SDK Theater "Budget" Build - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 1 Post By skylarlove1999
  • 2 Post By BIGmouthinDC
  • 1 Post By BIGmouthinDC
  • 1 Post By sbazzle
post #1 of 22 Old 01-19-2020, 04:54 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
Okay, it is time to get this build thread started. I have been lurking and reading long enough and it is time to get started on construction.
This is planned as a "budget" build. I say budget as compared to many of the theater rooms I have read about on this forum.
This will be a dedicated theater room with 99% movie watching and 1% music listening.
Here are the initial details that I can use to start dialing in the final plan.
Room Size: 21'-10" x 16'-9" x 8'-11" (365.7 sqft, 3,260.8 cuft)
Equipment (so far):
Speakers:
Left, Center, Right (3) - DIYSG HT-12
Side and Back Surronds (4) - DIYSG HT-8
Atmos (4) - RSL C34E (Planned, but not yet purchased)
Processing:
Marantz SR6013 AVR
Amp:
AMX Alero ALR-AMP-8 - 160W x 8 Bridged Channels
Video:
Epson Home Cinema 5050UB
Panasonic DP-UB420P
Apple TV 4K
Seating:
2 Rows of 4 Fusion Collection Seating 1011 Lagoon in Black Microfiber
Acoustic Treatments:
All walls covered with 2 inch OC703 with various "enhancements" for reflection and diffusion. All fiber will be covered with acoustically transparent fabric.
Update 1: I uploaded some SketchUp screenshots that I just finished.
ID:	2672412   Click image for larger version
ID:	2675936   Click image for larger version
ID:	2675938   Click image for larger version
ID:	2675940   Click image for larger version
ID:	2675944   Click image for larger version
SDK Theater
alangsk is online now
post #2 of 22 Old 01-19-2020, 04:55 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
Reserved for Speakers
SDK Theater
post #3 of 22 Old 01-19-2020, 04:55 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
Reserved for Sound Iso
SDK Theater
post #4 of 22 Old 01-19-2020, 04:55 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
Reserved for Acoustics
SDK Theater
post #5 of 22 Old 01-19-2020, 04:56 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
Reserved for Riser
SDK Theater
post #6 of 22 Old 01-19-2020, 04:56 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
Reserved for Stage
SDK Theater
post #7 of 22 Old 01-19-2020, 05:05 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
Sound Isolation Plan
So being that this is a budget build, I am only planning on 1 layer of 5/8 fire rated drywall. However, I plan to decouple the walls by building a room within a room and using RSIC-DC04 clips to attach to existing structure. Then I would do Kinetics IsoMax clips and channel on the ceiling.
First question, if I am only going to be using a single layer of 5/8 fire rated drywall, does it still make sense to follow the plan to decouple and use clips and channel on the ceiling? I am okay with some sound escaping the room, but I don't want to spend the extra money for the various clips if I am not really gaining anything when I am only using 1 layer of drywall.
SDK Theater
post #8 of 22 Old 01-19-2020, 05:17 PM
skylarlove1999's Avatar
Quoted: 1538 Post(s)
Liked: 1259
Equipment (so far):
Speakers:
Processing:
Marantz SR6013 AVR
Amp:
Video:
Panasonic DP-UB420P
Apple TV 4K
Seating:
Here is a sketch with the overall dimensions of the room as it stands today. I will be adding additional sketches to highlight the ducting and pipe runs in the ceiling that I have to work around.
Looks pretty cool. Have you chosen a screen material, size and aspect ratio as of yet?
Sent from my SM-G965U using Tapatalk
alangsk likes this.
skylarlove1999 is offline
post #9 of 22 Old 01-19-2020, 05:19 PM
Quoted: 6250 Post(s)
Liked: 5980
Using decoupling methods and clips in channel in the bones of your theater will allow you to correct the error of your ways later when you can add that second layer with Green Glue.
alangsk and mikela like this.
post #10 of 22 Old 01-19-2020, 05:21 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
I am planning right now to do a DIY spandex AT screen at 2.39:1 and 120” wide. That may change as I work through all my questions.
SDK Theater
post #11 of 22 Old 01-19-2020, 05:26 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
LOL, thanks BIG! I like how you stated that.
