First AV Rack - Go big or go home! - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jay_waller
post #1 of 29 Old 05-16-2020, 01:45 PM - Thread Starter
Pultzar's Avatar
Quoted: 266 Post(s)
Liked: 135
So I'm putting together my first real AV rack. Sure I've had some stuff from Salamander Designs over the years, but that is consumer level. It's time to get with the professionals
I don't want to do this more times than I have to so I'd like to do it right the first time. The rack will live in a bedroom without AC. I'm in Seattle and it gets warm here occasionally, sometimes the house can be 80+ in the summer as we don't have AC.
Anyway I'm considering the Middle Atlantic BGR series 41 RU edition. This should be enough to hold my AV equipment and a server or two.
Initial questions:
1) Active cooling or passive?
2) If I go active cooling, side panels seem required? How about rear? I'd like to go without a front door so I'd fill in the empty spaces with blanks
3) What about things like Blu-RAY players that aren't rack mounted? Use a shelf? Will that mess with active cooling since the front is open?
4) How quiet are these "quiet" AV fans anyway? Any recommendations? I'm used to super silent PC fans currently.
5) Do these units take standard post mounted casters or do I have to use the manufacturer casters?
I was thinking of making two zones. The bottom area would be amps and have an fan above them to remove hot air. The stuff above wouldn't be as warm like source components.
I'm sure there is a bunch of stuff I haven't even considered yet. Feel free to fill me in.
Looking forward to this!
Pultzar is offline
post #2 of 29 Old 05-16-2020, 04:26 PM
mhutchins's Avatar
Quoted: 364 Post(s)
Liked: 345
Middle Atlantic has a great white paper on thermal management that you should read. It will answer a lot of your questions. AC Infinity also has a short little blurb describing different cabinet cooling configurations.
Mike
mhutchins is offline
post #3 of 29 Old 05-16-2020, 04:38 PM
Cheddarhead's Avatar
Quoted: 798 Post(s)
Liked: 879
Before you purchase the Middle Atlantic Rack take a look at the APC line. They are better made, have a wide array of accessories and are price competitive. Refurbished APC racks can be an excellent deal.
Current system:
Sony 75X900e/Sony STR-DN-1080, CS-3/CS-8/CS5
Sony X800 4K blu-ray player/Dish Hopper3
Roku 4 Premier/Sony PS-4
Cheddarhead is online now
post #4 of 29 Old 05-16-2020, 05:26 PM - Thread Starter
Pultzar's Avatar
Quoted: 266 Post(s)
Liked: 135
Thank you! In what aspect would you say that APC is higher quality? I'm not sold on Middle Atlantic so totally open to alternatives.
Pultzar is offline
post #5 of 29 Old 05-16-2020, 05:55 PM
audiovideoholic's Avatar
Quoted: 787 Post(s)
Liked: 247
With the Blu Ray player or other source devices there won’t be an opening. You will purchase a shelf and faceplate that literally fits the device perfectly. Could always place some gasket material around where the two meet for even extra protection/seal.
Sorry I can’t help with anything backed up by data/white papers regarding air circulation as I use an entire room basically for my racks so I use a dedicated supply and return that is tied into the HVAC system.
Good circulation should be all that is needed would be my thoughts and could easily break the rack into quadrants if one wanted to but in my view that seems like it would/could trap more heat unnecessarily unless running fans nonstop every time heat generating devices are fired up. This is just me thinking aloud without any data that backs up my thoughts.
The design of the devices will also play a role in temperature most likely. Top mounted exhaust devices, front to rear cooling fan setup devices, etc... Some of my Class D amps have exhaust fans mounted on the top of their housing and some have them pulling air from front to rear.
Just babbling now so will quit lol
Bests
Alex
Sent from my iPhone using Tapatalk Pro
audiovideoholic is offline
post #6 of 29 Old 05-16-2020, 07:39 PM
pkinneb's Avatar
Quoted: 467 Post(s)
Liked: 1440
1. Yes
2. I do not use a back panel on mine but it is an pretty tight alcove 2" gap on sides and top, 4" bottom, and 6" in back
3. My Bluray I put on a half shelf and it has a grate bottom so air can go through it.
4. Pretty quite on low and medium, but annoying on high. my fans are all ac infinity
5. I have a Sanus rack and it would be hard to retro fit casters to it others may be different.
My Theater Build - Full Circle Cinema
pkinneb is offline
post #7 of 29 Old 05-16-2020, 09:03 PM - Thread Starter
Pultzar's Avatar
Quoted: 266 Post(s)
Liked: 135
Am I blind or are all of their racks about 36" deep? They look super nice but I feel like I may have to climb inside of it to hook things up
Pultzar is offline
post #8 of 29 Old 05-16-2020, 09:58 PM - Thread Starter
Pultzar's Avatar
Quoted: 266 Post(s)
Liked: 135
NVM, I found the AV version. Looks nice!
