Show me your RACK - Page 97 - AVS Forum | Home Theater Discussions And Reviews
 661Likes
post #2881 of 3083 Old 12-14-2017, 04:42 PM
SMHarman's Avatar
Quoted: 419 Post(s)
Liked: 140
Originally Posted by hkp2k View Post
My new Middle Atlantic RCS-4224 showed up today! This will be a fun project over the break
Originally Posted by marina_av View Post
Nice! I have the RCS-1824 on the way. Can't wait to load it up.
Arrives built. That's nice. I got a SNAP AV one and had to ikea that into a shape like this.
SMHarman is online now
post #2882 of 3083 Old 12-16-2017, 08:11 PM
hkp2k's Avatar
It is unwrapped and in place next to my "other" rack. Vertical power strip and wire strip installed. Next week it will all come together.
steebo777 and azz7686 like this.
hkp2k is offline
post #2883 of 3083 Old 12-16-2017, 10:21 PM
Quoted: 159 Post(s)
Liked: 91
Nice racks!
TV: Panasonic 60" VT60 Plasma Surround: Yamaha RXA3050 5.1.2 Definitive Technology BP7006 (front), DefTech studio 350's (rear), Def Tech Di6.5r (ceiling) Players: Raspberry Pi running OpenElec/Kodi, Roku, Sony Blu-ray Control: Control4, whole house automation
Kevin4730 is offline
post #2884 of 3083 Old 12-18-2017, 09:31 PM
happy hopping's Avatar
Quoted: 139 Post(s)
anyone see where you can buy a AV rack like this? it originally from Netherland, but when I try to contact the maker, there is no response
https://imgur.com/a/rSUAB
alternatively, where do you find someone to custom build a wooden AV rack like this?
happy hopping is offline
post #2885 of 3083 Old 12-19-2017, 06:53 AM
deewan's Avatar
Quoted: 642 Post(s)
Liked: 819
I would start by contacting some furniture makers in your area. They would have the resources, equipment and materials to make something like that. I'm guessing the original isn't cheap to purchase, and I promise a custom made rack won't be cheap either. But if that's the look you are going for, I'm not sure you have any other choices unless you want to tackle it yourself.
The Other Theater (most recent build)
Old Woods Remodel
Old Wood Theater (first build)
Marantz 8805 (Emotiva RMC in a box) | JVC X790R | Emotiva XPA-5 | Emotiva XPA 4-3s | Oppo 203 | DIYSG 1099 | DIYSG Volt 8 | DIYSG Volt 6 | SVS PC-4000 | Seymour UF 132"
deewan is offline
post #2886 of 3083 Old 12-20-2017, 01:02 AM
Quoted: 139 Post(s)
what do you think the approx. cost would be?
post #2887 of 3083 Old 12-20-2017, 06:42 AM
dhendriksen's Avatar
Quoted: 48 Post(s)
Liked: 40
4 figures for sure.
dhendriksen is offline
post #2888 of 3083 Old 12-20-2017, 08:56 AM
Quoted: 139 Post(s)
that much, I just drop my jaw
post #2889 of 3083 Old 12-20-2017, 08:59 AM
SMHarman's Avatar
Quoted: 419 Post(s)
Liked: 140
Originally Posted by dhendriksen View Post
4 figures for sure.
For sure. There is a lot of unpainted millwork there and those custom metal parts.
A basic Snap or MA rack is in the mid to high 3 figure. Add doors and sides that gets to four figure.
post #2890 of 3083 Old 12-20-2017, 05:58 PM
Quoted: 139 Post(s)
is there some place on the interet that I can buy finished high quality wood, all painted in rectgular sizes of my choice?
post #2891 of 3083 Old 12-21-2017, 06:48 PM
IVRINGS's Avatar
Quoted: 25 Post(s)
Still need to move a few things around, but this is how I'm doing with a 2 post rack. I know now I want my blu ray player lower for use, but it works for now. Just added the UPA 5 and enjoying it so far. I'll move into a 4 post soon.
IVRINGS is offline
post #2892 of 3083 Old 12-26-2017, 09:40 AM
JamesVG81's Avatar
Quoted: 106 Post(s)
Liked: 63
Just finished adding a few more things to my setup. Added outlaw audio amp and Sony x800 uhd player. Believe I'm done messing for a while. Can't believe it's almost full now.
