How To: Rip 3D Blu-ray full resolution for LG 4K 3D for native Plex playback - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #31 of 53 Old 01-24-2019, 07:12 PM - Thread Starter
Actionable Mango's Avatar
Quoted: 330 Post(s)
Liked: 276
Originally Posted by htn00b View Post
Thanks for this. Is there a free alternative to BD3D2MK3D? I'm using a Mac and BD3D2MK3D is only available for Windows.
More so, I've tried DVDFab to rip 3D Blu-Rays into 3D MKV.4K.H265.10bit (also copying original audio of DTS-HD MA 7.1) and high bitrate. It takes 25 hrs and that's ridiculously too long for me.
Looking for alternatives if anyone has suggestions.
BD3D2MK3D is free, so I'm not sure what you mean by a free alternative.
If you meant Mac alternative, then no, I'm not aware of that. BD3D2MK3D is just a Windows GUI front end to a huge number of freeware tools. Basically what you fill out in BD3D2MK3D gets translated into a script that runs each tool in the right order with the right command line options. It might be possible, if every single one of those freeware tools has a Mac binary, to duplicate what it does on the Mac, but I haven't the foggiest idea about that. I'd just try to run BD3D2MK3D in a Windows VM. Maybe it will run in WINE, I don't know.
The reason why DVDFab is taking so long is H.265. You should be using H.264. Yes the file size will be larger, but the tradeoff is massive time savings. I've tried to speed up H.265 by dropping the quality slightly, but I noticed ringing/noise around high contrast edges in brightly lit scenes.
Also Blu ray spec is 8 bit so I don't think you should be picking 10 bit.
Actionable Mango is offline
post #32 of 53 Old 01-24-2019, 07:23 PM
htn00b's Avatar
Quoted: 21 Post(s)
Liked: 4
Yes I meant a free Mac alternative. I'll use your suggestion and drop it to H.264. Didn't see an option in DVDFab for 8 bit but Ill try that if it's available.
Thanks so much for your response!
- LG OLED55E6P | OLED | 4K | HDR | 3D
- ONKYO HT-S7800 5.1.2 Channel Dolby Atmos Home
- XBOX ONE S
- Apple TV 4K
htn00b is offline
post #33 of 53 Old 01-24-2019, 07:29 PM - Thread Starter
Quoted: 330 Post(s)
Liked: 276
If you select H.264 it should just be 8-bit by default. I doubt there is an option.
post #34 of 53 Old 01-27-2019, 08:11 PM
htn00b's Avatar
Quoted: 21 Post(s)
Liked: 4
It took about 9 hrs to encode using your H.264 suggestion. ill be trying it out soon. It's about 20gig which isn't bad at all
- XBOX ONE S
- Apple TV 4K
htn00b is offline
post #35 of 53 Old 02-22-2019, 03:48 PM
bjorg's Avatar
Quoted: 176 Post(s)
Liked: 94
Is there any way to queue movies up for BD3D2MK3D? I don't mind babysitting the ripping to MKV, but it seems silly that I have to launch each 3D conversion individually when the content is already present.
Abstract yourself!
bjorg is offline
post #36 of 53 Old 02-22-2019, 06:32 PM - Thread Starter
Quoted: 330 Post(s)
Liked: 276
Yes there is a batch encode in the file menu. Don't ask me how to use it, I never have. You could ask the author on doom9 forum, he is very responsive.
What I did was set up multiple projects and then just launch them all at the same time. To do this, don't mark the "Exit and Encode After Successful Demux" checkbox. This will demux and get all the files ready to go for the project, but won't actually start the encoding. After you have several set up, manually launch them all from the command line one by one and they will all start encoding.
bjorg likes this.
post #37 of 53 Old 02-25-2019, 07:03 PM
bjorg's Avatar
Quoted: 176 Post(s)
Liked: 94
I took a look at the batch encode, but it seems rather confusing. For now, I'm going to give the Zidoo Z9S a chance. Hopefully it can provide a comparable experience to Plex without the need to jump through so many hoops. Will report back!
