Seamless (as possible) black velvet on false wall - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 2 Post By genaccmiller
  • 1 Post By BIGmouthinDC
  • 2 Post By BIGmouthinDC
post #1 of 5 Old 05-23-2020, 09:40 AM - Thread Starter
Quoted: 55 Post(s)
Liked: 6
Built out a false wall for an AT screen. The screen will take up the entire middle aspect of the wall. I have to cover above it, below it, and the side of the wall. The other side is up against the wall. So I have no problem and no seams at the front. I am really having a hard time (I am not a spacial visualization person) figuring out how to create the side wall with the velvet and having as minimal seam(s) as possible. Any recommendations??
ltalbrecht is offline
post #2 of 5 Old 05-23-2020, 09:45 AM
SteveCallas's Avatar
Quoted: 995 Post(s)
Liked: 938
If I am understanding your request correctly, staple the velvet to a new 2x4, frame the 2x4 in against the front wall, then pull it taught around the corner and staple it to the front framing.
SteveCallas is offline
post #3 of 5 Old 05-23-2020, 09:45 AM
genaccmiller's Avatar
Quoted: 885 Post(s)
Liked: 234
Black velvet is very dark. You may not see the seams.
Sent from my GM1917 using Tapatalk
Step by Step Theater Build - http://imgur.com/gallery/2tpaSru
My Theater Build Youtube Channel - https://www.youtube.com/channel/UCs_..._as=subscriber
My Theater Build Thread - https://www.avsforum.com/forum/19-de...ld-thread.html
genaccmiller is online now
post #4 of 5 Old 05-23-2020, 09:49 AM
Quoted: 6512 Post(s)
Liked: 6350
my seams
skylarlove1999 likes this.
post #5 of 5 Old 05-23-2020, 09:58 AM
Liked: 6350
wall to a small hallway seam, if this was black it would be even less noticeable. You staple fabric to a piece of furring, then screw the furring into position and pull the fabric around. Hide the top and bottom staples with molding. The alternative is to do a wall size frame, wrap and staple then mount the frame.
skylarlove1999 and pkinneb like this.
