Shadow Theater Build - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #1 of 34 Old 05-03-2020, 12:52 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Hello All! I've been dreaming of a theatre in my house forever, but once we bought this one it didn't seem possible. Well, I decided to make it possible. I completely tore out everything and started from the bare concrete walls. I have an Epson projector and it'll be thrown onto a 135" (ish) screen that I'm going to build. There will be seating for 4 and some bean bags, and a small bar area. I rerouted my entire water pipe and gas pipe systems and also some of the HVAC. Replaced all my galvanized steel pipes with Pex. I'll be leveling the floor a little but I'm currently framing the room.
Adding my future system below:
Video: Epson 5040UBe projector
Receiver: Onkyo TX-NR797 9.2-Ch. (I will be running 5.1.4)
Sub: SVS PB-1000 Subwoofer (Black Ash) - 10-inch Driver, 300-Watts RMS, Ported Cabinet
UHD Player: Panasonic DP-UB820 4K Ultra HD Blu-ray Player with HDR10+ and Dolby Vision Playback
Fire Stick 4K
HTPC (old one, will use when needed, maybe for MadVR if I upgrade it)
Speakers -
Front L/R x 2: Polk Audio 265-RT
Front Center x 1: Polk Audio 265-RT
Side L/R x 2: Polk Audio 65-RT
Atmos x 4 Ceiling: Polk Audio RC80i
b_scott is offline
post #2 of 34 Old 05-03-2020, 01:01 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
pkinneb likes this.
b_scott is offline
post #3 of 34 Old 05-03-2020, 01:10 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
pkinneb likes this.
b_scott is offline
post #4 of 34 Old 05-03-2020, 02:38 PM
Theedj's Avatar
Liked: 6
Congrats on getting it going. No easy task with all the plumbing and HVAC adjustments.
What are the room dimensions you’ll end up with?
Theedj is offline
post #5 of 34 Old 05-03-2020, 02:51 PM
mhutchins's Avatar
Quoted: 351 Post(s)
Liked: 315
Awesome job getting rid of all those leaking pipes!! You did the right thing getting rid of all that. I'm still a little worried about the cubby to the left of your panel where the window is and your sewer clean out. Both the window and the sewer down pipe look like they have been leaking. I saw the new brass plug, but the pipe joint above looks suspect, as does the window.
I would encourage you to run a dehumidifier down there. Judging by the warped peg board and flaking plaster on the walls, I'm guessing the humidity is pretty high down there at times.
Good job turning your dreams into reality! You've overcome the hardest part; getting started.
Mike
mhutchins is offline
post #6 of 34 Old 05-03-2020, 04:22 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Mike
Thanks! I didn’t take pics of everything but I cut down the sewer clean out and moved the slop sink area over there. There used to be a bath there and there may have been leaking in the past but there isn’t now. None from the window. The gray pipe out the wall is an old gas pipe that has been poly filled. There are two sewer drains so I’m just covered one of them.
Humidity is ok - I do have a dehumidifier due to a rainwater backup that we had to have our sewer main replaced. All good now.
b_scott is offline
post #7 of 34 Old 05-03-2020, 04:24 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Thanks! It’ll be 13’ by 25’ in rectangle area but that doesn’t account for the HVAC jog. I’m also going to build an under stairs sitting area for my kids.
b_scott is offline
post #8 of 34 Old 05-03-2020, 04:51 PM
Claybe's Avatar
Quoted: 315 Post(s)
Liked: 249
Wow! Good work. Way to get going on it!
Claybe is offline
post #9 of 34 Old 05-03-2020, 05:01 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Thanks! I started this thought process on 3/20. I just put the foam up Thursday.
b_scott is offline
post #10 of 34 Old 05-04-2020, 06:10 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Done framing. Square is for my projector.
ID:	2721236   Click image for larger version
b_scott is offline
post #11 of 34 Old 05-05-2020, 02:01 PM
Ladeback's Avatar
Quoted: 1612 Post(s)
Liked: 621
Send a message via MSN to Ladeback
I see you have a build thread now. Nice start. I see you decided to not go all in with the soundproofing. I am leaning that way as well. It would save a lot of money I could put into other things.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #12 of 34 Old 05-05-2020, 02:21 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
I haven’t done anything with soundproofing yet. Still deciding. I think I will end up with rock wool and clips and hat channel with one layer of 5/8”. I can’t see myself doing more than that.
Ladeback likes this.
b_scott is offline
post #13 of 34 Old 05-05-2020, 05:35 PM
pkinneb's Avatar
Quoted: 375 Post(s)
Liked: 1282
FWIW I think one things folks can miss, I know I did, is that the a lot of the techniques used to keep sound from escaping the room can actually make the sound in the room better. I suspect 10 to 15% of my budget went to sound proofing and I also suspect that amount, used else where, would not have delivered as much. Of course this is all personal opinion and who knows maybe I am just justifying the spend but bottom line is the room sounds amazing and also keeps all but major base scenes inside the room. Just food for thought.
