5.1.4 worth it in small room? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By skylarlove1999
  • 2 Post By Mashie Saldana
post #1 of 9 Old 10-21-2019, 04:46 PM - Thread Starter
Quoted: 93 Post(s)
Liked: 33
I’m going to start building a theater in one of my spare bedrooms within the next month. The room is pretty small at 10’x11’. See the dimensions and pics here.
My main question is whether it’s worth it to go for a 5.1.4 Atmos setup. I for sure want 5.1.2. I have read many reviews and posts online comparing having 2 Atmos ceiling speakers to 4. Some have said it’s only a subtle difference, others have said Atmos is only worth doing if you have 4 ceiling speakers.
It should be noted from the pictures that I will only be doing one row of 4 seats in this room. Usage will be around 50% movies (4K Blu Rays) and 50% gaming. I already own Klipsch towers, center, and surrounds, as well as an Outlaw Ultra X12 and a 65” OLED.
I plan on getting a new receiver, if I do 5.1.2 it looks like the Denon X1500H is around $300. From my research, the cheapest Denon or Marantz (want to stick with those brands) that will do 5.1.4 is the Marantz SR6013 for $750 on A4L. Not sure on what Atmos ceiling speakers are best, but from some looking it seems decent in-ceiling speakers might be around $150 each, please let me know if that’s not correct.
So overall it would cost me an extra $750 to do 5.1.4 instead of 5.1.2. Do you think it’s worth it in this room? I’m typically the person that likes to spend more the first time to do it right, but want to make sure it makes sense in this case.
Trogdor796 is offline
post #2 of 9 Old 10-21-2019, 04:56 PM
skylarlove1999's Avatar
Quoted: 1044 Post(s)
Liked: 724
I ran 7.1.2 before in a 15 ft wide by 25 ft long room with screen on short wall. I found the overhead panning from left to right and front to back and vice versa of both to be quite a bit more immersive with 4. Soundtracks also have more depth. If you able to run 4 Atmos speakers even in a smaller room I would do so.
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #3 of 9 Old 10-21-2019, 05:09 PM
Quoted: 16 Post(s)
I would go with the 5.1.4 setup. One always wants more. Might as well do it now and save on another receiver upgrade down the road. I started my home theater with 5.1. Quickly moved to 7.2 then 11.4 and now 7.4.6. I’m done unless I buy another house....it’s a approximately 14 x 16 room.
Home Theater System Denon X8500H, Emotiva XPA-5 Gen 2, Polk CSi A6 Center, Polk RTi A9 Front, Polk RTi A7 Front Wide, Polk RTi A1 Front Height, Polk FXi A6 Side, Polk RTi A3 Rear, Polk RTi A1 Rear Heights, Polk 70RT Middle In-Ceiling, SVS PB12-NSD x2 Front, SVS PC12-NSD x2 Rear, JVC DLA-RS1000, Visual Apex CineWhite 100" Screen, Panasonic UB9000, Dish Hopper 3
Phillihp23 is offline
post #4 of 9 Old 10-21-2019, 05:11 PM - Thread Starter
Quoted: 93 Post(s)
Liked: 33
Thanks for the reply. If I have the seats about 12-18” off the back wall do you think that will give me enough space for two rows (4) of ceiling speakers?
Also - any suggestions on in ceiling speakers? Not sure how high quality I need for Atmos, I see Klipsch and Polk have some for around $150ish each.
post #5 of 9 Old 10-21-2019, 05:29 PM
Liked: 724
I use these they have ceiling mounts but you don't have to cut holes.
https://www.svsound.com/pages/prime-...oaAjVdEALw_wcB
Highly recommended. You should be fine . This is Dolby laboratories layout for 5.1.4
post #6 of 9 Old 10-21-2019, 05:37 PM
m0j0's Avatar
Quoted: 683 Post(s)
Liked: 703
I have a fairly small room that is 13'2 x 12'4" and I was running 5.1.4 with no problems (and eventually added in back surrounds to make it a 7.1.4 setup). It can be done in a small space and is very much worth it in comparison to 5.1.2 (which I also tried for awhile, but it's no comparison to a 5.1.4 setup).
m0j0 is online now
post #7 of 9 Old 10-21-2019, 07:10 PM
Quoted: 16 Post(s)
The svs atmos speakers provide for a variety of placement. And easy ability to relocate if better placement for your room is discovered. Other options are in-ceiling in which case I would recommend staying with the same brand as your other speakers so they are tone matched. It’s Really a personal preference and room acoustic/placement needs matter.
post #8 of 9 Old 10-21-2019, 07:20 PM
Liked: 724
Timbre matching is certainly very important across LCR and to a lesser extent your surrounds but I don't think it really matters much with your Atmos speakers from what I have read and heard with my ears.
https://www.aperionaudio.com/blogs/a...imbre-matching
m0j0 likes this.
post #9 of 9 Old 10-22-2019, 01:53 AM
Mashie Saldana's Avatar
Quoted: 1244 Post(s)
Liked: 1083
5.1.4 is bare minimum for any size room.
jjcook and Boxozaxu like this.
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is offline
