AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Dedicated Theater Design & Construction (https://www.avsforum.com/forum/19-dedicated-theater-design-construction/)
-   -   Riser Support Centers (https://www.avsforum.com/forum/19-dedicated-theater-design-construction/3147682-riser-support-centers.html)
Uther 05-22-2020 05:41 PM
Quick question, is it sufficient to use 16” centers for the internal riser supports if using two layers of 3/4 osb subflooring on top or do I need to go narrower?
BIGmouthinDC 05-22-2020 07:30 PM
1 Attachment(s)
16 good, if the span is long (like over 8 ft) add mid span supports. That will kill any bounce.
https://www.avsforum.com/forum/attac...1&d=1590200922
Uther 05-22-2020 07:52 PM
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