My Theater Build - Full Circle Cinema
Left over Supplies for Sale - For Sale
pkinneb is offline
post #14 of 34 Old 05-05-2020, 05:50 PM
Quoted: 240 Post(s)
Liked: 156
Are you going with an AT screen?
bochoss is offline
post #15 of 34 Old 05-05-2020, 07:24 PM
kuroiknight's Avatar
This is what I love to see! This is what I find exciting. I love that you decided to do this and have documented with photos! I may have missed it but what are the dimensions and what type of audio equipment are you going with?
kuroiknight is offline
post #16 of 34 Old 05-06-2020, 07:14 AM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
I am! Spandex over wood.
Hoping that is the case Doing pergo-type wood floors with a large rug over the middle area.
So the main square area with the screen is about 13x13, and the room is 25' long total. I made a wall on the other side of the seating area to balance it and have a spot for the right speaker (when seated). The screen will be 138", which is 120" wide and 68" tall. Equipment:
Fire Stick 4K
Shield TV (2019)
Speakers (in wall) -
eventually I'll probably have an Xbox Series X and PS5 downstairs too but not right away. Until then I'll probably cart my Xbox One X and PS4 down there when needed.
bochoss likes this.
b_scott is offline
post #17 of 34 Old 05-09-2020, 07:15 AM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Wiring going in
pkinneb likes this.
b_scott is offline
post #18 of 34 Old 05-09-2020, 08:49 AM
Liked: 7
Allot of work put in to clean all the plumbing work. Well done.
b_scott likes this.
PaulF757 is offline
post #19 of 34 Old 05-09-2020, 05:55 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Thanks. I'll take a shot of the current pex setup soon. It's pretty neat. I didn't do a manifold but it's two trunks and branches. I'm so glad to be rid of that plumbing mess.
b_scott is offline
post #20 of 34 Old 05-10-2020, 02:24 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Bought some IB-1 clips without rubber and got some hat channel. I’ll probably be doing just that, but maybe adding some cheap insulation as well. I won’t be doing double drywall but I have canless lights so I really could add it at any time if I’m not happy with my setup.
Power and lights are all wired up and half my audio cables as well because I ran out of cable. Have more coming tomorrow.
b_scott is offline
post #21 of 34 Old 05-12-2020, 06:21 AM
Ladeback's Avatar
Liked: 621
So what will the dimensions of your room be?
Ladeback is offline
post #22 of 34 Old 05-12-2020, 06:38 AM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
b_scott is offline
post #23 of 34 Old 05-14-2020, 07:29 AM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Soffit building
ID:	2726120   Click image for larger version
pkinneb likes this.
b_scott is offline
post #24 of 34 Old 05-17-2020, 12:40 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Leveling out the floor.
b_scott is offline
post #25 of 34 Old 05-21-2020, 09:02 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Insulation and channel.
pkinneb and Ladeback like this.
b_scott is offline
post #26 of 34 Old 05-23-2020, 04:55 PM
Liked: 2
I can't believe the missus gave up her new laundry room!
Matthew Mills is offline
post #27 of 34 Old 05-23-2020, 05:16 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Lol well I kinda redid the laundry area so it’s nicer.
Matthew Mills likes this.
b_scott is offline
post #28 of 34 Old 05-24-2020, 11:00 AM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
Final leveling.
pkinneb likes this.
b_scott is offline
post #29 of 34 Old 05-26-2020, 02:55 PM
audiovideoholic's Avatar
Quoted: 787 Post(s)
Liked: 247
Nice job!!! Reminds me of my first projection setup in my older farmhouse. The projects that had to be done before the theater construction were the worst part of the process.
You may want to plan for more subwoofers or a single larger more efficient sub at a minimum. Just my opinion but I think LFE makes up to 80% of the Home Theater experience maybe more like 85-90% followed by dynamics and a large immersive image.
Dynamics are what makes one jump or look around like something actually happened in the room that wasn’t just a speaker playing while being engaged by the immersive image. The image and bass draw one into the movie/content then the dynamic sound catches one off guard.
Looking great!
Bests
Alex
Sent from my iPhone using Tapatalk Pro
b_scott likes this.
audiovideoholic is offline
post #30 of 34 Old 05-26-2020, 08:37 PM - Thread Starter
b_scott's Avatar
Quoted: 584 Post(s)
Liked: 188
thank you! I'm already installing a second subwoofer connection on the right side of the screen in case I need it. And I can always add another in the back of the room by simply going through the wall from the other room if needed.
b_scott is offline