ID:	2335528   Click image for larger version
JamesVG81 is offline
post #2893 of 3083 Old 12-31-2017, 11:03 AM
fierce_gt's Avatar
Quoted: 2031 Post(s)
Liked: 1925
nothing fancy, but i'm happy with the results
it's just a simple shelf system, open to the crawlspace for access
messy wiring, but i wasn't going to waste time since it all had to come apart to paint anyway
ID:	2337906   Click image for larger version
ID:	2337908   Click image for larger version
ID:	2337912   Click image for larger version
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC, PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #2894 of 3083 Old 12-31-2017, 04:38 PM
gdfein's Avatar
Quoted: 128 Post(s)
Liked: 56
Looking for advice on rack layout. My equipment list is as follows:
C4 800 Controller
ATV 4K and Sonos Connect and DTV C61K mini
Sony PS4
Xbox One
Oppo UDP-203
DTV HR54 Genie DVR
Space
Panamax M5400-PM
Space
Marantz AV8802A
Space
ATI AT528NC - 8Ch
Space
ATI AT543NC - 3Ch
I’m using a MA Slim5, 29U on casters and wondering if I can cram all this in 29U and have adequate ventilation. I am height limited and the 29U on the 4” casters is max height. This rack tucks into an alcove under stairs in a storage room adjacent to my theater.
My logic in putting the amps and AVR lowest as they are heaviest giving rack a low COG for max stability. I also figured it will be easy to bundle 11ch of speaker wires together into the pass-through to the theater. I also figured this would allow for relatively short interconnects between AMPs and PrePro.
I have the frame of the rack put together and the first three 4U ventilated shelves screwed in with a 1U spacer in between working from bottom up and now “analysis paralysis” is setting in. For example should I reverse the Marantz and Panamax so that HDMI and Ethernet from above don’t have to run past the panamax? But then the audio interconnects run past the Panamax to the amps.
Argh!!
Help and recommendations welcome to unlock my paralysis.
Greg
gdfein is online now
post #2895 of 3083 Old 12-31-2017, 09:13 PM
LydMekk's Avatar
Quoted: 224 Post(s)
Liked: 241
Remember the amps give out heat so placing them low will heat all other pieces mounted higher in the rack.
gdfein likes this.
"If everything is under control you are just not driving fast enough"
Home Theatre Heaven in Spain - V2.0 - Build thread
LydMekk is offline
post #2896 of 3083 Old 01-01-2018, 10:15 PM
rmazeffa's Avatar
Quoted: 37 Post(s)
cooling fan install for my built-in-shelf based equipment?
see photo...
We want to leave the doors as-is, and leave them closed. I have an IR repeater so I'm all good when it comes to sending signals, but it's getting too warm in the enclosure and I want to put in a basic cooling fan with thermostat.
I know a simple cooling fan like an 'AC Infinity Airplane T3' fan would do the trick, but that fan (and all models like it) seem to require access on both sides of the cabinet wall, in order to install. (I want to mount the fan on the inside-back wall of my enclosure, which means I only have access to 1 side of the wall. Naturally I cannot/do-not want to mount any fans on the front doors.)
Maybe there are cooling fans that only require access from 1 side in order to mount? (but I haven't found any yet...hmmmmm)
Thx for any ideas or thoughts!
Rob
rmazeffa is offline
post #2897 of 3083 Old 01-02-2018, 08:58 AM
Waterboy77's Avatar
Quoted: 604 Post(s)
Liked: 317
Originally Posted by rmazeffa View Post
see photo...
Rob
Hi Rob, I hope this gives you some ideas....
It's tough to see how much space you have behind the equipment but if you can fit the fans at the back in a "removable" enclosure.
For air to really move you need an in and an out....
Check out the drawing as I will probably fail to describe it very well
Basically two heat registers mounted to the from under the doors and using the lower part of cabinet as "ducting" to the inside of the cabinet
Name:	cabinet cooling.png
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is offline
post #2898 of 3083 Old 01-02-2018, 10:27 PM
rmazeffa's Avatar
Quoted: 37 Post(s)
hi, thx for the cooling ideas. Yeah, that could work! I have a space for a register as your diagram shows, didn't think of that!
Waterboy77 likes this.
rmazeffa is offline
post #2899 of 3083 Old 01-23-2018, 07:17 PM
Liked: 8
Ok. Here are mine
Here are my pics of our recently (almost) completed theater..
ID:	2350340   Click image for larger version
ID:	2350342   Click image for larger version
Tedd, azz7686, SMHarman and 2 others like this.
filmmixr is offline
post #2900 of 3083 Old 01-24-2018, 08:44 PM
Quoted: 127 Post(s)
very cool cabinet. Are you using an IR repeater or something?
enkrypt3d is offline
post #2901 of 3083 Old 01-25-2018, 08:15 AM
IVRINGS's Avatar
Quoted: 25 Post(s)
Show me your RACK
Anyone have any RSH shelfs without faceplates? Looking for three 2U and one 3U. Let me know. As I want to get out of my two post rack cause I have my 4 post in a box.