Pultzar is offline
post #9 of 29 Old 05-17-2020, 10:26 AM
Quoted: 798 Post(s)
Liked: 879
I mostly work with network racks but this is what I know about the APC line. The first time I specified APC racks on a job, I had the following conversation with my lead tech:
Tech: "You're buying APC racks for every job from now on."
Me: "Why?"
Tech: "Because if you don't go find a new lead."
He felt that strongly as to the quality of the APC racks. Rarely will you find a sharp edge that will cut your hand or a mis-aligned part and the availability of accessories is excellent.
FYI: Most of our work is modernizing old data centers at small military sites. 2-4 racks of network equipment per site. We frequently replace hardware that is 8-10 years old.
Current system:
post #10 of 29 Old 05-17-2020, 12:34 PM - Thread Starter
Pultzar's Avatar
Quoted: 266 Post(s)
Liked: 135
Me: "Why?"
I like how the self leveling feet work as well. As far as cooling goes, all I'm seeing is ventilated rear doors. Have you experienced solid rear doors as an option?
Pultzar is offline
post #11 of 29 Old 05-17-2020, 12:36 PM
Quoted: 798 Post(s)
Liked: 879
No, we always have airflow from the front of the servers/switches out the back so we use the ventilated rear doors, usually the half doors. What kind of cooling are you using that you want solid rear doors?
It's amazing the amount of heat that pumps out that ventilated door.
Current system:
post #12 of 29 Old 05-17-2020, 12:44 PM
jay_waller's Avatar
Quoted: 32 Post(s)
Liked: 66
I am running the Middle Atlantic SRSR-4 series rack and love it. I am using AC Infinity Rack Mounted 2U fans. One for intake (bottom), one for exhaust (top). I was going to install another fan exhausting air out of the backside of the rack but the two fans I am running now keep everything cool so I haven't bothered. The fans only kick on when temps rise above 80 degrees and I have them programmed in 3 stages. I have never had stage two kick on, even during spirited listening.
Let me know what questions you may have.
Sent from my SM-G988U using Tapatalk
- Jay
jay_waller is offline
post #13 of 29 Old 05-17-2020, 12:58 PM
nonstopdoc1's Avatar
Quoted: 917 Post(s)
Liked: 390
How do you manage the IR control on your devices?
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | JBL SDP-55 | Nord NC500 | ATI AT528NC | Procella P8/P5V | Revel C763L | Monolith 12" x4
Living Room - LG OLED 65" | Denon X4400H | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia 20 CC | Polk Surrounds | Rythmik FV15HP x2
nonstopdoc1 is online now
post #14 of 29 Old 05-17-2020, 01:22 PM - Thread Starter
Pultzar's Avatar
Quoted: 266 Post(s)
Liked: 135
I was thinking that solid doors would be better for pulling air up through the enclosure, ie for amps. But I see what you mean if a server is also in there.
Pultzar is offline
post #15 of 29 Old 05-17-2020, 01:23 PM - Thread Starter
Pultzar's Avatar
Quoted: 266 Post(s)
Liked: 135
Is there a trick to loading heavy gear into the rack without tipping the entire thing on its back to drop stuff in?
Pultzar is offline
post #16 of 29 Old 05-17-2020, 01:27 PM
jay_waller's Avatar
Quoted: 32 Post(s)
Liked: 66
To the left and back there is an IR blaster on the foot of the speaker pedestal. Never fails.
- Jay
post #17 of 29 Old 05-17-2020, 01:34 PM
Quoted: 917 Post(s)
Liked: 390
Do you mean its outside the rack? Thanks
post #18 of 29 Old 05-17-2020, 01:36 PM
jay_waller's Avatar
Quoted: 32 Post(s)
Liked: 66
Yes, my recessed rack is in the back left corner of the room and my rear left surround is a few feet out of the picture frame. I use a Harmony Elite and the hub sits on top of the left rear surround speaker, near the rack.