Abstract yourself!
bjorg is offline
post #38 of 53 Old 02-25-2019, 07:41 PM - Thread Starter
Quoted: 330 Post(s)
Liked: 276
I took a look at the batch encode, but it seems rather confusing. For now, I'm going to give the Zidoo X9S a chance. Hopefully it can provide a comparable experience to Plex without the need to jump through so many hoops. Will report back!
I just started experimenting with the Zidoo in the last few weeks. It is better in some ways and worse in some ways. So I think you'll have to pick your poison.
post #39 of 53 Old 06-23-2019, 11:20 AM
Liked: 1
frustrating with this.....
Encoding movie in 3D
Movie: Captain Marvel (2019)
Encoding started 23/06/2019 18:12:18.93
C:\Users\.....\Documents\Captain Marvel (2019)\MKV3D>"D:\S\New folder\Recovered data 10-06 06_45_31\Deep Scan result\More Lost Files(RAW)\Rich Text Document\BD3D2MK3D (2)\BD3D2MK3D\toolset\x264_x86.exe" --output-depth 8 --crf 23 --preset medium --sar 2:1 --range tv --colormatrix bt709 --frame-packing 4 --qpfile chapters_3D.qpfile --frames 177957 --fps 24000/1001 --output "MKV3D_3D.264" "__ENCODE_3D_MOVIE.avs"
avs [error]: ERROR: Cannot initiate Intel Media Decoder.
(__ENCODE_3D_MOVIE.avs, line 20)
x264 [error]: could not open input file `__ENCODE_3D_MOVIE.avs'
Encoding finished 23/06/2019 18:12:19.44
C:\Users\....\Documents\Captain Marvel (2019)\MKV3D>"D:\S\New folder\Recovered data 10-06 06_45_31\Deep Scan result\More Lost Files(RAW)\Rich Text Document\BD3D2MK3D (2)\BD3D2MK3D\toolset\mkvmerge.exe" @__MUX_3D_OPTIONS.json | "D:\S\New folder\Recovered data 10-06 06_45_31\Deep Scan result\More Lost Files(RAW)\Rich Text Document\BD3D2MK3D (2)\BD3D2MK3D\toolset\tee.exe" "MKV3D_3D.mkvmerge.log"
mkvmerge v33.1.0 ('Primrose') 32-bit
Error: The type of file 'MKV3D_3D.264' could not be recognized.
Ray Mondo is offline
post #40 of 53 Old 06-24-2019, 05:40 PM - Thread Starter
Quoted: 330 Post(s)
Liked: 276
I don't know what any of this means. I suggest asking here:
https://forum.doom9.org/showthread.php?t=170828
post #41 of 53 Old 06-24-2019, 05:58 PM
Liked: 1
thx can u ask for me i registered but have to wait 5 days to post.
post #42 of 53 Old 06-24-2019, 06:45 PM - Thread Starter
Quoted: 330 Post(s)
Liked: 276
Sorry, I don't want to get involved. Send a PM to the thread starter R0lz.
post #43 of 53 Old 07-02-2019, 02:04 PM
Quoted: 632 Post(s)
Liked: 189
What is the best filter to use for resize in BD3DMK3D?
Avisynth Bilinear
Avisynth Bicubic
Avisynth Gauss
Avisynth Lanczos
Avisynth Lanczos 4
Avisynth Blackman
Avisynth Spline16
Avisynth Spline36
Avisynth Spline 64
x246 fastbilinear
x246 bilinear
x246 bicubic
x246 bicublin
x246 experimental
x246 area
x246 gauss
x246 sinc
x246 lanczos
x246 spline
ID:	2586774   Click image for larger version
noob00224 is offline
post #44 of 53 Old 07-02-2019, 03:14 PM - Thread Starter
Quoted: 330 Post(s)
Liked: 276
I don't know. I've never wanted to resize because the native size is correct and works.
post #45 of 53 Old 07-03-2019, 09:19 PM
Quoted: 632 Post(s)
Liked: 189
But generally speaking, wouldn't lanczos be the best?
post #46 of 53 Old 07-23-2019, 02:11 PM
Liked: 1
Hi yday I did one from 40gig disc to 7gb using this, surely there's a loss in quality? If so what's the best way to get like for like with no loss in quality?
post #47 of 53 Old 07-29-2019, 04:56 PM - Thread Starter
Quoted: 330 Post(s)
Liked: 276
There is no way to do a perfect bit-for-bit copy and have it play using the LG TV's native Plex player, which is the goal of this thread.
