment, and have a big 'ol Flat Panel TV residing just above said Cabinet as being their prevalent targets. Of course using a Blaster or IR extension can be easily accommodated in those cases. For all others....the ones who have already spent loads on real Home Theaters with closeted Equipment a-way off in God's country, all ya all gotta ante up.
Here are Links that help:
https://img.bbystatic.com/BestBuy_US...comparison.pdf
https://www.universalremotereviews.c...Chart-2019.pdf
It appears that the Harmony Ultimate Home and Harmony Ultimate One and Harmony 950 Advanced are the only Remotes that offer IR separately from a Hub...the Ultimate Home coming with a Hub and the 950 Advanced simply being a Elite sold without a Hub.
rontalley likes this.
post #896 of 957 Old 12-05-2019, 07:25 AM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
Left speaker stand done. Right and center pending.
post #897 of 957 Old 12-05-2019, 08:23 AM
rontalley's Avatar
Quoted: 815 Post(s)
Liked: 415
@MississippiMan I agree if there is no practical way to run the cable. However, if it is, then this is exact intended purpose of the extenders. The magic of the Harmony Hubs is that you press 1 button and everything turns on/off...It would drive me crazy if I had invested $$$ in a remote to automate operations but still had to manually turn on/off the PJ and/or equipment. If there is an equipment room then the Hub should go in there or close to it. That's the beauty of RF because it doesn't need a clear line of site and can travel through walls.
However, I am in agreement with just getting the Elite or Ultimate! I have 1 Elite, 1 Ultimate, 1 Companion and 1 HUB with a simple remote that can all work together through SmartThings. Although I am use to it now, the Ultimate has a weird layout while the Elite's layout is much more ergonomic.
Saying all that, I still find myself using the PJ remote when I am tinkering with the PJ setting and using the AVR remote when tinkering with the AVR!
@genaccmiller You will be happy with the Elite! However, if there is an option to run the extension cable, I highly recommend that you consider doing so.
My Media Room
post #898 of 957 Old 12-05-2019, 08:37 AM
Liked: 1811
Nice job.......I'd feel confident in standing on that myself...and I weigh 240 lbs. (well...maybe...) I suppose the Cleats holding up the top MDF platform could have been 2x4s instead of 1x3s, but I already know how securely you screwed everything together. The additional bracing you added certainly looks to have done the trick as far as preventing any "wobblety-ness"
post #899 of 957 Old 12-05-2019, 08:40 AM
Dan Hitchman's Avatar
Quoted: 4747 Post(s)
Liked: 2780
Don't forget the acoustic treatments!! Don't get in such a rush to finish that you skip one of the most important aspects of theater building!!
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #900 of 957 Old 12-05-2019, 08:40 AM - Thread Starter
Quoted: 699 Post(s)
Liked: 159
Just to clarify the diagonal braces you see are the ones in the front panel. Do you want me to add these diagonal braces as well? It is fairly secure without them. Also I added the 1x3 bracing but to your point do you want me to replace with 2x4s?
