Fiberglass insulation questions... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-07-2004, 12:59 PM - Thread Starter
lunnar's Avatar
Quoted: 59 Post(s)
Liked: 42
Ok I've decided to use Fiberglass batts insulation in my wall because of the NRC-CNRC study . But this document referer to 2 types of Fiberglass Batts Call G1 and G2 where G2 seem more dense. but thru some analysis of this document, G1 seem to give better soundproofing partiulary in the 50-100 Hz region
Now If I look at Owens Corning Firberglass material for 2X4 stud wall, they got 3 types : R11, R13 and R15. I understand that this R rating reffer to heat isolation but does it meen is is also more dense??
now I am trying to match those G1 and G2 with the R11, R13 and R15... any idea ??
-Lunnar
"Tempo is everything, perfection unattainable..."
lunnar is offline
post #2 of 4 Old 07-08-2004, 01:09 PM - Thread Starter
lunnar's Avatar
Quoted: 59 Post(s)
Liked: 42
*bump
-Lunnar
lunnar is offline
post #3 of 4 Old 07-08-2004, 02:01 PM
BasementBob's Avatar
Quoted: 137 Post(s)
Liked: 139
http://www.cmhc.ca/publications/en/r...ch/02-108.html
says
Generally, at low frequencies, the increase in the transmission loss of a partition obtained by adding a sound absorptive material inside its cavity is equivalent regardless of the material used. Above 250 Hz, mineral fiber and blown cellulose give the best results; mineral fiber insulation provides slightly better transmission losses than glass fiber, especially around the critical frequency. Also, in the case of glass fiber, a greater transmission loss can be achieved by using denser batts.
on page 64 of
http://irc.nrc-cnrc.gc.ca/fulltext/ir693/ir693.pdf
it shows the airflow resistivity of G1 as 4300 mks rayls/m, which seems fairly low to me so it might be fluffy fiberglass. The thickness in mm can be used to tell if it's R19 or so on.
An amateur built the Ark. Titanic was built by professionals. Of course Noah took a little advice.
BasementBob is offline
post #4 of 4 Old 07-08-2004, 02:31 PM - Thread Starter
lunnar's Avatar
Quoted: 59 Post(s)
Liked: 42
Well BasementBob, your are trully my savior in all my post!
thanks again!
So maybe I shoud just ask you What do you think is better insulation to put between the stud?
-Lunnar
lunnar is offline
Closed Thread Dedicated Theater Design & Construction