IVRINGS is offline
post #2902 of 3083 Old 01-25-2018, 10:24 AM
Liked: 8
Thank you.. it's compact which I like.
I'm not using any IR repeaters. They seem quite complex to me.
The entire room is run via ios interfaces;
1. The Blu Ray is a standard Sony unit, they have a remote app called Video & TV sideview.
2. Sound switching and control (receiver in residential terms) is a custom system that I designed and built from BSS Soundweb London integrated downstream of the Dolby decoders.
3. Lighting is Philips Hue.
I'm a sound designer for film and television and I also work in the room so I wanted the same headroom as the theatrical mix stages I work on. That meant all professional reference equipment from D to A conversion through to the monitoring system. The room is currently 7.1 and is wired for atmos - we just haven't spent the money yet on the additional components.
filmmixr is offline
post #2903 of 3083 Old 01-25-2018, 11:55 AM
deewan's Avatar
Quoted: 642 Post(s)
Liked: 819
I don't have any without face plates. I have one shelf with a face plate for the UPA-5 you show.
I suggest looking at Parts Express if you just need a shelf and not the face plate. Or even eBay. I've purchased several shelves for my rack without a face plate and had good luck at both sites. They are RSH equivalent but much cheaper.
Old Woods Remodel
deewan is offline
post #2904 of 3083 Old 01-25-2018, 12:16 PM
IVRINGS's Avatar
Quoted: 25 Post(s)
Well I want the RSH shelf only so I will be able to add the face plates later. I can buy locally standard shelves for $25-35, but after I swap them out I would have extras laying around. I don't want them to start being like car parts with me. As for the UPA I have the black trim from Gen 2 and rack ears from Emotiva and my Denon X4300H. So No need for those to be mounted on shelves. Can't beat the pricing of the rack ears for them.
IVRINGS is offline
post #2905 of 3083 Old 01-25-2018, 12:40 PM
deewan's Avatar
Quoted: 642 Post(s)
Liked: 819
@IVRINGS I have purchased all my RSH shelves and face plates from https://www.customavrack.com/category/20-middle-atlantic-custom-rack-shelves.aspx. They used to have the best prices I could find. If I remember correctly it adds some cost of you purchase the shelf and face plate separately. Might want to bite the bullet and order them together now.
Old Woods Remodel
deewan is offline
post #2906 of 3083 Old 01-25-2018, 04:57 PM
IVRINGS's Avatar
Quoted: 25 Post(s)
I sent in a quote to the e-mail asking about that. The problem is in waiting to see what happens with the oppo unit if it is getting updated from what Sony did that is messing everyone up. Also I would replace my Xbox one before I spend $120-140 for a faceplate for it. So it would be buying two units and then all the shelfs it would be to much at this time with a kiddo due in the next 15-35 days.
IVRINGS is offline
post #2907 of 3083 Old 01-26-2018, 09:03 PM
Quoted: 56 Post(s)
Liked: 6
So many cool looking racks and I'm not even a third of the way through the thread. This thread has given me so many ideas when I finally can build my HT. Keystone speaker wire post? I would never of thought about that as an organization method.
Tatts4Life is offline
post #2908 of 3083 Old 01-29-2018, 07:28 AM
v8maro's Avatar
Quoted: 50 Post(s)
Liked: 36
Where could I buy a glass front door (smoke) for my half rack?
Sony VPL-VW385ES | DES ALR 130" 2.40 screen, Denon AVR-X6300H, SVS Prime 7.1.4 ATMOS, HSU Research ULS-15 MK2 Sub, RSL Ceiling speakers
v8maro is offline
post #2909 of 3083 Old 01-29-2018, 07:38 AM
deewan's Avatar
Quoted: 642 Post(s)
Liked: 819
According to google there are several places. Here is one of them: Middle Atlantic glass Door
Not sure if that door will fit your specific model since you didn't list your model. But a google search should reveal your answer.
Old Woods Remodel
deewan is offline
post #2910 of 3083 Old 01-29-2018, 07:45 AM
v8maro's Avatar
Quoted: 50 Post(s)
Liked: 36
Awesome, thanks. I don't have a rack yet, I was considering building my own shelves then adding a glass door - do you know if that door only fits a MA rack?
v8maro is offline
