New Atmos build - Speaker location help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-21-2020, 04:07 AM - Thread Starter
Liked: 2
Hi all,
I am in the process of getting the room ready for all my equipment to arrive and having a hard time deciding on speaker placement for the 4 in ceiling atmos speakers, this will be going in with a 7.1.4 system.
Attached is a very crude drawing showing the room, its 6m long X 4m wide.
Screen is the yellow, Brown boxes are the couches (They are off center due to the walkway on the bottom of the image, back seats will be on a platform and in ceiling speakers are either going to be where the green or red circles are.
Green would mean they are higher in the recessed ceiling and I am concerned that some seats are on the wrong side of the speaker so you may loose some surround effects.
Red is my ideal position however I am concerned that the middle seat (where i normally sit) wouldnt get much overhead sound due to them being quite far away.
Any thoughts?
Lawrage is offline
