LCR speakers behind wall? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By BIGmouthinDC
post #1 of 11 Old 05-26-2020, 08:26 AM - Thread Starter
jbn008's Avatar
Quoted: 304 Post(s)
Liked: 163
I apologize if this is the incorrect sub-forum, but I thought someone might be able to give some insight...
I'm moving into a new house so I'm in the process of converting the bonus room into a theater. My last home theater we used in-walls due to space constraints, but I was hoping to do the LCR with bookshelf speakers this time. In order to maintain a more "commercial cinema look I was hoping to hide the front speakers, and in doing so my idea was to place them in the (finished) storage room behind the front wall.
In other words, I was planning to place 3 speakers and the subwoofer in the room behind the front wall and just cut out holes so they'll basically look like in-walls. Do you see any audio issues with doing this or should I just stick with in-walls again?
Note that a projection screen will be hung on the front wall over the cutouts so the speakers will be hidden.
Thank you
jbn008 is offline
post #2 of 11 Old 05-26-2020, 08:57 AM
Quoted: 6671 Post(s)
Liked: 6549
There are audio impacts of sticking speakers designed for in room use into a wall, You will get a bass boost (baffle wall effect) which is not necessarily a problem if you can manage your rooms frequency response with equalization or willing to live with the boost. Second you will eliminate the negative effects of front wall SBIR that normally occurs when reflections off the front wall add destructive interference to the speakers, the frequency is dependent on the distance from the front wall. This is good news.
Food for thought is you can achieve the look you desire by placing the speakers in the room and erecting an acoustically transparent screen wall. which is probably more common than cutting holes in the wall and more flexible for future upgrades.
Mocs123 and skylarlove1999 like this.
post #3 of 11 Old 05-26-2020, 09:45 AM
Liked: 0
Would you have to worry about this if the speakers are not rear ported?
kcklipsch is offline
post #4 of 11 Old 05-26-2020, 10:36 AM
Liked: 6549
it has nothing to do with the port, but if they are rear ported I wouldn't stick them in the wall.
post #5 of 11 Old 05-26-2020, 12:45 PM - Thread Starter
jbn008's Avatar
Quoted: 304 Post(s)
Liked: 163
I really appreciate the help. In a perfect world I'd build a false wall for the screen to hang on with the speakers behind it as suggested, but unfortunately that would eat into the throw of my projector (in order to fill the full image). Long story short, I need all the distance I can get.
If it were you would you go to the trouble with bookshelf speakers or just go in-wall? My room will be strictly for movies and I would not consider myself an audiophile, but I would like to get decent performance.
Last question, I'm guessing the subwoofers should probably be placed within the room as well? I could just try to hide them if need be. Thanks again
jbn008 is offline
post #6 of 11 Old 05-26-2020, 01:14 PM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 408
You could look into infinite baffle subwoofers. You pay a lot to get good performance from in-wall speakers, but good performers are out there - Check out Triad's line.
I'm not sure how tight you are with space, but you could have a acoustically transparent screen as close as a foot from the wall. Speakers like the DIY Soundgroup HT-12 or HT-10 are built for just such instances.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, Dual Driver VBSS
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is offline
post #7 of 11 Old 05-26-2020, 01:36 PM - Thread Starter
jbn008's Avatar
Quoted: 304 Post(s)
Liked: 163
Thank you. I'll look into those
jbn008 is offline
post #8 of 11 Old 05-26-2020, 02:54 PM
Liked: 6549
Nothing wrong with putting subs in wall if you are willing to make those big holes. Ports should face the room.
post #9 of 11 Old 05-26-2020, 04:32 PM - Thread Starter
jbn008's Avatar
Quoted: 304 Post(s)
Liked: 163
That's what I was hoping to hear. I really appreciate the help!
jbn008 is offline
post #10 of 11 Old 05-26-2020, 04:51 PM
Liked: 6549
On other note, it is not an all or nothing proposition. If you have a 2x2 sub, and you can recess it in the wall 1 ft than it looks like a 1x2 sub.
post #11 of 11 Old 05-27-2020, 04:09 PM - Thread Starter
jbn008's Avatar
Quoted: 304 Post(s)
Liked: 163
good idea. thanks
jbn008 is offline