If you want perfect bit-for-bit 3D files to play on the LG TV, you need to use an external box of some kind and play back ISOs or MKV-MVC files, but that is out of the scope of this thread. AFAIK, your options are Windows10 HTPC (see Brazen1's signature), media players like the Dune and Zidoo, or the OPPO BD player (see relevant threads for those).
However, keep in mind that file size is not a good indication of quality when you are comparing an entire disc to a single file extracted from that disc. I will be very surprised if you can notice the difference in quality from normal viewing. But if you do notice and it bothers you, you can always bump up the quality setting and re-encode until you cannot tell the difference. See the x264 encoder options on Tab 5, it will explain how to increase the quality at the cost of larger file size.
post #48 of 53 Old 07-30-2019, 02:53 AM
Quoted: 632 Post(s)
Liked: 189
Tried with CRF 23 and medium preset and got an 6GB file. Not good quality. In the 3D Blu ray were to be extracted via MakeMKV (in full Frame Packing), the video alone is 27GB.
I understand that below CRF 18 is not worth it, but what other settings are required for a maximum quality HSBS/HTAB?
post #49 of 53 Old 07-30-2019, 10:48 AM - Thread Starter
Quoted: 330 Post(s)
Liked: 276
Does the "H" mean half? If so, why are you doing half instead of full? That's throwing away half the resolution in one direction. None of the other settings are going to fix losing that.
post #50 of 53 Old 07-30-2019, 11:24 AM
Quoted: 632 Post(s)
Liked: 189
It's Half. The display is a 1080p projector (Benq W2000).
I thought that when using the SBS/TAB's mode on this kind of display, half the resolution is discarded anyway since it can't display
2160x1920 or 3840x1080.
post #51 of 53 Old 07-30-2019, 11:47 AM - Thread Starter
Quoted: 330 Post(s)
Liked: 276
My instructions are pretty much the opposite of what you are trying to do in almost every way. It's a list of steps and settings designed to fit within the limitations of the LG's native Plex client while taking advantage of its ability to use 4K resolution in order to keep the full resolution of the source.
It is very confusing for me trying to help people on the assumption that this is what they are trying to do, when in fact they want to do something else completely, with different equipment, and don't mention that.
If you don't want loss of quality on your display, forget SBS and TAB. You want to present full resolution 1080P 3D signal to your projector. This is going to be accomplished with an appropriate media player, such as a Zidoo, Dune, OPPO BD player, or Windows 10 HTPC. Depending on your media player, rip your discs to ISO or MVC-MKV.
If you don't have a media player that can do 3D ISOs or MVC-MKV, then you are stuck with half resolution and no quality setting is going to help.
post #52 of 53 Old 07-30-2019, 12:37 PM
Quoted: 632 Post(s)
Liked: 189
Sorry for the confusion, I was referring strictly to BD3D2MK3D's functionality.
I want SBS/TAB because the video will be interpolated to 60Hz. The projector can't do Frame Packing at 60Hz, 24Hz maximum. It can however do 3D TAB/SBS @60Hz.
The 6GB file's quality was not good enough, and I've seen HSBS/TAB's with good quality.
How can the image quality be improved? The CRF set to 18? The preset?
post #53 of 53 Old 07-30-2019, 12:52 PM - Thread Starter
Quoted: 330 Post(s)
Liked: 276
Unfortunately I know very little about half resolution quality issues and settings because I am only interested in full resolution. The best place to get advice would probably be the Doom9 forums BD3D2MK3D thread here.
Reply 3D Displays