In all seriousness, I may not be in this house for more than 3-5 years. The extra DW and Green Glue puts me over my planned budget. What are the drawbacks, besides sound outside the room, if I don’t do that?
SDK Theater
post #12 of 22 Old 01-19-2020, 05:29 PM
Liked: 1259
Pay once cry once. I am sure the home theater builders will tell you to use the green glue and two layers of drywall. I am sure @BIGmouthinDC could probably even tell you the exact cost to do it the right way the first time, within a couple hundred. I know we all have a budget but since you are building from scratch you should do it right the first time. You are already saving on the speakers, screen and maybe subwoofer if you are going DIY. You could always use free store financing for 24 months for the Epson 5050 and divert that cash to the sound isolation? Just my two cents.
post #13 of 22 Old 01-19-2020, 05:32 PM
Liked: 1259
Seymour AV has some very budget friendly AT screen material that people rave about.
http://www.seymourav.com/screensDIY....UaAvKZEALw_wcB
alangsk likes this.
post #14 of 22 Old 01-19-2020, 05:37 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
I have samples of their XD and UF as well as Dreamscreen and spandex. Right now based on projecting on the samples I would go with either the UF or the spandex.
Carl’s Place also has Nano FlexiWhite that I would like to get a sample of.
SDK Theater
post #15 of 22 Old 01-19-2020, 06:14 PM
Liked: 5980
Outside sounds in the theater
post #16 of 22 Old 01-19-2020, 06:18 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
Thanks BIG, I appreciate your input. I will have to re-figure and see what I can do there. You figure two tubes of GG per 4x8 sheet of DW, correct?
SDK Theater
post #17 of 22 Old 01-19-2020, 07:08 PM
Liked: 5980
correct or two speed loaders if you buy GG by the 5 gallon bucket.
p3bham likes this.
post #18 of 22 Old 01-20-2020, 09:28 AM
Quoted: 194 Post(s)
Liked: 251
I'll join the chorus here - you're going through this effort to decouple and add clips and channel - find a way to get the green glue and second layer. The difference will be immense. Perhaps you go with a DIY screen at first (spandex) then can upgrade later as finances allow. Or as suggested above finance the projector. I think you'll be very glad you did.
Roll Tide.
p3bham is offline
post #19 of 22 Old 01-25-2020, 07:37 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
I uploaded some SketchUp screenshots that I just finished. I want to get some initial feedback on room layout. Once I get the initial feedback, I will make any adjustments and then put together some layouts with dimensions for additional comments.
Atmos speakers will be RSL C34E angled toward listening area.
For the back, there are two different options for the pillar location. I am not sure which one I prefer the most, so feedback is most welcome.
Also, I am really interested if the corner subs will work. Due to my rack location (already existing), could utilize the corners for subs. Otherwise they could go below the screen.
SDK Theater
post #20 of 22 Old 02-02-2020, 10:42 AM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
I have a couple of questions I need help with for sound isolation:
Question 1:
I am building a room within room design with clips and channel on the ceiling. The soffits will built as part of the room within room. What I mean is the framing for the soffit will be attached to the decoupled wall and then attached to the clips and channel on the ceiling so that the whole "inner shell" is decoupled. The "inner shell" will then get DD+GG.
Should the inner walls be built with studs 24" on center or the standard 16" on center?
Question 2:
Looking at the attached pics of the HVAC ducts and the intake and exhaust pipes for the furnace, what is recommended for quieting the HVAC ducts? Or should the soffit being built around all of it and attached to the decoupled wall and ceiling and covered by DD+GG be adequate?
ID:	2679256   Click image for larger version
ID:	2679258   Click image for larger version
SDK Theater
post #21 of 22 Old 02-02-2020, 11:25 AM
sbazzle's Avatar
I love when dedicated theater builds are starting, and people include SketchUp drawings to show. Great to see what is in your head early in the process. Looks like a wonderful space.
Sent from my Nexus 6P using Tapatalk
alangsk likes this.
Professional home theater lurker.
sbazzle is offline
post #22 of 22 Old 02-02-2020, 02:28 PM - Thread Starter
alangsk's Avatar
Quoted: 34 Post(s)
Question 1:
Question 2:
Any thoughts @BIGmouthinDC
SDK Theater
