Cheap Soundproofing layer on top of subfloor before carpet - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By BIGmouthinDC
  • 1 Post By Mocs123
post #1 of 18 Old 09-15-2019, 04:06 PM - Thread Starter
qlizard's Avatar
I initially put this in the wrong section...
Anyway, We are starting to put together our HT (21'x16'x9') and I need some quick help. My wife is building the riser (yes she is the better carpenter) and I need some advice on what to put under it (and under the carpet for the rest of the room).
It is an OSB subfloor and has a room (kitchen) under it. Unfortunately I can't do anything with the space between the floor and the ceiling underneath. But I can lay down something on the subfloor before building the riser on it, and before carpeting the rest of the room (and the riser). But I can't spend very much - I have about 360 sq ft to cover and couldn't spend more than a couple hundred dollars. Is there something you recommend that I can put down or roll out before building the riser and putting down the carpet that will at least help deaden some of the sound? I do plan to shove a bunch of insulation into the riser.
If nothing else I was thinking this. https://www.amazon.com/UltraSeal-Und...ct_top?ie=UTF8 or this https://www.amazon.com/Roberts-70-19...SIN=B008N6Q7HI
I appreciate the help.
qlizard is offline
post #2 of 18 Old 09-15-2019, 04:19 PM
Quoted: 5863 Post(s)
Liked: 5422
post #3 of 18 Old 09-15-2019, 05:05 PM - Thread Starter
qlizard's Avatar
Those look great but unfortunately out of my price range right now. Seems I would need about 15 of them = $675. I know, small price to pay for the long term benefit but I've got other factors to contend with (WAF).
qlizard is offline
post #4 of 18 Old 09-15-2019, 05:31 PM
Liked: 5422
keep your eyes open locally for a gym that is going out of business and selling their rubber floor mats
For the riser, you could just cut strips for under the framing and you really only need enough for the perimeter if you build it right.
post #5 of 18 Old 09-15-2019, 06:30 PM - Thread Starter
qlizard's Avatar
Good idea, thank you. So those rubber mats are much better than the rolls I linked?
Sent from my Moto E (4) using Tapatalk
qlizard is offline
post #6 of 18 Old 09-15-2019, 09:15 PM
Liked: 5422
can you stay warmer in a parka compared to a T-shirt?
post #7 of 18 Old 09-16-2019, 02:04 AM
NotShorty's Avatar
Quoted: 41 Post(s)
Liked: 42
Searching "horse stall mat" on my local Craigslist page turned up the following link. Not sure how it would work for your purpose, but for someone on a tight budget it might be worth considering (if you can get it locally or shipping isn't too expensive).
https://atlanta.craigslist.org/atl/g...971762049.html
Sent from my Pixel 2 using Tapatalk
NotShorty is online now
post #8 of 18 Old 09-16-2019, 06:40 AM - Thread Starter
qlizard's Avatar
Thanks for the link, I'll take a look through that.
qlizard is offline
post #9 of 18 Old 09-16-2019, 06:49 AM
Liked: 5422
I suspect that the conveyor belts are harder less resilient. Not as desirable but they do have mass which is good.
post #10 of 18 Old 09-16-2019, 07:09 AM - Thread Starter
qlizard's Avatar
Good tip on the gym. I found one going out of business. They only have seven left though. And still more than I want to pay ($25 each). Decisions.
qlizard is offline
post #11 of 18 Old 09-16-2019, 08:12 AM - Thread Starter
qlizard's Avatar
Well I decided to get those mats for under the riser. For the rest hopefully I can find some more for cheap or I'll have to get them at tractor supply. Either way I'm going to be in trouble for weeks.
To save a little money do you think I should still cut strips for under the riser? Or will the lack of mass there be noticeable?
qlizard is offline
post #12 of 18 Old 09-16-2019, 12:03 PM - Thread Starter
qlizard's Avatar
Nevermind, I recalculated and I only need 10 panels. So after these 7, I just need 3 for the whole floor. I'll just fill the whole space. Thanks for the help.
qlizard is offline
post #13 of 18 Old 09-20-2019, 06:31 AM - Thread Starter
qlizard's Avatar
I am going to start laying down these heavy horse mats. Is there anything I should put between the osb subfloor and the horse mats? I found some green glue at a good price on Craigslist. Would it be at all effective between the osb and horse mats?
qlizard is offline
post #14 of 18 Old 09-20-2019, 08:44 AM
Liked: 5422
The gg will not provide any benefit, a carpet adhesive intended for rubber backed carpets would keep the mats from moving around.
post #15 of 18 Old 09-20-2019, 09:38 AM
Mocs123's Avatar
Quoted: 218 Post(s)
Liked: 114
Those mats are pretty heavy themselves and the riser will be heavy as well, so I doubt it will move anyways.
pkinneb likes this.
7.4.4 Theater Room: JVC-RS46U, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic DBT-110, JBL Studio 270’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne
Mocs123 is offline
post #16 of 18 Old 09-20-2019, 09:52 AM - Thread Starter
qlizard's Avatar
So those mats have one side smooth and one textured. Do you think it will matter which size is up or down? It will be carpeted on top of them in the non-riser places.
qlizard is offline
post #17 of 18 Old 09-20-2019, 06:03 PM
niccolo's Avatar
Quoted: 269 Post(s)
Liked: 68
Agreed with BIG, GG is for damping relatively rigid layers, using it with rubber would seem to either provide minimal or no benefit at all.
Roberts, which makes various glues, has very particular recommendations for attaching a rubber layer to OSB. I wrote up some feedback they shared here, but you may want to reach out to their customer service directly yourself. https://www.avsforum.com/forum/19-de...l#post58546412
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #18 of 18 Old 09-20-2019, 07:20 PM
Bigus's Avatar
Quoted: 636 Post(s)
Liked: 583
I would place textured side down. Minimizes contact area.
Bigus is offline
