AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Dedicated Theater Design & Construction (https://www.avsforum.com/forum/19-dedicated-theater-design-construction/)
-   -   Opinions: Dolby Atmos Speaker Placement (https://www.avsforum.com/forum/19-dedicated-theater-design-construction/3106824-opinions-dolby-atmos-speaker-placement.html)
Rob Dobbs 12-03-2019 08:58 AM
3 Attachment(s)
Looking for opinions on what people would choose to do in my situation. The room is about 15'x25'. Which speaker arrangement would you do? I have a LCR with 2 subs, and 6 - 8 surround speakers. Is it worth spending the extra money for 2 extra speakers to get 8, when the budget is tight? If so, would you put the extra 2 on the side or the ceiling?Thanks!
A) Attachment 2648766
B) Attachment 2648768
C) Attachment 2648770
sdurani 12-03-2019 09:49 AM
2 height speakers let you hear left-vs-right movement overhead. 4 height speakers let you hear left-vs-right AND front-vs-back movement overhead. Big difference.
In the base layer, having 4 surrounds gives you wrap-around envelopment AND side-vs-rear separation in the surround field. So first choice would be option B (7.1.4 layout).
Down the road, if the budget allows, you can add a pair of Wides to fill the gap between the Fronts and Sides for a 9.1.4 layout. Speaking of budget, if you can do 2 subs, that would be very helpful in getting smoother bass (fewer/smaller peaks & dips) AND greater seat to seat consistency.
Rob Dobbs 12-14-2019 08:48 AM
That's the direction I was leaning. Thanks a lot!
mhutchins 12-16-2019 02:09 AM
I would do B, as well. However, I would wire for 9.4.6 so you are ready for future expansion!
Mike
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
