Help in choosing/how to use this space - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-05-2019, 02:09 PM - Thread Starter
Liked: 0
Well after haveing this house for quite a few years and just useing the basement how it was when i bought it im thinking of redoing some of it and creating an actual dedicated 5.2.movie/gameing room. So thought id post up some pics of the space and get some suggestions on layout from the pros here if possible. Room dimensions 23 1/2 L,13ft W wall to supports 9 1/2 front of fireplace to supports,7.2ft H with drywall as is now.My initial idea was to build a wall where the support columns are and putting entrance between the 2 supports,putting false wall with at screen on end where the screen is now,seating with a riser on opposite side with shelving built into back wall for equipment(theres a closet on back side of the wall already i could use for access).building 4 columns to hide four surrounds on the riser. Unfourtantly there's a issues i ran into with this plan..the steps. With a wall built down length of room (where the columns/supports are) it only leaves about a foot between bottom step and wall. Any ideas or suggestions? Iv also got another room behind the back wall thats about 19 1/2ft long and same width as the room w fireplace but in the closet theres a sump with a drainage pipe that runs cpl feet up and out the wall in the closet id have to work around. Any ideas/suggestions gratly appreciated also Im on mobile so sorry if post comes out formated wrong.Click image for larger version
ID:	2598934Click image for larger version
ID:	2598940Click image for larger version
ID:	2598942 Click image for larger version
oglk30 is offline
post #2 of 8 Old 08-05-2019, 02:52 PM - Thread Starter
Liked: 0
apparently it says i cant edit but that's supposed to say 5.2.4 setup and going to try pics again seeing as how came out sideways. Sorry hopefully this works
ID:	2598980   Click image for larger version
ID:	2598982   Click image for larger version
ID:	2598984   Click image for larger version
ID:	2598986   Click image for larger version
oglk30 is offline
post #3 of 8 Old 08-05-2019, 07:08 PM
Quoted: 5867 Post(s)
Liked: 5432
Is that fireplace a foundation for one like it above?
post #4 of 8 Old 08-05-2019, 07:20 PM - Thread Starter
Liked: 0
ya there is another fireplace straight above it in the upstairs living room. Upstairs has a gas insert the one in pic is wood burning if matters.
oglk30 is offline
post #5 of 8 Old 08-05-2019, 08:56 PM
Liked: 5432
I was hoping you could take it out.
post #6 of 8 Old 08-06-2019, 07:03 AM
Silva741's Avatar
Quoted: 150 Post(s)
Liked: 137
It's hard to judge based just on the photos, but it seems the fireplace isn't centered, so (assuming it isn't possible to completely remove the fireplace) perhaps placing the screen on the opposite wall could at least allow for a bit more space between the screen and the fireplace.
Silva741 is offline
post #7 of 8 Old 08-06-2019, 07:53 AM
m0j0's Avatar
Quoted: 604 Post(s)
Liked: 609
What would the size of the room be if you walled off from the right side of the chimney back to the supports and in towards the right wall? If you could wall that off, it might work for a dedicated HT space.
Another way might be to make a wall going back on one side aligned with the supports, and then do a false wall on the chimney side, so that you no longer see the chimney or windows on that side of the room. It could be then as long as you want to make it, though it will be a little narrow.
m0j0 is offline
post #8 of 8 Old 08-06-2019, 11:52 AM - Thread Starter
Liked: 0
oh believe me id love to considering it's only been used maybe 1/2 times in the 10 years iv had the house.
ya your right and thats how i had it when i had my old setup in there actually. problem with that is if i went 2 rows of seating. Front row would have fireplace on immediate left and be a problem with side surrounds(i messed up in both my previous posts supposed to be 7.2.4 not 5.2.4).That bottom step is also an issue because it would only leave like a ft between it and wall ran length of room so either have to turn bottom step or build a door right there. So Id also thought with screen wall on side its on now if i went with a false wall with at screen it would allow me to maybe have bottom 2 steps turned towards where the pool table is then on wall id build running down length of room(where the supports are) i could frame an access opening to behind screen where the steps come down to now for access behind screen as well as i wouldnt have a hard right angle to deal with if/when needed to bring anything big down the stairs. i could just remove the screen and still have a straight shot up/down stairs. Hope that made sense lol
Originally Posted by m0j0 View Post
What would the size of the room be if you walled off from the right side of the chimney back to the supports and in towards the right wall? If you could wall that off, it might work for a dedicated HT space.Another way might be to make a wall going back on one side aligned with the supports, and then do a false wall on the chimney side, so that you no longer see the chimney or windows on that side of the room. It could be then as long as you want to make it, though it will be a little narrow.
think either of those ways would be extremely tight
Besides not really being able to soundproof because of the fireplace being one huge opening making it pointless(luckily im only one who lives here so not huge issue) i dont really think its too much of a problem as far as view although obviously not ideal. Going to post some test shots i threw up on wall for more peoples opinion on that. But the steps running right into where i want to build the wall down length of room is throwing me off so any opinions on my thinking of what to do about that i posted in response to Silva? Also going to throw up some pics of room behind that one(dnt judge its a mess lol). Maybe bring that back wall down from where it is now extend it about 5ft into room where fireplace is and use that space? Issue there being the sump which im including pics of.
ID:	2599704   Click image for larger version
ID:	2599706   Click image for larger version
ID:	2599708   Click image for larger version
ID:	2599710   Click image for larger version
oglk30 is offline
