Our new build Home Theater design - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BIGmouthinDC
post #1 of 5 Old 05-28-2020, 02:41 AM - Thread Starter
LostBoyNZ's Avatar
Liked: 1
Thumbs up Our new build Home Theater design
I'm really thankful to be in the position where we're making the space of two bedrooms into a dedicated home theater in our new build home. Being my first home theater though, of course I'm overflowing with questions. I know doing research is the #1 priority, so I hoped to ask some of the questions here. Thanks in advance for any help!
Our room is 5.82 x 3.48 meters / 19.09 x 11.4 feet, and 2.4 meters high / 7.87 feet high.
Our screen is a used 130" Studiotek 130 16:9 Fixed Screen, so about 2.9 x 1.6 meters / 9.5 x 5.2 feet.
Our speakers are the Klipsch RC-64 II Center, 2 x Klipsch RF-82 II Fronts, 2 x Klipsch RS-62 II Rears and 2 x Power Sound Audio XV15se 15" Subwoofers.
Our receive is a Pioneer VSX-LX70, but likely I'll look to upgrade that and ideally maybe add a couple of speakers for an Atmos setup if that's possible.
I haven't decided on a projector yet.
Ideally looking to have two rows of seats, and build a riser, but I'm not sure if the room isn't quite big enough for that? Hopefully it's ok having the fronts by the walls too, but I realise it's probably not ideal.
At the moment though we're looking at colors and thinking about this for the walls, ceiling and the door: https://www.dulux.co.nz/colour/all-c..._duluxnz_28377 But I do wonder if it's dark enough? The darker shades certainly show marks easier though.
Then I was thinking about doing all the walls with curtains to help with the sound too, and it seems recommended to have them about 3 times the length of the wall space, so I'd need about 45 meters / 147 feet. Something like this would be in budget: https://www.bunnings.co.nz/home-styl...rtain_p0037800 (a little under US$ 1000) excluding rails etc. They're Polyester/Cotton, black, insulated and plain textured and I know someone managed to get them in a 2.4 m drop which is the height of our room, so I'm hoping I'll be able to as well.
Any recommendations in terms of what to think about with the paint and / or curtains would be a great help Of course feel free to ask any questions at all too.
LostBoyNZ is offline
post #2 of 5 Old 05-28-2020, 05:26 AM
sirjaymz's Avatar
Quoted: 531 Post(s)
Liked: 649
Congratulations on the new home and welcome to the forum.
Starting with a drawing and a plan is the right move. Good job. Make a budget as well. Continue to read AVS Forum to educate yourself and ask questions.
"Our speakers are the Klipsch RC-64 II Center, 2 x Klipsch RF-82 II Fronts, 2 x Klipsch RS-62 II Rears"... my same setup.
You should be able to do 2 rows in 19'. @deauxt was at that same length, and his turned out really well.
IMHO, definitely go with Atmos receiver and speaker layout. (7.2.4) or more.
As for the color, definitely go dark. By making the room darker, it's more immersive when watching. No bright spots in your FOV.
Not sure what you're thinking on the curtains though ... "to help with the sound too". This statement is confusing.
If you are using curtains for sound proofing or acoustic treatments, I'm unsure.
Sound "proofing" - This requires mass, isolating, decoupling, etc.
Acoustic treatments - absorption, dampening, reflections, dispersion, scattering. - These are intended to make a more enveloping balanced sound within the space itself and improve the intended directors vision of the story.
Two threads highly recommend reading that will help you get a clear understanding of your intentions.
Acoustical Treatments Master Thread
Soundproofing master thread
You can do speakers by the walls, however, need to have acoustic treatments in mind for the audio reflections, etc. Ensure they are toed in towards the MLP however.
Again, welcome to the forum. Good luck on your build.
HT1.0 | HT2.05 | Bass EQ for Filtered Movies
JVC RS-2000 / Seymour AV Center Stage 130"diag, 2.35 / nVidia Shield
11.2(22).6 Atmos / Denon 7200WA / Denon 6300 / 2x miniDSP2x4HD / DIY treatments
2x NU6000DSP / 2x NU3000DSP / 2x Klipsch R-112SW / 4x UM18-22 / 4x PA-460 / 12x JBL 12"
Klipsch RF-82II/RC-64II/RS-42II/RS-41II/RB-61II/CDT3800-C-II
sirjaymz is offline
post #3 of 5 Old 05-29-2020, 04:45 PM - Thread Starter
LostBoyNZ's Avatar
Liked: 1
Thanks! I had a look for deauxt's thread (here) and wow that came really well yeah! That's a great sign
Must admit the 7.2.4 Atmos setup looks tempting. I'll have to see if it all fits into the budget but I think there's nothing wrong with adding more later if needed. Just great to plan for it now I guess as I can put in the wiring etc.
Sorry I should have been more specific with the curtains comment. I'd read they work well for absorbing sound to cut down on reflections, which makes the surround sound more accurate. For sound proofing, we're getting double 13mm / 0.5 inch plasterboards on both sides of the walls (total of 52mm / 2 inches of plasterboard) and r2.6 fibreglass insulation in the walls. As with everything I know there's certainly more we can do there, but hopefully that does the job well.
Thanks for the links to those threads too, I'll check those out.
Likewise thanks for the advice on what to do with the front speakers
post #4 of 5 Old 05-29-2020, 08:07 PM
Quoted: 6671 Post(s)
Liked: 6548
Actually when you cut down all reflections you make the surround sound more specific to the location of the speakers, an artificial sound stage with easily identifiable pinpoint sounds that don't sound surrounding. You need some reflections to properly reproduce what the sound engineers put in product. When you eliminate all side wall reflections the front sound stage which is often a large orchestra recording the score will sound like a bunch of musicians sitting between the left and right speakers, when you have sound mix of partially absorbed, controled reflections and diffusion you close your eyes and the orchestra is sitting in an orchestra hall. Bottom line is too much absorption is not a good thing.
trancedigital likes this.
post #5 of 5 Old 05-30-2020, 03:00 AM - Thread Starter
LostBoyNZ's Avatar
Liked: 1
Thanks for that tip, that's good to know. I watched some of these videos on absorption and reflection here today: https://www.youtube.com/channel/UCwx...mIaH1jQ/videos And it's very interesting to learn about absorption panels and combo panels.
It seems like the Klipsch RC-64 speaker has terrible off-axis sound and he talks about how you have to absorb everywhere in that case. But I have no idea if that applies to the mark II version as well, or my Klipsch RF-82 II Fronts or Klipsch RS-62 II Rears.
I see there's some panels available here in New Zealand which I could get a few of, and then experiment with having a couple at the back, and few on either side, using the "mirror trick". I can see how this all gets confusing very fast haha. But I'm certainly learning a lot.
dedicated home theater , design help , new build , new zealand
