Do I need a Sony brand transmitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-05-2020, 02:03 PM - Thread Starter
Quoted: 133 Post(s)
I inherited a Sony Projector VPL-HW55es and 3d doesn't work using my other active 3D glasses.
The manual lists these as optional accessories:
IR External Transmitter TMR-PJ2
IR 3D Glasses TDG-PJ1
The transmitter has been discontinued, with some used ones on Ebay.
Is there a replacement updated transmitter? Or do I need to find BOTH a used transmitter AND used glasses?
Or if I buy the used transmitter, will it work with any glasses?
AudioQuestions is offline
post #2 of 4 Old 01-05-2020, 07:59 PM
RonAlam's Avatar
Quoted: 125 Post(s)
Liked: 74
what glasses are you using?
RonAlam is offline
post #3 of 4 Old 01-05-2020, 09:09 PM - Thread Starter
Quoted: 133 Post(s)
I've tried two pairs from prior Sony TVs: TDG-BT400A and TDG-BT500A
post #4 of 4 Old 01-05-2020, 09:14 PM
RonAlam's Avatar
Quoted: 125 Post(s)
Liked: 74
Those aren’t compatible, you need Sony IR 3D glasses, not those BT ones
RonAlam is offline
Reply 3D Displays