- Jay
post #19 of 29 Old 05-17-2020, 01:37 PM
jay_waller's Avatar
Quoted: 32 Post(s)
Liked: 66
You can see it in this picture.
nonstopdoc1 likes this.
- Jay
post #20 of 29 Old 05-17-2020, 01:40 PM
jay_waller's Avatar
Quoted: 32 Post(s)
Liked: 66
It is a pain in my situation where the rack cannot be easily removed. Even though my rack slides all the way out, nearly killed myself with an Emotiva XPA-7! Just needs a couple sets of hands and be careful not to cross-thread the machine screws.
- Jay
post #21 of 29 Old 05-17-2020, 08:08 PM
jay_waller's Avatar
Quoted: 32 Post(s)
Liked: 66
I did find it helpful to put something under the components you are mounting to keep them at the right height. That is about all I can offer.
- Jay
post #22 of 29 Old 05-18-2020, 07:49 AM
Quoted: 798 Post(s)
Liked: 879
Ah yes, the A/V industry still has not understood the utility of standardized slide-in rails to allow easy mounting of equipment.
The only tip I can give is load the rack bottom to top with your heaviest equipment at the bottom, not gaps between equipment and always have at least two people when racking and stacking.
One trick my tech uses is to buy a set of universal shelf rails, mount them upside down, slide your equipment in and secure it. Remove rail universal rail rinse and repeat. You have to install the rails upside down to allow access the mount holes for your equipment. It work for him.
Sample rails: https://www.amazon.com/NavePoint-Uni...9813127&sr=8-3
Current system:
post #23 of 29 Old 05-18-2020, 03:52 PM
jay_waller's Avatar
Quoted: 32 Post(s)
Liked: 66
That is an amazing idea!
- Jay
post #24 of 29 Old 05-26-2020, 09:54 AM
Liked: 0
Do you have a door/cover for the rack or leave it exposed? If you can't hear the fans but they can keep that stack cool, looks like a winner to me. Thanks!
kcklipsch is offline
post #25 of 29 Old 05-26-2020, 10:11 AM
jay_waller's Avatar
Quoted: 32 Post(s)
Liked: 66
I thought about trimming out the opening and possibly adding a door but I also did not want to affect cooling. I can here the fans when it is dead silent (which is rare) but the stack is pretty efficient so the fans don't kick on very often. Right now, I will leave it open.
- Jay
post #26 of 29 Old 05-26-2020, 11:08 AM
Liked: 0
Very nice! How deep is it?
post #27 of 29 Old 05-26-2020, 02:33 PM
Quoted: 787 Post(s)
Liked: 247
Easy with a faceplate. Put a temporary faceplate on the rack and slide your equipment in while the faceplate holds the majority of the component in place while screwing it into the frame. You’ll need to basically just balance it while threading the new screws.
Edit after reading further down the thread-
Using an extra set of rails is an even easier way to mount components by oneself. I need to try that for sure.
post #28 of 29 Old 05-26-2020, 04:21 PM
jay_waller's Avatar
Quoted: 32 Post(s)
Liked: 66
While this is a good idea, this only works if the rack ears support the component from the bottom right? If the rack ears purely bolt to the side of the component frame, you still have to hold the component up while bolting it in.
Right?
- Jay
post #29 of 29 Old 05-27-2020, 06:20 AM
Quoted: 787 Post(s)
Liked: 247
Right?
Yes and no. The rack ears will sit atop of the faceplate so that the faceplate is doing the brute work and one will only have to balance the component while screwing it into the rack. Then remove faceplate from below and place it directly beneath where the next component will go and repeat.
Most power amps and similar constructed components that have molded ears are supported by the entire length of the component whereas added ears generally don’t work the same but the ears themselves will hold the weight of the component just fine.
I have used this method with all my gear except stuff that uses shelves and custom faceplates with zero failures. My rack is right beside the closet door so I can reach around from behind the rack with one hand, pull the component tight up against the rack rails, while the component is resting on the temporary faceplate that is being used just to mount components, and screw the component in place all by myself. Sure two people make it even easier for sure but it can be done with a single person.
Now that I know about the rack rails I will use this method just because it’s even easier. It will work the same way with components that don’t sit flush with the ears. The ears will rest on the rails is how I’m visualizing it.
Bests
Alex
