Minimalist Approach to Screen Wall - Page 35 - AVS Forum | Home Theater Discussions And Reviews
 410Likes
post #1021 of 1034 Old 05-08-2020, 10:53 AM
pkinneb's Avatar
Quoted: 375 Post(s)
Liked: 1282
I just held up the rear layer and plastic with a couple screws and then screwed the front layer with like 6 per panel through the whole works.
BIGmouthinDC likes this.
My Theater Build - Full Circle Cinema
Left over Supplies for Sale - For Sale
pkinneb is offline
post #1022 of 1034 Old 05-08-2020, 05:32 PM
mkiv808's Avatar
Quoted: 152 Post(s)
Liked: 37
I actually used staples for first layer. Worked fine. So will screw second layer.
mkiv808 is online now
post #1023 of 1034 Old 05-08-2020, 06:13 PM
mkiv808's Avatar
Quoted: 152 Post(s)
Liked: 37
Is there much of a consensus whether bottom attachment is needed on most screens? I just did the goalpost like this
MinHeadroom likes this.
post #1024 of 1034 Old 05-18-2020, 10:08 PM
Jirachi's Avatar
Liked: 1
How exactly are these being set into place between the floor and ceiling? All I imagine is needing to hammer the top or bottom piece into position to get it snug
ID:	2728984   Click image for larger version
Rjloper9 likes this.
Jirachi is offline
post #1025 of 1034 Old 05-19-2020, 06:06 AM - Thread Starter
Quoted: 6543 Post(s)
Liked: 6397
Doesn’t need to be snug, just secured with screws. if I can’t put it in place without banging I take 1/8 inch off and try again. If it is too short I slip a shim up top.
4fit?, JPeezy13, Rjloper9 and 1 others like this.
post #1026 of 1034 Old 05-21-2020, 08:26 AM
Ladeback's Avatar
Quoted: 1612 Post(s)
Liked: 621
Send a message via MSN to Ladeback
I would think if the screen is touch the sides you wouldn't necessarily need a cross piece at the bottom unless you fell it does. Looks good.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #1027 of 1034 Old 05-21-2020, 08:44 AM - Thread Starter
Liked: 6397
A few screen that I've installed recommended and provided clips at the bottom of the screen to pull the screen material tight, IMHO Kind of a band-aid for a flimsy screen frame. In that case you need the bottom board otherwise I usually skip it as it just gets in the way when you want to do any maintenance on your speaker array. It is a good idea to paint the goal posts black.
post #1028 of 1034 Old 05-22-2020, 05:47 AM
Quoted: 81 Post(s)
I followed the same minimalist design ideas but included a cross piece at the bottom. When I hung my screen I found one of the bottom corners of the screen frame wanted to hang about an inch off the vertical post. I don't know where this is coming from, maybe some warp in one of the horizontal cross beams, or just a combination of different elements not being perfectly level or perfectly vertical. At any rate, I used a very small black plastic clamp to pull that bottom frame corner back to the cross beam. If I didn't have the cross beam I would not have been able to do this simple fix. On the other hand, maybe the cross beam created the problem in the first place. Part of the joys of working with wood.
Steve
Harddrive2 is online now
post #1029 of 1034 Old 05-22-2020, 06:10 AM - Thread Starter
Liked: 6397
I've experienced the same one corner issue a few times and I think it is the diagonal cut of the fabric to avoid moire that is contributing to the problem. One solution I've found is to get a short piece of Zclip and mount it vertically near the bottom corner, Then when you hang the screen start with it 1/2 inch to the side of the clip and then move it over hooking the clip like along the top. And it is always just a one corner problem.
Rjloper9 and Jan3 like this.
post #1030 of 1034 Old 05-22-2020, 06:18 AM
mkiv808's Avatar
Quoted: 152 Post(s)
Liked: 37
Steve
I wound up not needing the bottom bar. Everything wound up straight. Guess it depends on the wood and screen
post #1031 of 1034 Old 06-01-2020, 07:16 AM
mumbles60's Avatar
Quoted: 74 Post(s)
Liked: 36
I have a question around the use of Z-clips / French cleats... If the uprights and horizontal board all meet in a flush surface, the cleats would stick out from that surface causing a gap along the top, correct? Not sure if that makes sense...
mumbles60 is offline
post #1032 of 1034 Old 06-01-2020, 08:23 AM - Thread Starter
Liked: 6397
Actually the metal clips that grab the metal extruded screens frame from the back pull it tight to the flush surface, If you are DIYing a frame and using clips on the goal post and the back of a wood frame there may be a slight gap, if this is the case just fasten some spacers at the bottom so it hangs plumb. This has never been a problem. sketch not to scale
post #1033 of 1034 Old 06-01-2020, 09:38 AM
mumbles60's Avatar
Quoted: 74 Post(s)
Liked: 36
Thanks Big! Your sketch might not be to scale, but it was clear enough to make me have a light bulb moment... another case of me overthinking something
post #1034 of 1034 Old 06-01-2020, 09:54 AM - Thread Starter
Liked: 6397
better sketch
rboster, Rjloper9 and mumbles60 like this.
